VWVortex.com - front wheel stud torque specs.
    Results 1 to 17 of 17
    Thread: front wheel stud torque specs.
    1. 06-30-2007 08:10 PM #1
      I'm putting spacers on right now and i had to modify my hub centric rings a bit, so i want to make sure all the wheel studs are torqued equally.
      Anyone know how tight they need to be?
      Thanks in advance.
      -Jon.
    2. 06-30-2007 08:16 PM #2
      i believe the standard is 90... i think.... thats what I torque to
    3. 06-30-2007 08:18 PM #3
      ok. I believe you.
      But everyone wants a second opinion.
    4. Member ryanmiller's Avatar
      Apr 13th, 2006
      beaverton OR
      oil burning 3 door
      06-30-2007 08:21 PM #4
      82 foot pounds.. thank ya bently [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Dub Cult ESAD
      Nov 6th, 2004
      Florida
      MK6 R
      06-30-2007 08:23 PM #5
      it's 89.
      90 will work.
      make sure you re-torque them after driving for a bit. sometimes spacers do weird things, never hurts to make sure.
    6. 06-30-2007 09:07 PM #6
      I torque all wheels to 94 foot pounds.
    7. 06-30-2007 09:18 PM #7
      My chart at work says 85. but i do 100 on pretty much everything.
    8. 06-30-2007 09:51 PM #8
      What size spacers do you have? Just ordered myself a set & wasnt sure about fitting issues. How did you get the fronts 2 fit right??
    9. Senior Member bluebora20v's Avatar
      Jun 14th, 2001
      Bay
      2000/VW/MK4 Jetta
      07-01-2007 02:05 AM #9
      Jesus Christ. 5 different torque specs in this thread.
      The CORRECT torque is 89 ft-lbs (that's what it says in Bentley btw NOT 82). You really shouldn't over-torque your bolts (or under-torque for that matter).
    10. 07-01-2007 02:40 AM #10
      1. 89lb-ft
      2. Bolts, not studs
    11. Member
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      07-01-2007 03:03 AM #11
      Quote, originally posted by bootymac »
      1. 89lb-ft
      2. Bolts, not studs
      This is correct, listed multiple times in the Bentley.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    12. 07-01-2007 03:11 AM #12
      Quote, originally posted by FaelinGL »
      Mike
      Yes, and over torquing is never a good idea. When you over torque, you can then next time push it even further. This will happen each time until stripping becomes apparent. Follow the Bentley and you should be fine [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. 07-01-2007 03:23 AM #13
      Mike
      Too bad my torque wrench only goes to 80lb-ft
    14. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      07-01-2007 03:45 AM #14
      whats the standard lug bolt head size? is it 22mm? doesnt say on my stock lug wrench, just curious what socket i can toss on my torque wrench next time i need to put them on properly(only getting up i feel like doing right now is for another beer else id go look myself, heh)
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    15. Member
      Nov 27th, 2004
      Charlotte, NC
      07-01-2007 04:01 AM #15
      17 mm.
      Mike
    16. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      07-01-2007 04:09 AM #16
      wow i was way off. ty [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 07-03-2007 10:21 AM #17
      Quote, originally posted by Platinum Dubber »
      Quote, originally posted by wtfmate3487 »
