VWVortex.com - i have searched and found nothing (g182) w/ vagcom
    Results 1 to 5 of 5
    Thread: i have searched and found nothing (g182) w/ vagcom
    1. 07-15-2007 06:04 PM #1
      how do i fix this code (g182)on vagcom
      input speed sensor circut malfunction / intermitent
      please help
    2. Banned
      Feb 26th, 2007
      07-15-2007 06:07 PM #2
      that doesnt look like a normal vagcom code
    3. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      07-15-2007 06:18 PM #3
      Quote, originally posted by shawshank2 »
      Correct, it's not.
      The G182 is the component, which is the Transmission Input Speed Sensor (G182).
      To the OP, we need the specific fault code to assist you in your efforts of fixing the problem.
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    4. 07-15-2007 06:35 PM #4
      17099 maby this is it
    5. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      07-15-2007 08:28 PM #5
      Quote, originally posted by whodat200si »
      If that's the case:
      * VW DTC 17099 (P0715) - Transmission Input Speed Sensor (G182): Circuit Malfunction, Electrical Fault in Circuit
      So, the ISS is either faulty or there's an electrical wire cut on the sensor.
      - Erik
