You need to fix that wiring loomHow long did it take you to do the timing belt?
I did mine (A4 B5) for a day and a half, with a lot of breaks.
It's an ATW motor though.
#36
Well I thought about starting to part it out, but its too hot today.
#37
#38
located my oil leak that just started two weeks ago....looks like the oil sending unit....lets just hope thats all it is
#39
Quote, originally posted by izzo » You need to fix that wiring loom How long did it take you to do the timing belt?
It's an ATW motor though.Really not that long, About 5hrs of continous work. I changed timing belt and h20 pump, and coolant, spark plugs and air filter and oil change. I changed all the accessory belts too. The hardest part was getting the timing belt on all the gears without throwing anything out of alignment. I could probibly do it un 3hrs or less now that I am familiar with the setup and the procedure to slide the lock carrier forward. I also found that I had a busted water pump impeller and luckily I got the upgraded pump with the metal impeller. Heres the pic
#40
replacing the master cylinder/abs unit...![]()
'i wonder what will go wrong next.
#41
Quote, originally posted by ACschnitzer23 » haha how rude of me!
Here are some recent pictures.Today I finished the timing belt change on my 03 Passat 1.8Turd
Today also I put in a new fog light where my glass fell out and broke. Thanks Triple Seis!My engine is really cluttered, gonna clean it up some. Its pretty much all custom fabricated with the exception of C2 MAF and chip and Kinetic manifold.
Modified by ACschnitzer23 at 4:52 PM 7-31-2007Great Success!!!!
What kind of power are you putting down now? What turbo did you use? How much? So many questions, I must know!!!
Daily Driven
Whatta you lookin at butthead
#42
here are my specs:Garrett T3/T4 60. trim with .58a/r turbine
Kinetic turbo manifold
TiAl 38mm wastegate, custom dump tube (LOUD)
custom 2.5" intercooler piping
ebay Front Mount Intercooler 3" inlet and outlet
C2 36# OBDI software and Bosch 36# injectors
Devils own Alcohol/Methanol injection kit, with boost activated switch
Audi TT diverter valve recirculated
2.5" Stainless Techtonics exhaust (for sale shortly, going 3" turbo back)
manual boost controller
vacuume block.
VDO gauges and Innovative wideband o2Current setup is running 10lbs of boost on stock compression. I will turn it up to 12psi in the fall when temps drop a bit!
Modified by ACschnitzer23 at 12:56 PM 8-1-2007
#43
PM'd for more info
Modified by DubPassatVR6 at 1:43 PM 8-1-2007
Daily Driven
#44
waxed my b*tch today, if i had my camera at work i woulda snapped a pic
#45
tore the front clip off so i can switch to g12 its been a long time coming and then i can also replace the leaky switches on top of the oil filter and then maybe i might do the rear brakes who knows i might even get to radio after that then she should be good for a while. good thing my dad is nice enough to lend me a car to get back and forth to work although i should have the bug fixed too![]()
so much work not enough light or time in the day
#46
it is now done and still have the radio left but it runs smoother i think![]()
#47
took off the fuel pump..the one under the car.....geez i got all greasy but it was fun.![]()
#48
Doin a cylinder head, becasue the old on has bad valve seals.![]()
#49
Dreamed about it sitting on the opposite coast... planning front end overhaul soon...
#50
Changed brake pads both front and rear. Flushed the brake fliud while I was there.
#51
put a bumper on it, used peanut oil on the textured moulding and it looks brand new.
#52
Wow, five hours? Have you done it before?
It took me a lot more than that, but I had no clue what I was doing
Got the kit from ECS - all belts, water pump, thermostat, and also did a coolant flush.Where did the piece of the water pump impeller go?
Here's a photo of when I did mine:
#53
first time on a 1.8t, i had done them on old 8valves. I had a bentley too. I am not sure on audi, but on the B5 Passats all you do is remove the bumper cover, and then there are 8 torx bolts holding the lock carrier. they come out easy with an cordless impact, then the whole carrier slides forward and your good to go.
#54
Same thing here, the lock carrier slides out of the way. I used a DIY from AudiWorld - was a great help. It is MUCH easier when the motor is NOT transversely mounted.
#55
Got lumped in with B5s at VAG fair in York, PA, and took home 1st place. B5 what?![]()
Daily Driven
#56
i started shaving my bumper last night and i will probably work on it a bit today...
here it is 5 hrs into the projectstill have to re shape the line and do some more filler work and spray high build prime ...should get all that done today(if i dont get lazy)
"Build it for fun"
"Buy art...Not cocaine!"
#57
I understand there is no need for fog lights, but where do you put the turn signals when you shave the front? I'd love to do it on my B4, but I don't know where to put my turn signals so that it doesn't look stupid
Daily Driven
#58
Quote, originally posted by DubPassatVR6 » I understand there is no need for fog lights, but where do you put the turn signals when you shave the front? I'd love to do it on my B4, but I don't know where to put my turn signals so that it doesn't look stupid the corner lamps is where i will have mine...they will only blink...and the city lights in the e-codes will be my parking lights...
"Build it for fun"
#59
washed my motor....and parked it...waitin forpartin
Modified by lilDevil at 5:12 PM 8-6-2007
#60
Quote, originally posted by drifter_xero02 » i started shaving my bumper last night and i will probably work on it a bit today...
I like evrything that's shaved and debadged![]()
#61
I like how its all shaved it is going to look very good. I only have one question how will you take the bumper off if you cant pop the fake light out to get to the mount bolts now that you have shaved it? did you cut a part out behind the bumper so you can get to them? I want to do the same this has just always been my concern
#62
Quote, originally posted by irockamk2gli » I like how its all shaved it is going to look very good. I only have one question how will you take the bumper off if you cant pop the fake light out to get to the mount bolts now that you have shaved it? did you cut a part out behind the bumper so you can get to them? I want to do the same this has just always been my concern x2
Daily Driven
#63
well...the 2 13mm bolts that hold the re-bar to the frame...are covered uo now yes but if you shimmy your hand around you can reach them from th underside...not to say it did not take me 30 minutes to get the bumper on or anything but it isn't that bad...or you can take the slides that go into the frame rails out(kinda like a mk2)
but the front crossmember will drop and it will be more of a biotch to put back than the way i did it
"Build it for fun"
#64
I think I will stay unshaved because I am going to need a new radiator at some point (there is a leak in mine that has a temporary seal on it) and I don't feel like having more of a b*tch of a time then I normally would!![]()
Daily Driven
#65
shaved off rear passat tag, lovin how it looks, I will post pics soon
#68
Quote, originally posted by babydaddy » just chiming in to get suscribed.
Nothing.![]()
You can use this, you know:
At the top, right-hand side![]()
#69
Quote, originally posted by izzo » You can use this, you know:
lol holy7 crap never ever saw that before.You have no idea how many threads I've posted in just to watch them
#70
Don't sweat it, it's a +1 for your post count![]()
