VWVortex.com - Neuspeed Coil Springs - upside down?
    Results 1 to 5 of 5
    Thread: Neuspeed Coil Springs - upside down?
    1. 07-05-2007 07:35 PM #1
      Hello VWVortex Forum!
      I just had my mechanic install some Neuspeed Coil Springs on my Golf IV.
      As I am inspecting the job they did, i noticed the logo and information branding on the coils is upside down when viewing the springs in the front. Couldn't check the rear yet.
      My question is:
      Is this normal? How do i know if they installed it correctly? My gut (being a graphic designer) is that the logos should be right side up, but my expertise is not in cars.
      I also noticed the right shock top screw that is viewable under the hood is slightly hovering over the chassis. The left shock is snug to the chassis, but the right one has about a 1/4" gap from the mount to the chassis. Any advice on that as well. Much appreciated.
      (please go easy on me if this is a stupid question, but you guys are my know it alls when it comes to VW ) thank you for your input.
      Robert
      Modified by sphereboy at 9:27 PM 7-5-2007
    2. 07-05-2007 07:37 PM #2
      i dont think it matters if its upside down or not
      Mk6 CSG GTI 6sp | APR Stage 2 v2 93 oct ho | Sachs SRE Stage 2 Clutch | DG SS | Raceseng Ashiko Heavy Shift Knob | CTS Intake + Turboback | GFB DV+ | Neuspeed RSe52's + Intercooler | Michelin PSS | 034 RSB + Upper Strut Mounts + Street Density Motor Mounts | Eibach Pro-Street-S Coils | Energy Suspension Dogbone Insert | Fluidampr Pulley
    3. Member Dubsport Inc's Avatar
      Oct 12th, 2002
      Edmonton
      '61 Beetle '09 Rabbit '12 Ram 1500
      07-05-2007 07:38 PM #3
      The front can only go in one direction and the rear should have the closer coils at the bottom. Lots of spring manufacturers do this.
      HTH
      Richard
      P.S. 2001 and 50 posts that has to be a record.
    4. 07-05-2007 08:51 PM #4
      ^^^^^^yeah that is correct. good luck with the coils.
    5. 07-05-2007 09:29 PM #5
      Quote, originally posted by automan21 »
      thanks. they feel very nice. makes me want to take corners a little snappier.
      i checked out the rear coils and the tighter coils are towards the bottom.
      Any ideas on the mount sticking up from the chassis. Looks weird to me. I might swing by the mechanic and ask them, but i wanted to get your feedback as well. That way he can't jerk me around.
