VWVortex.com - New Fault Code. Immobilizer? 17978/p1570
    Results 1 to 8 of 8
    Thread: New Fault Code. Immobilizer? 17978/p1570
    1. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      07-15-2007 05:49 PM #1
      Scanned the car today and found this gem of a code:
      17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-10 - - - Intermittent
      Been doing some searching and it seems that this problem is actually related to my key. Is there any way to test if it is the key or something deeper?
      ///BrooklynAutoRennen
      2014 VW GLI Autobahn/Nav/DSG - Two clutches. Two pedals. Four doors. No apologies.
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      07-15-2007 06:30 PM #2
    3. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      07-15-2007 07:27 PM #3
    4. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      07-15-2007 07:31 PM #4
      Not likely the key itself. More likely an intermittent problem somewhere else. Clear it and see if it comes back. If it doesn't come back frequently and you don't have problems starting your car, don't worry about it.
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    5. 07-15-2007 07:35 PM #5
      Key or the ignition switch. Ever have the car "Stall" approx 1 or 2 seconds after you start it? Pay close attention to the dash next time you will probably see a blinking car with a key icon.
    6. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      07-15-2007 07:38 PM #6
      Quote »
      More likely the immo pickup-coil or connections between it and the immo. But this code is common as dirt in immo-equipped cars and if the owner has never experienced problems starting, my recommendation is just to clear it and see how soon it comes back. I think the immo systems just wake up on the wrong side of the bed some mornings and throw this code.
      -Uwe-
    7. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      07-15-2007 09:16 PM #7
      Quote, originally posted by Uwe »
      -Uwe-
      Will do. Last week was the first time It's happened. It started and then shut itself off. I thought it was just that I didn't turn the key enough and therefore didn't engage the starter long enough. Never since and never before. I have scanned this car many times for many reasons and this, like I said, is the first time I've seen this code.
    8. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      07-15-2007 09:16 PM #8
      Quote, originally posted by joako »
      When it happened, there was no flashing anything on the dash.
