Page 4 of 4 FirstFirst 1 2 3 4
Results 106 to 119 of 119
Thread: MKIV Rear brake job DIY with pictures
  1. n00b
    Jan 18th, 2011
    2002 VW Golf
    01-18-2011 04:06 PM #106
    This turorial was just great, it made it so easy. I used the caliper brake kit and it was a breeze.
    I bought some pads from Canadian Tire and also rented the tool kit from them, it was free but I did
    have to leave a $120 deposit, got the money back when I took the tool kit back.
  2. Member rajuncajun37's Avatar
    Apr 25th, 2008
    New Orleans
    2011 FORD .:Raptor
    02-09-2011 10:25 AM #107
    Quote Originally Posted by Iguana Man View Post
    Sorry to bump an older thread but I need to make sure that the tools and steps listed here apply to the 04' R32 as well. And that there is no scan tool needed to release the e-brake.
    Thanks!
    Glad you bumped it, I gotta do rear brakes on my R32 ASAP. Wish me luck
    *R32 1518*, biggest head ever to fit in a GOLF!
    Congrats, turd burglar.
  3. Member jaso028's Avatar
    Aug 12th, 2007
    02.5 24v GLI, 05.5 Jetta 2.5l
    02-09-2011 11:04 AM #108
    I know this is old...
    but on most MKIV's you can get the rotors on and off without pulling the carrier off...
    it will save you a step and the possibility of screwing up the allen bolts...
    I know on the 04.5's GLI's it might be more difficult to get the rotors off without pulling the carrier...
    N.E.R.D.
    White Lightning
  4. n00b
    Nov 9th, 2011
    new york
    2000 jetta 1.8t
    11-11-2011 03:56 PM #109
    I just wanted to thank you for posting this thread, I'm getting ready to do my rear breaks this weekend and its great having a thread w/ pictures included! I know its an old thread, but its still a great reference!
    PS going to rent the tool from autozone - $60 deposit that you get back when you return it
  5. 11-23-2011 02:54 PM #110
    Thanks for the thread. Did pads and rotors both front and rear. I'm curious, though, is it supposed to smell hot or burning after the initial test drive? I literally just got done doing this, so I'm wondering if I did it right. I didn't use any synthetic brake grease, but I could if necessary. The calipers seemed like they moved around pretty well on the carrier.
  6. Member
    Mar 23rd, 2008
    N/A
    N/A
    11-25-2011 12:15 PM #111
    Did you clean the preservative off the rotors before you installed them? If not the smell could be the coating burning off the rotors.
    Did you lubricate the slide pins at all? You wrote about not using a synthetic brake grease, but did you separate the calipers and carriers and lubricate the slide pins with anything? The slide pins could be seizing (generating the smell).
    Did you use a tool to retract the caliper pistons completely so the new brake pads could slide easily into place, or did you retract them only far enough so you could jam them in? The brake pad clearance is set by working the parking brake handle, after you have the rear brakes reassembled. If you didn't retract the brake pistons far enough, the brake pad clearance could be too small, causing the pads to rub on the rotors all the time (and the smell).
    Have you tried lifting the rear of the car, and spinning the wheels? There should be minimal rubbing of the pads on the rotors, and minimal sound. If it take some effort to spin the wheels due to brake friction, then the rear brake pad clearance is too small, and you probably didn't retract the pistons far enough. Or, maybe the pads are defective (too thick).
    Nov 7th, 2008
    Stamford, CT
    2001 (AWD engine) GTI :: 2011 Shadow Blue GTI
    05-28-2012 10:27 PM #112
    Uhhh ****, I think I put antseize in the wrong spot. I put it on the bolts that hold the carrier and on the spindle? (After the rotor is off) I. should I wipe it off? Wouldn't that just help the rotor not stick on? Can you even misuse anti seize lol? I accidentally put blue threadlock on the rotor screw and went to put antiseize on...to late its stuck lol. W/e iboth fronts broke off (reading that those screws just make alignment easier when installing wheels again)
    Should I wipe anteize off back of rotor/spindle area (not where pads touch)?
    Should I put antiseize on front rotor (top of tophat part,not hwere pads touch)
    Nov 7th, 2008
    Stamford, CT
    05-29-2012 08:34 AM #113
    guess ill find out ;o, about to bleed and test drive it xD
    Nov 7th, 2008
    Stamford, CT
    05-29-2012 08:35 AM #114
    going to slab some antiseize on both sides lol....i did have the left rear wheel tire stick on even after the lugs were off sooooo.
  10. Member
    Nov 7th, 2008
    Stamford, CT
    05-30-2012 10:36 PM #115
    Quote Originally Posted by phatvw View Post
    Quote, originally posted by gNYp »
    Do you need to remove the parking brake cable? (E-brake cable)
    THanks!
    No, you can leave it in place.
    Quote, originally posted by talknmime »
    At what point during the install do you use the Anti-Seize, Brake Cleaner, WD-40? Do you need to put Anti-Squeal on the pads?
    - Spray brake cleaner on both sides of the rotors right before putting the wheels back on. Wipe with a clean shop towel.
    - WD-40 for loosening bolts.
    - anti-seize for lug bolts
    - anti-squeal paste - goes on the BACK of the brake pad - the part that touches the caliper, not the rotor
    - hi-temp brake lube - goes on the caliper guide pins - there are two pins per caliper
    Modified by phatvw at 4:12 PM 11-28-2007
    Okay well, anti seize on lug nut bolts is a super bad idea haha...gf was going 50 mph and wheel started shaking and got to work and noticed they were so loose that she could move them with her fingers....When i put it on there I was like HMMm this seems stupid. Is it just me?
  11. 06-10-2012 11:35 PM #116
    hello,
    I have a question or two. What is the purpose of the spring things attached to the outer side of the pads? Should those go into the slot on the caliper? I was able to get one in there but not the other.
    Feb 9th, 2011
    yukon, oklahoma
    2000 Jetta GLS VR6
    06-12-2012 11:01 AM #117
    Quote Originally Posted by renglish View Post
    more tips:
    1) spray down the bleeder valve with penetrating oil before starting
    2) when compression piston, it is much easier to bleed the caliper while using the "special tool" -that way you are not forcing brake fluid back thru the system. -just into your waste brake fluid container -and arguably easier your on ABS and Master Cylinder.
    3) if in a Winter salt area -toss some anti-seize on the rotor hat- if you have alloys -so they don't get stuck on. -nothing like trying to change a wheel that won't come off.
    i agree with this. it is much easier to compress the piston while bleeding the valve at the same time....you're supposed to change your brake fluid every 2 years anyway, and with 2 years being the average lifespan of low end brake parts, it just makes sense to bleed them while changing them.........just make sure you bleed them properly (ie with a hose attached to the valve on one end and submerged in brake fluid on the other end) to make sure you dont end up with any air bubbles in your brake lines. seen too many career mechanics leave air bubbles because they thought they were good enough to bleed without the hose, and there's really no way to be certain the fluid you're purging doesnt have air bubbles without it passing through a clear hose so you can inspect it.
  13. Junior Member
    Jul 7th, 2012
    Chapel Hill, NC
    03 Ford Taurus, 01 VW GTI VR6
    03-13-2013 10:15 AM #118
    how much did you pay for said special tool, in the initial picture of the tools used it looks like you got a brake caliper piston retracting set i'd well imagine that was a pretty penny
    Engineer. Calm. Collected. German.
    Designated leader of B Squad for all lightning strike rescue ops
    01 GTI VR6
  14. n00b
    Aug 4th, 2012
    Central NJ
    2001 Jetta GLS 2.0 AZG
    04-27-2013 11:33 PM #119
    I just picked up the caliper tool at Harbor Freight today for $40. Great DIY from the OP, thank you! Also thanks to all those who posted additional helpful comments. Once all my hardware arrives next week, I'll be ready for battle thanks to everyone!
