#4691
LUCKY YOU IFLY....
I WANT NEW BUMPER SKINS FOR MY CARS..
WELL ARE YOU GOING TO MAKE THIS HAPPEN ABOUT THE FRONT UNUSED GT SKIN? GREYHOUNF SEEMS TO BE THE WAY TO GET IT TO BUFFALO NEW YORK FOR ME.
I WILL HAVE TO PICK IT UP THERE AT THE BUS DEPO.
TRAFFIK; IS THAT THE LICENSE PLATE I SENT YOU? LOOKS GOOD AT NIGHT WITH THE EURO PLATE...![]()
#4692
#4693
Auto to 5 speed swap in my calypso wagon = complete! Also swapped out the disgusting grey interior for black after stripping and POR-15ing the floors. I can't wait to drive it again!
#4695
trying to do a ABS delete in my 94 b3 passat. anyone have some insight on doing this?? trying to get it done asap because my break master cylinder just went up and im not paying over $200 for a master cylinder lol... so anyways can someone help me out??
All the wheel gap in this thread scares me
you own a VW and nothing has ever broke???? WHAT!
#4696
http://forums.vwvortex.com/showthrea...1#post77580667
Procedure is the same. Don't freak out about a slightly spongy pedal, our cars don't have super tight brake pedals from the factory.
If you can, get your paws on a vacuum / pressure bleeder, specially since you're going to do this from a dry master. Bench bleeding is useless, but bleeding the entire system is a pain in the dick.
BTW I have some female to female SS front lines for sale if you want them. They'll most likely fit your car since they didn't fit mine (cutoff was mid-95 IIRC).
#4698
Hello!
I'm new here, so sorry if i posted in a wrong thread.
I have a question, if someone can help me.
How to lossen glass of a US position?
I want to make the black on inside. Like these ->
Thank you for your help!
#4699
Mike S.SacWater
'03 20th Anniversary - '96 GTI VR6
'91 B3 Variant - '76 Mk1 - '66 T3 Variant
*Duc*Duc*Hawk(GT)*
The Ranch Run - Wuste2012 "Cogito, ergo zoom!" RIP David E.
#4700
Just a generic 12v. I believe I did both of them off of the glovebox light.
#4701
the break peddle isnt spongy its stiff as a freakin brick. im hoping its the break master cylinder so im replacing it with one that is non ABS and pull all the ABS crap out and T the front line.. ill look more into this tomorrow and check back. wish me luck. really hope its not the break booster
"http://forums.vwvortex.com/showthrea...1#post77580667
BTW I have some female to female SS front lines for sale if you want them. They'll most likely fit your car since they didn't fit mine (cutoff was mid-95 IIRC)."
#4702
#4703
Well got the vrt running, but now my drivers side headlight and fogs wont work.. Any ideas? All the fuses are good so idk what is going on.![]()
#4704
I have twins again!
3 red B3 wagons in 3 years!
#4705
#4706
got a new ABS, break booster, and break master cylinder (used but working) for $20going on tomorrow hopefully tomorrow. next weekend timing chains, guides, head gasket, rear main seal and water pump... going to be running like a CHAMP!
picking up leather MOMO rep front seats for trade for a stock VR headfair trade right? lol
body work starts in the next 2 weeks and will be ready for the bedliner paint job!
false floor goes in tomorrow along with the 15inch woffer, custom box and JL amp. progress on this B3 is coming along very well..... now to find some wheels i like that are with in my budget... ideas??![]()
#4707
*brake
#4708
Looked what just showed up from germany.
Now only if someone could find me some damn tailllights and textured rub strips
#4709
Steering wheel is meh. The mirror though - I can't live without mine, had it for many years
on the B3, and when the car was wrecked I put the whole mirrors on my MK2 so still using it now.
#4710
Discovered why my condenser was leaking...
...and it also appears someone R² this condenser before I got to it.
#4712
installed a new radiator, runs cooler. Bought interior parts to install later!
#4713
#4714
#4715
#4716
I was thinking the same thing. I have those on both sides of my 20th & plan on doing the same thing to my Mk3 when I get the cabby mirrors swapped on.
Mike S.SacWater
*Duc*Duc*Hawk(GT)*
#4717
#4718
Finally got the Bilstein shocks and H&R springs installed. Lower 40mm all around, and some adjustable camper-screws to finish it off![]()
#4719
#4720
#4721
#4722
Just sent my minty-fresh used front bumper off to paint. Waiting till Friday is gonna be sooo tough...
Rear one will go off once I work the kink out of the corner.![]()
Mike S.SacWater
*Duc*Duc*Hawk(GT)*
#4723
Media-blasted and painted most of the syncro rear-end stuff, removed the various brackets from the syncro parts car to transfer to my wagon, ordered a bunch of parts from Volkswagen for the drivetrain rebuild, and starting working on making the rear control arms fully camber/toe adjustable.
I still need to order the syncro-specific KW V2s... I want this done for WaterWerks on the Bay!![]()
#4724
Thought about finally fixing my cruise control. Then thought about all the vac wiring that's rotting away inside my driver's left fender. Then though about the shaved bay cabrio I want to build in the future.
**** this, deleting cruise control too.
#4725
Bunch of work on the rear suspension: all new rubber and steel brake lines, new proportioning valve, wheel bearings, rotors, pads, control arm bushings, and rear input and axle shaft seals. Also got parts for the camber/toe adjustment machined and ready to weld on tomorrow.![]()
