VWVortex.com - AC not working :(
    Results 1 to 19 of 19
    Thread: AC not working :(
    1. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-11-2007 04:22 PM #1
      i needed a headlight changed, but had to go to work. i let my uncle (not a good idea) change the light, but he took out the filter and some other stuff thinking that was the best way to get to the back of the headlight...he didn't know about the lacht that brings the light out, now my AC doesn't work and Seattle is freaking hot!!!!!!
      what's a girl to do besides taking it to a mechanic??
      Modified by vwbuggy at 9:27 AM 7-12-2007
      Nov 29th, 1999
      On Vortex since the last millenium
      07-11-2007 06:23 PM #2
      Could he have messed with the fuses on top of the battery?
    3. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-11-2007 06:31 PM #3
      i did check all fuses to see if i noticed anything but they all seem fine. would there be a specific fuses i should consider?
    4. Member
      Mar 3rd, 2006
      Everett/Totem Lake
      95 Golf Sport
      07-12-2007 02:47 PM #4
      Can you tell when you turn the AC on from in the car if the compressor kicks on or not? Most of the time when it kicks on it will affect the idle for a second,.
    5. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-14-2007 02:59 AM #5
      Quote, originally posted by mhsballplaya2369 »
      no nothing... i feel air coming through the vents when i drive but the AC or the heater won't turn on
    6. Member
      Mar 3rd, 2006
      Everett/Totem Lake
      95 Golf Sport
      07-14-2007 12:17 PM #6
      So when you turn the fan speed up higher it doesnt affect how hard the air is blowing out of the vents? If thats the case i would double check all the fuses.
    7. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-14-2007 06:55 PM #7
      yeah your right...sigh...ok maybe i missed some thing...i'll keep checking
      Mar 3rd, 2006
      Everett/Totem Lake
      95 Golf Sport
      07-17-2007 03:11 PM #8
      did ya figure anymore out yet?
    9. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-17-2007 07:36 PM #9
      oh thanks for checking up on me
      but sadly no
      i'm still trying
    10. Member atoson's Avatar
      Dec 28th, 2002
      San Jose, Ca. South Bay Area
      12 Golf TDI, 00 GTI, 00 NB, 84 Scirocco, 80 Dasher
      07-18-2007 08:49 AM #10
      You're saying both heat and air doesn't work? You prolly talking about the fan switch and not the ac. The speed resistor is under the pass kick panel and outside the blower housing. It's actually a thermo protected fuse like they use for coffee makers. I fixed my wife's NB with a fuse that I bought from Fry's. Heating has nothing to do with the AC since it uses the cooling system for heat through a heater core.
      Modified by atoson at 5:53 AM 7-18-2007
    11. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-18-2007 12:20 PM #11
      Quote, originally posted by atoson »
      nice...and smart...um so can i do that or would it take a mechanic
      thanks for looking out
    12. Member atoson's Avatar
      Dec 28th, 2002
      07-18-2007 02:49 PM #12
      If you know how to use a VOM (in short digi volt meter) it would be as easy as reading voltage from a battery. Remove the glove box and look for an access port in the blower casing. Once you find it there be a fuse looking like a resistor but cased in aluminum. Find which one doesn't have continuity, that'll be the bugger.
    13. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-18-2007 08:42 PM #13
      in other words a mechanic, because there's no way i would be able to do that without messing something up
      thanks for helping me out
    14. Member atoson's Avatar
      Dec 28th, 2002
      07-19-2007 03:17 AM #14
      If you know how to use this tools it would be like learning how to floss your teeth the first time.
      1) Soldering Iron/gun
      2) Volt Ohm Meter
      3) Torx bit driver
      If you can handle that then prolly you'll save
      Parts = $5
      Tools all D above = $35-50 or even less
      Labor = $ 65- 120
      What you're trying to achieve is finding out whether the fresh air blower series resistance fuse which protects the blower fan speed switch thermally has reached it's protection threshold and blown. If there is no continuity of current through the fuse then it could be fixed by replacing the fuse using a soldering iron. Forums are here to make you understand that you don't necessarily have to shell out $$ when it's simple as screwing (like in changing a light bulb).
      Modified by atoson at 9:52 AM 7-19-2007
      Modified by atoson at 11:30 AM 7-19-2007
    15. Member atoson's Avatar
      Dec 28th, 2002
      07-19-2007 12:57 PM #15
      Yes it affects the idle or engine RPM's because of a large amount of parasitic load required to operate the ac compresor. When compresor activate via magnetic clutch, the two cooling fans active to lower engine temp caused by heat generated from the extra engine load and maintain engine speed at an idle condition.
    16. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-19-2007 02:05 PM #16
      sounds like fun
      thanks for your help i really appreciate it because i was soooo stuck i had no idea where i needed to start
      thank you again [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. Member atoson's Avatar
      Dec 28th, 2002
      07-19-2007 03:13 PM #17
      Quote, originally posted by vwbuggy »
      sounds like fun
      Just buy a Bently's CD or hard manual (worth the $$$) and see how much fun and educational specially money saving fixing problems which you csan tackle yourself. I'd rate the work difficulty a 2, 10 being hardest and 1 granny able.
      I'll try guessing since you're from SD that you're half asian because of my geographical observation (naval base).
    18. Junior Member Y2kTurboBug1's Avatar
      Dec 31st, 2004
      Steelville, MO
      Now:2007 MazdaSpeed3 / Then: Y2K TurboBug
      07-20-2007 02:31 PM #18
      Check this post for ideas...It could be 10 or 20 different things, but you never know. Good luck!
      http://forums.vwvortex.com/zerothread?id=3324658
      Les
    19. Member vwbuggy's Avatar
      Jul 8th, 2007
      White Center ha!
      New Beetle 2002
      07-20-2007 08:51 PM #19
      thank you i'm trying everything
