Page 1 of 149 1 2 3 4 5 11 51 101 ... LastLast
Results 1 to 35 of 5215
Thread: What did you do to your passat today?
  1. Banned SoCal_GLI's Avatar
    Jun 21st, 2002
    07-26-2007 01:13 AM #1
    stolen from the MkII forum.
    today i installed my factory mudflaps...
    two days ago i had my ass handed to me by an Acura RSX
  2. 07-26-2007 01:31 AM #2
    I'll add my .02 I removed the passenger side axle and CV joint so I could remove the broken vibration damper.
  3. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    07-26-2007 07:22 AM #3
    Pretty much nothing, as I am a few thousand
    miles away from it now
  4. Member psst97's Avatar
    Jun 21st, 2006
    Louisville, KY
    2004 Passat TDI, 1997 Passat TDI, 95 Jetta VR, 91 Corrado VR,
    07-26-2007 12:49 PM #4
    looked over all of my vaccum hoses cause i have been hitting limp mode the past few days....
    Quote Originally Posted by upoo2
    its ok, wheels come and go. But RIMZ are FOREVER
    Quote Originally Posted by dano17
    So they moved the small passat section to fit the abundance of MKIV's that all look the same...
  5. 07-26-2007 01:00 PM #5
    washed her up real nice, and today adding some battery post shims to my sh!tty wal-mart battery.
  6. 07-26-2007 01:03 PM #6
    Quote, originally posted by arawak420 »
    if that doesnt do it for you, aluminium foil will do the trick.
    I p;ssed on my car today.
  7. 07-26-2007 01:24 PM #7
    i kicked mine several time after i just got done resolving the running issues and the heaterbox issue. only to find out that the drivers front claliper siezed... i dented the bottom of my trunk...
    if anyone wants a GLX passat with a slew of new parts it can be yours for 2700 bucks
  8. Member EazyEfromLI's Avatar
    Jul 14th, 2006
    Los Angeles, CA
    Lotus Elise, Ford Transit
    07-26-2007 04:08 PM #8
    drove it and kicked it where the front bumper SHOULD be.
    PizzaClub | DubHistoricalSociety | EXDUBHAUSNY | DVEDF
    Your Car Sucks
  9. 07-26-2007 05:09 PM #9
    Changed fan thermal-switch to a low temperature one. ordered bunches parts from http://www.autohausaz.com/ for weekend DIY job,espacially motor mounts.
  10. Banned SoCal_GLI's Avatar
    Jun 21st, 2002
    07-26-2007 08:34 PM #10
    washed mine real good today, tomorrow in detailing the interior, i have a show to attend on sunday
  11. 07-26-2007 09:16 PM #11
    installed P-chip(thanks Brad!), replaced cabin filter, and a quick wipe-down to shine it up
  12. 07-26-2007 11:59 PM #12
    installed a vacuume block and boost controller. Washed it too. Got gas also, it eats gas
  13. Banned SoCal_GLI's Avatar
    Jun 21st, 2002
    07-27-2007 12:02 AM #13
    Quote, originally posted by ACschnitzer23 »
    i bet it eats Mustangs too
  14. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    07-27-2007 12:22 AM #14
    Quote, originally posted by projects »
    Good choice
  15. 07-27-2007 11:36 PM #15
    got mine running with MSD 6a, MSD 8980 and a hot Bosch coil...so SCHWEEET! My daughters civic can rest now.
  16. Banned SoCal_GLI's Avatar
    Jun 21st, 2002
    07-27-2007 11:42 PM #16
    finished up the details for the most part, all i have left is the motor....
  17. Member SpaceHamster's Avatar
    Jul 26th, 2004
    Middletown, NY
    1996 VR6 Passat, 2003 1.8T Passat
    07-28-2007 01:23 AM #17
    Ordered Low Temp Thermostat kit, and new front left ABS sensor, and adjusted my coils
  18. 07-28-2007 02:38 PM #18
    beat the piss out of her like i do everyday
  19. 07-28-2007 04:46 PM #19
    Received parts from http://www.autohausaz.com/
    So I'll do some jobs:
    1.engine/tranny mounts.
    2.tranny filter and oil change.
    3.fan drive belt.
    4.install transmission cooler
    5. install a heat shield for abs brake system.
  20. 07-29-2007 12:54 PM #20
    I blew out one of my front 205/40/ZR17. So until my new tires come in for the front I am going JDM style running the stockers up front with some nice 17's in the back. I get a lot of thumbs up from the honda crowd
  21. 07-29-2007 01:34 PM #21
    drove to minni last week, today i cruised around with the girl, parked it in the garage
  22. Member stapleface's Avatar
    Nov 13th, 2005
    providence,RI/MA
    '95 VR GTI
    07-29-2007 07:52 PM #22
    woke up in the back of the wagon this morning
    NEK....PISS OFF
    R.I.P ALEXI
  23. Member Biff Tannen's Avatar
    Jan 24th, 2005
    Hill Valley, PA
    '97 Passat w/ V, '02 Jetta w/ T
    07-30-2007 11:23 AM #23
    VR6T and no pictures? How cruel...POST UP!
    I finally got my CEL fixed and I smoked a Civic
    Daily Driven
    Whatta you lookin at butthead
  24. Member Tomandante's Avatar
    Jan 30th, 2004
    Watsonville
    1993 VW Corrado VR6
    07-30-2007 11:42 AM #24
    I'd just stare at it every time I go outside to the driveway. Its been parked since April needing some suspension work.
    Sofa King uro
    C'mon man, you know that criticizing wheel size is the de facto way to show your mettle as an elitist car snob.
  25. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    07-30-2007 03:03 PM #25
    Quote, originally posted by DubPassatVR6 »
    http://forums.vwvortex.com/zerothread?id=3248943
  26. Member Biff Tannen's Avatar
    Jan 24th, 2005
    Hill Valley, PA
    07-30-2007 03:17 PM #26
    ehhh...very nice!!
    Daily Driven
  27. 07-30-2007 05:44 PM #27
    worked on installing the new air intake boot and started sanding the grill to put a wrinkle texture look on it.
  28. Banned SoCal_GLI's Avatar
    Jun 21st, 2002
    07-30-2007 07:57 PM #28
    today i finished for the mostpart cleaning my engine bay while we were slow at work. im gonna pull some stuff out of the wat to get it more detailed my next weekend off
  29. 07-30-2007 10:01 PM #29
    I pulled it out of the garage today so I could do an oil change on my S6
  30. 07-31-2007 12:10 PM #30
    well i thought about sitting in it but it smells like gas coz stupid me forgot to take the relay out and decided to roll down the windows ..reason is coz i undone the fuel lines from the tank coz the fuel pump needs work and didnt think of taking out the relay so when i turned it on the pump in the tank started and now my trunk is gas soaked ...bummer but oh well you live you learn...
  31. Member Biff Tannen's Avatar
    Jan 24th, 2005
    Hill Valley, PA
    07-31-2007 03:38 PM #31
    Filled her up with gas to the tune of $3.00/gallon. Friggin premium!
    Daily Driven
  32. 07-31-2007 04:07 PM #32
    the price you pay for premium, us canadians get regular... 87 oct , and then pay about 4 more cents
  33. 07-31-2007 04:19 PM #33
    deep clean of the paint (polish & wax) and change my replica's RS4 for a Borbet Rex8, both 17
  34. Member irockamk2gli's Avatar
    Jan 19th, 2007
    Portland OR
    2012 tdi golf 1998 gti
    07-31-2007 04:47 PM #34
    pulled all my damaged panals off only to find a bent frame rail......so yeah thinking about parting her out now
  35. 07-31-2007 04:50 PM #35
    haha how rude of me!
    Here are some recent pictures.
    Today I finished the timing belt change on my 03 Passat 1.8Turd
    Today also I put in a new fog light where my glass fell out and broke. Thanks Triple Seis!
    My engine is really cluttered, gonna clean it up some. Its pretty much all custom fabricated with the exception of C2 MAF and chip and Kinetic manifold.
    Modified by ACschnitzer23 at 4:52 PM 7-31-2007
