VWVortex.com - Jonny's polished taillights project
    Results 1 to 17 of 17
    Thread: Jonny's polished taillights project
    1. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      Lewiston, Maine (USA)
      88 Scirocco, 78 bus, 91 Vanagon
      07-20-2007 01:23 PM #1
      as requested, here is the poroject thread for my polished taillights.
      Got a set of taillights for a song off ebay. they were pretty scrubby,
      but in great shape. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I got started right away on polishing them. first thing to do is to sand off all the ridges.
      cant go too fast, or you will melt the plastic. so I took a break.
      OK, so I took too many breaks. got the kegerator retrofitted for my extra keg of bud light. and had some friends show up.
      delicate sanding work should be done sober, so I put the lights away and went back to drinking.
      more pics to follow soon.
      Modified by JonnyPhenomenon at 1:27 PM 7-20-2007
    2. Member veetarded's Avatar
      Jul 28th, 2004
      [OO==w==OO]
      07-20-2007 01:31 PM #2
      You work like I do lol.
      Red Leader - Team Infidel
      The Price of 7reedom is the Willingness 2 do Sudden Battle Anywhere, Anytime an6 With Utter Recklessness
      -Heinlein
      Oct 8th, 2005
      MN
      g60
      07-20-2007 01:45 PM #3
      Sanding those lights down takes alot of time, What grit sandpaper are you using?
    4. Member
      Oct 8th, 2005
      MN
      g60
      07-20-2007 01:47 PM #4
    5. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-20-2007 03:18 PM #5
      I started with 120 since that is the coarsest I had. but a friend of mine just brought me some 80 grit and I am going to use that tonight.
      the intention is to get the majority of the ridges down with coarse grit, then get the last with a finer grit. so I wont have to do too much more sanding just to clean up the gashes I left with the heavier paper.
      ive got paper all the way up to 2000. and then I have polishing compound that will make this look like glass.
      Im not sure if I will smoke tint these tho. I really just like the glossy smooth look.
      but we shall see.
    6. 07-20-2007 03:25 PM #6
      Beer good (Homer Simpson, 1995), at this rate you could finish by next summer.
    7. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-20-2007 11:56 PM #7
      making progress
      Modified by JonnyPhenomenon at 12:01 AM 7-21-2007
    8. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-21-2007 12:02 AM #8
    9. 07-21-2007 12:04 AM #9
      looks good so far.
      how long did it take you to get the ridges off one light?
    10. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-21-2007 01:18 AM #10
      it took a couple hours of sanding with the sander I would say. altho I was trying to do it with 150 grit paper.
      those ridges are TALL. that is a lot of material to remove. almost make more sense to just polish them up without griding them down.
      regardless, it went a LOT faster when I picked up some 80 grit paper. I considered picking up some 40 grit, but that seemed a bit too aggressive.
      once I got all the ridges down with the 80, I went to work hand sanding with 150, then 320, then 2000, and then the polishing compound.
      I got a small crack in the reverse lense tho. I dont know if it was there already or if I cracked it with to much force. its not bad tho.
      I guess that it will encourage me to smoke tint them after all..
      tomorrow I get to work on the second one.
      here is another pic for your enjoyment.
      I started polishing the right side. the two red quares on the left have no polish, and the one on the right has had a cursory application.
      when these are done, they look like glass
    11. Member California Special's Avatar
      Dec 15th, 2005
      Garden Grove,CA
      83 Scirocco Cal Special, 69 Corvette
      07-21-2007 02:48 AM #11
      Very cool man, love the ingenuity. I would like to recommend you getting some of this stuff.
      http://waxdepot.safeshopper.com/161/167.htm?33
      I used many products for plastic over the years as I've built scale models for over 30 years now and this stuff is just magic with tail lights and instrument clusters,etc. Everybody should have this STUFF !! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-21-2007 09:31 AM #12
      one down. I used 3m "perfect-it" handglaze
    13. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-21-2007 09:32 AM #13
      Quote, originally posted by California Special »
      thanks for the tip! I will have to pick some of that up.
    14. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      Some American, British, German, and a bunch of Japanese.
      07-21-2007 11:49 PM #14
      Quote, originally posted by JonnyPhenomenon »
      Looking really good so far! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Lots of VW stuff|Rare Scirocco parts!
      The family: '55 Ford 351C, '70 TR6 262Olds, '80 Rabbit AAZ, '84 C30 350, '88 Scirocco 9A, '97 Hardbody KA24E, '01 TJ 150AMC.
      Quote Originally Posted by Crimping Is Easy View Post
      You're always better off with a Citroën.™
    15. Member slow_16v's Avatar
      Jan 24th, 2006
      California
      451, K1500, Z33
      07-22-2007 02:52 AM #15
      I was looking into shaving the lines.... when I tinting my rados tails I shaved the DOT markings and stuff... looked good....
      Edit Signature Here
    16. Member ginster86roc's Avatar
      Apr 19th, 2005
      oviedo fl
      86 volkswagen scirocco, baby
      07-22-2007 08:18 AM #16
      nice work.
      it IS a bit time consuming, the task of shaving them thar lamps...but your results are impressive. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      i good vibes... and sciroccos.
      Quote Originally Posted by sciroccojim
      Yes. Follow the adjustment procedure in the Bentley. Works like "magic."
      Quote Originally Posted by punchbug
      That's just how we roll.
    17. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-22-2007 05:08 PM #17
      got the second one sanded down. used 40 grit on this one to get the ridges off. then 80, 120, 150, 320, 1000, 2000 and the polishing goop.
      the first one came out great except for the one crack in the reverse lens, but the second one looks like it had a lot more sun/age damage to it to begin with, and you simply can not sand out cracks.
      its got a lot of "crazing" (as some people have called it) thoough it,
      basically it means that I will have to smoke them after all. I was really hoping to avoid that, I dont really like the smoked look. >.<
