VWVortex.com - Wiper Mechanism Mechanical Failures [TOC, Photos done]
    Page 2 of 3 FirstFirst 123 LastLast
    Results 26 to 50 of 75
    Thread: Wiper Mechanism Mechanical Failures [TOC, Photos done]
    1. Junior Member Fratrick's Avatar
      Jan 22nd, 2009
      Midwest
      2004 Phaeton V8
      08-27-2011 06:30 PM #26
      Where on earth do you buy the bracket with arm? I can't find anything online anywhere
    2. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-28-2011 02:06 AM #27
      Just go to a VW dealer and order it there. Any VW dealer can order the part for you, they don't even need to know what a Phaeton is.
      Michael
    3. Junior Member Fratrick's Avatar
      Jan 22nd, 2009
      Midwest
      2004 Phaeton V8
      08-28-2011 10:31 AM #28
      Yikes, looks like I'm going to get raped on that one. Definitely going to take it to my mechanic first to see if he can loosen it up with the grease first. Worth a shot!
    4. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-28-2011 11:30 AM #29
      If you are in the United States, you can get a quote from any one of several VW dealers who sell parts over the internet at a discount price. I am not familiar with them, because I live in Canada, but I know some other forum members have purchased parts from these companies and seem to be happy. I think one of the larger companies is called "1st VW Parts" or similar.
      Personally, I don't think it is worth your while to attempt to repair the part you presently have - the problems are caused by corrosion, which implies that material is missing. Plus, the assembly is not meant to be taken apart, it is unlikely you will succeed in getting it back together (and working within an acceptable tolerance) even if you do get it apart.
      Michael
    5. Junior Member Fratrick's Avatar
      Jan 22nd, 2009
      Midwest
      2004 Phaeton V8
      08-28-2011 08:50 PM #30
      It seemed to work for Vipa. I have nothing to lose by trying. If it's screwed, then it's screwed one way or the other!
    6. Junior Member
      Nov 19th, 2006
      Montreal, Qc., Canada
      Phaeton V8 2004
      08-29-2011 09:05 PM #31
      The repaired wiper link arm connection is still working fine...
    7. Member udaymohan's Avatar
      Nov 8th, 2007
      Toronto
      2004 VW Phaeton V8
      10-03-2011 03:31 PM #32
      Well looks like mine went on me today as well, called the Dealership to see what they can do in order of a discounted rate for the replacement, waiting to hear back will advise on the results.
    8. Junior Member Fratrick's Avatar
      Jan 22nd, 2009
      Midwest
      2004 Phaeton V8
      10-06-2011 02:29 PM #33
      Fixed mine on my own with the new bracket/arm. Could not fix the siezed one at all. I even tried to hit it with a hammer and it would NOT BUDGE! Incredible that a 7 year old windshield wiper could sieze up that badly. I contacted VW north America about it and they seemed to be oblivious to this issue. Probably because of the fact there are so few phaetons out there. If it happens to you, be sure to call them up!
      Sep 6th, 2010
      Ohio
      2006 Phaeton W12, 2004 Phaeton V8 x2 (sold), 2011 Toyota Sequoia Platinum, 2009 Audi S5
      10-10-2011 05:08 PM #34
      I finished replacing the wiper arm linkages on both sides. My problem now is that while the passenger side blade moves in the correct pattern (full range of motion and stops where it should), the driver side seems to not move in the correct way (not quite full range of motion and stops before it is in the true down position). Anybody know how to fine tune the motion? Thanks...Jay
    10. Member
      Sep 6th, 2010
      Ohio
      10-11-2011 12:24 PM #35
      It would be of great help if any of you could post photos of your windshield wipers in the "service" position for me (photos in the down position would also be beneficial). I was able to mark the up position of the driver side before replacing the linkages but wasn't able to get the passenger side back in position to mark it. When I secure the wiper to match my "up" mark for the driver side, though, it seems to stop too high in the down position. Thus, the range of motion seems to be shorter than before (not achieving full range). Also, I have set the passenger side blade to stop almost pointing to the driver side blade when in the up "service" position. This helps reduce the amount of unwiped windshield area in the upper driver side view but I am afraid it is not really correct. The passenger side blade does return to a full down position, though. I hope this isn't too confusing to follow but any photos or advice would be greatly appreciated. Thanks...Jay
    11. Member udaymohan's Avatar
      Nov 8th, 2007
      Toronto
      2004 VW Phaeton V8
      10-24-2011 03:55 PM #36
      Would anyone know which fuse drives the passenger side wiper motor?
    12. Member WillemBal's Avatar
      Nov 20th, 2010
      Putten, Netherlands
      Phaeton 04W12, Crystal Grey & Extended Leather, '03AudiA4 1.8T, '51 BMW R25
      10-24-2011 05:00 PM #37
      Quote Originally Posted by udaymohan View Post
      Fuse 20 in the E-box.... Rating is 20 Amps. This fuse is located in the right air intake plenum chamber. To get there, wipers need to be removed, air intake cover and the plastic weir which is running right under the entire width of the windshield. This part is easy to recognize as the two wiper spindles are sticking through this part.
      Quite a job to replace just one fuse, to be honest!
      Willem
    13. Member udaymohan's Avatar
      Nov 8th, 2007
      Toronto
      2004 VW Phaeton V8
      10-25-2011 09:56 AM #38
      Quote Originally Posted by WillemBal View Post
      Willem
      Good Lord...that is a fair bit of work to do simply to replace one fuse...or determine if it has indeed blown.
    14. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      10-25-2011 01:33 PM #39
      Uday:
      Normally, one uses a diagnostic scan tool to determine if the fuse is blown or not. The scan will report if the fuse is blown... no dis-assembly is necessary.
      Michael
    15. Member udaymohan's Avatar
      Nov 8th, 2007
      Toronto
      2004 VW Phaeton V8
      10-25-2011 04:34 PM #40
      Quote Originally Posted by PanEuropean View Post
      Uday:
      Michael
      This is a valid point
    16. Semi-n00b
      Feb 25th, 2012
      Poland
      2004/VW/Phaeton W12 USA
      02-25-2012 05:06 PM #41
      Could someone repost pictures?
      thx
    17. Member WillemBal's Avatar
      Nov 20th, 2010
      Putten, Netherlands
      03-04-2012 06:09 PM #42
      Michael post #1 of this thread with original pictures:
      Hello Everyone:
      There have been a few reports recently of failures due to corrosion within the mechanism that operates the windshield wipers. As most of you know, the Phaeton has two entirely separate and completely independent wiper mechanisms – one for each side of the windshield – thus it is possible for one side to fail and the other side to continue to operate. Unfortunately, unless the side that fails happens to be in the ‘parked’ position when it fails, the remaining functional wiper blade will foul against the failed blade, so the outcome is the same – no windshield wipers.
      The failure appears to be caused by the round shaft that the wiper arm attaches to corroding within the aluminum (or other ‘white metal’) casting that contains it. There is an o-ring at the top of the round shaft where it enters the casting, and a bushing at the bottom, but it seems that liquid is somehow managing to get past these seals and into the middle of the casting. If you drive in an area where roads are salted in the winter, this water will contain salt, and the eventual result will be corrosion. As the ferrous metal shaft corrodes, friction within the casting increases, and eventually the fuse for the affected side wiper motor will blow. When the fuse blows, the wiper stops ‘wherever it may be’, and that is the end of your driving in the rain.
      I am going to advise our friends in Dresden about these failures (my VW dealer has encountered three different Phaetons with this kind of failure this year, including my car), and perhaps they can come up with some kind of test based on wiper motor current draw that we can use to determine if a problem is developing, for the purpose of taking action before the sudden failure. I think that the probability of encountering such a failure is directly linked to the amount of salt or brine that is used on your roads during the wintertime, how long winter lasts in your area, and how much you drive in the winter. In other words, I kind of doubt if Don in Scottsdale will be affected, and at the other end of the scale, I think there is a high probability of failure for cars registered in the Province of Quebec.
      The purpose of this post is to provide a little background on the failure, explain what happens, and provide some guidance to technicians who have to replace the mechanism.
      Below is a photo of a Phaeton showing what it looks like after the fuse blows on the passenger side wiper. The wiper stops dead wherever it may be when the fuse blows, and typically, this will interfere with the operation of the remaining (functional) wiper. This is Chris’s car.
      What it looks like when the fuse blows
      I suppose if you just happened to have a spare fuse handy, you could wait a few moments for the wiper motor to cool down, then put the spare fuse in, and you might get a few more wipes before the spare fuse blows. For all practical purposes, though, once the fuse blows, you are toast... the corrosion has caused the mechanical load on the motor to reach a point where the current required to operate the wiper is excessive, and the only solution is to replace the wiper mechanism. It is not uncommon for both of the blades to be damaged as a result of the fouling of the remaining functional wiper blade against the failed wiper blade, thus, you will probably need to replace both blades as well.
      Below is an illustration that shows the left and right side wiper blade mechanisms. Normally, these parts are not visible, they are covered up by the cover that goes over the air intake plenum, aft of the engine. These assemblies consist of the motor, the casting and linkages, and a few nuts and bolts.
      The motor itself is usually unaffected by the failure (the fuse protected it), thus the part you need to replace is the casting and linkage.
      Left and right side wiper drive mechanisms
    18. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      04-10-2012 03:23 PM #43
      Photos on page 1 rehosted.
      Michael
    19. Member
      Jul 5th, 2008
      Strasbourg - France
      May 04 V8
      04-10-2012 04:16 PM #44
      Hi Michael,
      Happy to see you again.
      Was anything decided concerning your thousands of photos ? Needing to rehost them every xx months is such a waste of your precious time and energy...
      Once more, none of the photos I put for free on photobucket since many years ago has ever disappeared or been removed by photobucket. Why don't you use photobucket ?
      I'm not affiliated with photobucket, and there are probably other sites that offer the same kind of service. I'm only advocating this site because I have experienced that none of the photos I put on it ever disappeared.
      P.
    20. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      04-10-2012 04:22 PM #45
      Hi Pierre:
      I do use Photobucket now. In the past, I used two 'Volkswagen specific' photo hosting sites (HostDub and later a site operated by OEM Plus) that have now shut down.
      I have an account with Photobucket, costs about $50 a year (a free account won't support the bandwidth needed by the forum), I will use that in the future for all photo hosting, including re-hosting.
      Michael
    21. 05-24-2012 01:11 PM #46
      Where would i buy the replacement bracket with operating rod and crank arm from and recommendation ?
    22. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      10-02-2012 09:58 PM #47
      Here is some additional information about how the windshield wiper system on the Phaeton is controlled:
      Pheaton Windshield Wiper System - Description and Overview
      Some information for decoding the diagrams:
      CAN means Controller Area Network.
      30 means terminal 30, which is battery supply voltage.
      31 means terminal 31, which is ground.
    23. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      10-02-2012 10:02 PM #48
    24. Member udaymohan's Avatar
      Nov 8th, 2007
      Toronto
      2004 VW Phaeton V8
      11-06-2012 06:52 PM #49
      Hi Everyone,
      As you all may recall a while back my passenger side wiper had stopped working. Turned out it was due to the corrosion that has been outlined in the post earlier.
      Well I experienced another wiper failure, only this time it's on the driver side. Now one major difference between two incidents is that while the passenger wiper had failed I could still operate the driver, headlight washers and windshield washer.
      In this instance I am unable to utilize anything, one could argue that it may be a safety feature to prevent the passenger wiper from smacking in to the stuck driver but not sure.
      Any checks I can do before heading it back to the shop, or would this be pretty much the same issue only on the driver side.
      As usual your input is always welcomed and appreciated.
      Thanks
      Uday
    25. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      11-07-2012 02:51 AM #50
      Hi Uday:
      My guess is that the passenger side wiper is a slave (subordinate) to the driver side wiper, and as a result, the control module will allow the driver side wiper and other wiper-related elements to continue to work if the passenger side wiper is not in the appropriate position, but not the other way around.
      The replacement process is more or less the same for both wiper arm pantographs. While you are having this done, clean out the air intake plenum at the same time, because it is really easy to get access to that plenum once the wiper arm assembly has been removed. See this post for more information about cleaning out the plenum: Cleaning Air Intake Plenum and Sunroof Drains.
      Michael
