Whoa, good job! Came out nice![]()
#1
Well finally got around to buying a Ipod a couple of weeks ago. Decided to do the armrest install. Didnt come out to bad.
I basically just carved the wood out of a old shelf we had lying around at work.
Yes I know my interior is filthy, been meaning to clean it for a couple of years now.
#2
#5
already a bunch of DIYs for it out there...
if my ipod still worked I would do this![]()
#7
this is prejudism, my car doesnt have an armrestnice work tho
#8
WHOA!! Nice work brotha!!![]()
Came out clean.
You can go ahead and do one up for me when you gots time. HAHA!! No seriously...
Warren
#12
That looks tons better than all of the pictures I can recall from DIY's-past. Nice work!
Just because you can do something, does not mean you should.
#14
damn.. i need to do this. nice work.![]()
#17
Quote, originally posted by 99golfofpa » what did you use to carve out the wood?
I dont have any pics during, but I took a drill bit that matched the circumfrance of the corners and marked the bit with tape the depth I wanted to go and drilled the six corners out then drilled four lines down through the middle. After it was all drilled out just took a chisel and knocked it out. The bottom part took a small bit and drilled across then same thing just knocked it out with a chisel, then took a flat file and filed the opening to the size I needed.
#18
That install looks tight and quite professional!![]()
Very nice indeed.
#20
Hi, i am trying to do exactly what you have done but cant get the armrest apart to route the ipod wires, please can you give me any pictures or info on how to dismantle the armrest ?
really appreciate any help you can give me
Thanks
Rob.
#22
looks really good. too bad I don't have an armrest![]()
#23
nice work![]()
#25
wanna travel out to nj nd do mine![]()
#26
looks way better than the actual DIY![]()
I'm too lazy to carve out a holder for mine.
