Page 4 of 4 FirstFirst 1 2 3 4
Results 106 to 124 of 124
Thread: Wii Remote Measurements
  1. Member Lidberg's Avatar
    Nov 20th, 2004
    Minneapolis
    Audi B7S4Q6MT
    08-03-2007 06:57 PM #106
    PM replied to with hosting info.
    .:Christian:.
  2. 08-12-2007 06:15 AM #107
    As long as the thing samples fast enough and its A/D converter has enough steps, then accuracy only comes down to calibrating the thing.
    Until reading this post I didn't know what a Wii was, but I've formed an idea from all the discussion. As a games device it would have to have reasonable resolution or it would be annoying to use in a game. (I also never play computer games btw). +/- 20% accuracy has been mentioned. That may be so, but I'm pretty sure it would be consistent and linear - that is the nature of electronic devices. For a cheap item that is just for games, it doesn't matter if it is 20% different than another one in the shop, as long as it is consistent and smooth.
    Calibration couldn't be easier - while hooked up and recording as per klee's instructions, just hold it level on its base (ie, rest it on the kitchen table) for a few seconds, then repeat for face down, left edge down, right edge down, nose down and bum down. Each time you are applying 1G or -1G. You can then compare this to your saved data in Excel and work out the appropriate corrections.
    For a correction factor (one you multiply) you compare LEFT minus RIGHT to 2G. For a zero correction (one you add or subtract) you compare LEFT plus RIGHT to 0G.
    I know I am telling some people how to suck eggs and others won't know what's going on, but hopefully this is useful for someone. Maybe klee can incorporate the calibrations into his/her spreadheet.
    PS I found this post via http://www.autospeed.com.au. I used to read the 16V forum religously - that's why I could log in to respond.
    - Rick
  3. 04-06-2008 04:25 PM #108
    HI,
    thats pretty awesome dude, first thing i did after reading it was go out and buy a bluetooth thingy.
    I set it all up..
    Everything works perfectly =D
    But i have a few questions...
    Why do you multiply the var.t thing by 86400?
    and when i leave my wiimote still it has a reading of 1.10 on the y axis, yet i thought it should be 1, would there be a way to add an offset so that it made it into 1 or is it right how it is now?
    Thanks
  4. 04-06-2008 04:34 PM #109
    86400sec/day.
    in excel you can just subtract 0.1 from the y axis column.
  5. 04-06-2008 04:41 PM #110
    Pretty impressive!
  6. Member blowjustinup's Avatar
    Jun 8th, 2007
    West Haven, CT
    2003 20th Anniversary Edition GTI
    04-06-2008 04:57 PM #111
    Is it just me or does the m3's 0-60 time seem off.. 6.7 seconds?
  7. Member GENERAL-LEE's Avatar
    Sep 11th, 2006
    Milf-town, MA
    Tropic gti and a ford
    04-06-2008 05:13 PM #112
    absolutely ridiculous...mad props
  8. Banned friday's Avatar
    Dec 8th, 2007
    04-06-2008 05:25 PM #113
    Wii motes are going to cure cancer and aids.
  9. Junior Member grink's Avatar
    May 17th, 2007
    Brooklyn, NY
    2006 VW Jetta 2.5
    04-07-2008 11:55 AM #114
    I just found a use for my extra wiimote. I am going to play with this tonight when I get home.
    I wonder if you attached the nunchuk and averaged the two you would get a more accurate reading...
    Modified by grink at 9:16 AM 4-7-2008
  10. 04-07-2008 06:03 PM #115
    OutputToFile() Method...
    If you use this method in your GlovePIE code and you run the program multiple times within one sitting, the data keeps adding on to the output.txt file (so you will have a file that has all the runs that you did). Is there any method that will erase the previous data once you press "run" so that the data does not get added on?
  11. 05-19-2008 09:27 AM #116
    Since output.txt is a text file open the file using notepad. Select All [CTRL A] then press DEL. Save the file and quit. The file is empty.
    Or read the glovepie documentation and figure out how to erase an existing file.
    http://www.wiili.org/index.php...ripts
    Somebody is going to have to do it why not you?
    Just through that in because it seems nobody really wants to read.
    RTFM http://en.wikipedia.org/wiki/RTFM
    The guy who started the post put in his time and effort so why just copy?
  12. Junior Member BlkBullitt's Avatar
    Feb 10th, 2008
    Cleveland, OH
    1998 Audi A4 2.8 Quattro
    08-15-2008 07:39 AM #117
    Hmmmm....
    *looks at his new PS3 Dual Shock 3 controller*
  13. Member VWRulez's Avatar
    May 27th, 2003
    Shanghai
    86 Golf, 90 Corrado, 88 & 91 GLI, 91 MR2T
    08-15-2008 08:27 AM #118
    that's awesome
  14. 02-10-2010 05:54 AM #119
    Hello,
    This is awesome I want to do it also. I bought a wii remote. But i am unable to know if glovepie detected the wiimote or not ? In the output file, first column is time, but all I see is zeros in the last three columns.
    Please if anyone has a step by step procedure..please send me. I want to really try this.
    thanks
  15. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    Jahre ABF, A4 B6, R6
    02-10-2010 06:34 AM #120
    Dynolicious for iPhone works pretty good, if you don't want to do this, and you have an iPhone, iPod touch
    http://dynolicious.com/
    Quote Originally Posted by dankvwguy
    They toed my car to the toe yard
    THE CBOX KREW ----Mk3 16V club--------www.AWOL.tv---- STANCE|WORKS
  16. Member WhitePoloCT's Avatar
    Jul 28th, 2005
    Cape Town WC South Africa
    '99 Cabrio, '05 S2000
    02-10-2010 07:23 AM #121
    Quote, originally posted by Swizz!! »
    All the smart in this thread made my head asplode
    and with that i own page 4
    Not quite...
    Let's just say I like my women like I like my cars - fast, cheap, kinda ugly and beaten up, unreliable, dangerous, unwanted....
    4 coilpacks, 2 gearboxes and counting...
  17. Member Tj_gti's Avatar
    Sep 1st, 2009
    York Pa
    09 Wrx Hatchback
    02-10-2010 07:29 AM #122
    Clever
  18. 02-10-2010 07:43 AM #123
    If you need any help with the math/software/hardware/calibration issues let me know. I'm a navigation engineer.
    The best thing you can do with a low-grade accel is constantly calibrate it when you're stopped. If you can have some software to zero it out when you stop, you'll be all set
  19. Member Benjamin.'s Avatar
    Nov 12th, 2001
    Hanover, PA
    09 Fit Sport, 03 Miata Shinsen, 03 Jetta TDI Wagon
    02-10-2010 09:37 AM #124
    Quote, originally posted by WhitePoloCT »
    Not quite...
    He probably did at some point before someone deleted their post.
