Well I found the trunk release...
#1
I work at a VW dealer and one of the porters came to me to figure out how to charge a 3.2 Eos. Now im usually the one to come to as far as product knowledge at the dealership but this one im not sure about. Im not even sure where the battery on a 3.2 is located. I know how to jump the car using the positive terminal under the hood but I cant see this working to charge the vehicle due to there not being a negative terminal to make a loop. The top is also down so I dont know if that makes a difference being the battery is probably in the trunk. Is there a manual trunk release hiddin like in some of the other cars?
ex's:'12 GLI | '12 Jetta SEL | '11 Jetta SE | '10 GTI | 09 Jetta TDI | 09 Tiguan | 08 2Dr GTI | 07 4Dr. GTI | 07 Passat pkg2 Sport, 6spd | 07 Jetta | 06 Audi A3 | 05 GTI | 05 GLI
#2
#3
I don't mean to sound like a smart ass, but isn't there an owners manual with car?I would think it would provide some insight on charging the battery.
Kevin
#4
The owners manual says bring the car to an authorized dealer lol.
#5
Talked to a tech, said theres two 6volt gel batteries on either side of the trunk (tops down so that doesnt help.) but also that he thinks the batteries cant be charged. The cars on the showroom. I guess the only option is jump it with the positive terminal under the hood and drive it till it charges.
#6
Yes the charger would go on the positive terminal under the hood and the negative to a good solid (unpainted) spot on the frame or engine block. The frame is your return path to close the loop. I know I saw mention of this in the owners manual. If there is a suggestion in the manual to take the car to dealer for a jump start is useless information. How is it supposed to get there? Perhaps they suggest that for replacing the battery??
#7
I have no clue why it says bring the car to the dealer to charge the battery. I ended up just jump starting the car and pulling it off the show room and drove it around for a while. Talked to a different tech and he said the same thing, just ground it to the frame and it will close the loop. However now the mfd is saying the door is open, and even better its saying the back door is open. Obviously an eos doesnt have a back door. I put it in service im sure all it needs is to be reset after the battery going dead.
#8
Quote, originally posted by SpoolinFSI » The owners manual says bring the car to an authorized dealer lol. That's hilarious.... Guess you've got that covered
Kevin
#9
Quote, originally posted by SpoolinFSI » I have no clue why it says bring the car to the dealer to charge the battery. I ended up just jump starting the car and pulling it off the show room and drove it around for a while...... There is an oblivious advantage to this service technique. Nothing like a nice long top down cruise as part of your work day.
Kevin
#10
Quote, originally posted by SpoolinFSI » I work at a VW dealer and one of the porters came to me to figure out how to charge a 3.2 Eos. Now im usually the one to come to as far as product knowledge at the dealership but this one im not sure about. Im not even sure where the battery on a 3.2 is located. I know how to jump the car using the positive terminal under the hood but I cant see this working to charge the vehicle due to there not being a negative terminal to make a loop. The top is also down so I dont know if that makes a difference being the battery is probably in the trunk. Is there a manual trunk release hiddin like in some of the other cars? Do you have any of the solar chargers laying around? They might work for a trickle charge?
#11
There is a thread on this in the FAQhttp://forums.vwvortex.com/zerothread?id=2982042
It includes a TB on care of the batteries in the 3.2..
-Mark
#12
That's interesting that the manual does not recommend charging the battery from under the hood. I'm curious why. The auxiliary battery terminal must be able to handle high currents for jump starting and the alternator, which is under the hood charges the batteries?Another question pertaining to jump starting. With the DSG transmission does anyone know if you are able to push start the car like you can with a manual?
#13
How would you 'pop' the clutch...
#14
Roll the car in neutral and then pop in drive? It doesn't sound good but I don't remember seeing a warning against this off the top of my head. I know I've seen warnings in other owners manual against trying to push start an automatic. With all the warnings in the Eos manual I don't remember seeing one about this? Has anyone else?Regardless, I always carry a set of jumper cables in the trunk for the unexpected dead battery. In fact, I was able to snake my jumper cable perfectly around the spare tire in the Eos trunk well.
#15
Quote, originally posted by just4fun » There is an oblivious advantage to this service technique. Nothing like a nice long top down cruise as part of your work day.
Kevin
Yeah I definetly wasnt complaining when I came up with my charging technique. Nice hour long top down ride in a loaded 3.2 in florda never hurts.
#16
If the battery was flat would their be enought power to operate the clutch even if you moved the stick into drive. I'm certainly not going to be the first to try this one..
#17
Nor I, and I would bet the computer would not allow the clutch to engage if it knows the engine is not running.
#18
Quote, originally posted by solarflare » Roll the car in neutral and then pop in drive? It doesn't sound good but I don't remember seeing a warning against this off the top of my head. I know I've seen warnings in other owners manual against trying to push start an automatic. With all the warnings in the Eos manual I don't remember seeing one about this? Has anyone else? Regardless, I always carry a set of jumper cables in the trunk for the unexpected dead battery. In fact, I was able to snake my jumper cable perfectly around the spare tire in the Eos trunk well.
I would not reccommend it... I do not know what will happen but I am willing to bet it is bad. DSG is still an automatic. There is no clutch to manually release. It is all computer controlled... so if the car is off how do you suggest we engage the clutch?
