Alright, I'm having issues with my VR. I have the 55lb injectors in for prepping to turbo it, but I'm hitting some snags. I'm using the hi-res code also, but other than the fuel and code, everything was setup the same as need_a_vr6.Now on to my problems. I switched the req_fuel to ~5.2 but have been playing with it. My Wideband seems to be reading rather erratically and I noticed my PW1 was exactly half of PW2.
When its running, the engine vibrates a lot, and has a loud clanking noise from the rear bank. I'm thinking that the engine is running very lean on bank 1 and very rich on bank 2, and the difference in power balance is the cause. Does this sound about right? If so, what would cause the difference in pw?
On to timing. I started off running the same spark settings as shown, but it would backfire through the intake occasionally on failed startups. I started playing with the trim angle, and it seems to start the quickest/run the smoothest at approx 32* advance trim.
Also, my wideband is reading differently from the display to the MS, I'm using JAW and have the MS set for LC1 while using the OUTPUT 1 on the JAW. I think Beav might be able to help me with this.
Any help would be greatly appreciated, as I need to work everything out in about 3 weeks to drive it 800 miles back to NE.
Thanks guys.
