Page 25 of 26 FirstFirst ... 15 21 22 23 24 25 26 LastLast
Results 841 to 875 of 893
Thread: Ask a VW Parts Guy....Passat Edition
    Feb 13th, 2009
    Ontario
    2007 2.0T, 6MT, shadow blue Passat wagon
    04-10-2012 08:07 PM #841
    I need a grab rail for my 07 Passat wagon, part number 1T0-827-547-L.
    Any help? Local stealership is charging $160. Obviously looking to find one for less.
    Feb 18th, 2002
    Bel Air, MD
    2010 Passat
    04-18-2012 12:11 PM #842
    I have a question -
    I have a 2010 Passat with the 6sp DSG transmission
    I was reading about the DSG transmissions, and it looks like they came in two flavors - the 09G and 09M
    From what I can find, the 09G is what my Passat has, curiously, the specs say that the 09G is rated to only 184 lbs-Ft. of torque whereas my car comes stock with 207
    Is this wrong, right or am I way off. I checked my code sheet and don't see anything stating a 09G or 09M. I'm guessing it's the D6F code. If so, what are the specs of that transmission.
    Thanks
    2010 Passat Comfort
    Full Vag-Com Service for
  3. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    04-19-2012 07:40 AM #843
    Quote Originally Posted by rookie View Post
    I have a question -
    Thanks
    You actually have an 02E transmission....I dont have anything in my parts catalog to say the specs. Ill look around and see what I can find
    -Adam-U of M Tigers Wings Lions Seattle Sounders Seattle Supersonics
    Checkered Flag Volkswagen Virginia Beach Virginia
    1-800-277-2122 ext: 4788 or 757-687-3465
    Email Me: adam.meyers@checkeredflag.com
  4. Member
    Feb 18th, 2002
    Bel Air, MD
    2010 Passat
    04-19-2012 09:13 AM #844
    Okay -02E tells me alot
    Max torque of 350 NM (258 ft-lbs.)
    Unbelievably complete pdf at:
    http://www.evosoft.dk/diagrams/DSG_02E.pdf
    2010 Passat Comfort
  5. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    04-19-2012 09:29 AM #845
    good stuff
  6. Member
    Feb 18th, 2002
    Bel Air, MD
    2010 Passat
    04-19-2012 10:57 AM #846
    I know this would be a pain, but is there any way to decode that options code sheet?
    Damn, which one even says what color paint I have?
    Also - trying to figure which fuse is my fuel flap and what else is on that circuit.
    I keep getting a "Short to ground" code when I push my fuel flap button.
    I bought a new actuator, but it didn't help.
    It must be something else on that circuit as if it was a true "short" - it would be blowing the fuse. Instead it just doesn't work and throws a code. I've made a couple mods and have tried disconnecting them all, but nothing seems make a difference. The switch is fine and I've even traced the wires thru the transmission tunnel and haven't found a thing.
    Thanks again - you are a wealth of knowledge and a great contributor to the Tex
    2010 Passat Comfort
  7. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    2008 Passat 2.0T TSI; 2005 Scion xB
    04-19-2012 11:37 AM #847
    Greetings Parts guys!
    I have a request, I may need to buy a few body panels...
    Right & Left Sides for these:
    Turn Signal 'housing' the body/fiberglass/whatever that the turn signal sits inside of...
    The body piece that sits next to the turn signal, a strange bump out that on my model does not look like it is a formed part of the bumper (heard that later models have this fused with the bumper)...
    Appreciate the help!
    2008 Passat 2.0T TSI - Unitronic Stage 1+ / BSH True Seal Intake Stage 2 / AWE Diverter Valve / 42DD Boost Tap / MKV MFSW with Paddles / Driver Gear Springs & Koni FSD / Euro Spec F/R Turn Signals
  8. Junior Member
    Jul 26th, 2011
    SF peninsula
    08 Passat 3.6 4motion wagon
    04-22-2012 03:47 PM #848
    Hows it going parts guys,
    I broke the oil filter housing on my 08 3.6 4motion. Do you know the part # for this?
    thanks!
  9. Member nodashi's Avatar
    Mar 20th, 2012
    Whidbey Island, WA
    2006 FSI 2.0t Passat
    04-22-2012 05:35 PM #849
    looking for a aluminum dash trim where can i get one of those?
  10. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    04-25-2012 09:12 AM #850
    Quote Originally Posted by mtnryder View Post
    thanks!
    071-115-433
  11. Member
    Feb 13th, 2009
    Ontario
    04-25-2012 10:37 AM #851
    Quote Originally Posted by JohnEcanuck View Post
    Anyone?
  12. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    04-25-2012 10:55 AM #852
    Anyone?
    The part number is no good....shoot me your vin Ill get you a price on it
  13. 04-26-2012 08:50 AM #853
    Quote Originally Posted by nodashi View Post
    You should consider wrapping with 3M vinyl.
  14. 04-26-2012 12:48 PM #854
    Any chance I could get a part number for a non tow hook hole lower rear valance (the black texture bit at the bottom of the back bumper) and the the part number for the same part on an r line Passat.
    Thanks
  15. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    04-27-2012 10:20 AM #855
    Quote Originally Posted by coderedcomputing View Post
    Found a bit more info if this helps:
    http://www.jimellisvwparts.com/showA...front%20bumper
    On the diagram listed above, I'm looking for part #37 and #40 but can't find much info about them... any ideas?
    Thanks!
  16. Member
    Dec 24th, 2011
    Belleair, Florida
    2006 Volkswagen Passat
    05-02-2012 07:05 PM #856
    Can someone give me a link to somewhere I can get the updated fuel cap from? Or even a part number would be great. I tried searching and even ECS didn't have what I was told to be the revised cap...the one ending in "G." Thanks
    2006 Passat FSI 2.0T | Forge DV Spacer | 17" Monte Carlo Wheels | 10" Kicker sub in custom box | iPad Mini Dash installed as headunit | 5% Tint on sides, 30% on back window | Carbon fiber mirrors | Votex Roof Rack | Resonator Delete w/ Magnaflow tips | Badgeless grill | OEM Audi S6 LED DRLs | Lip spoiler
  17. Member Born²VW's Avatar
    Jan 28th, 2012
    CT
    07 VW B6 4Mo Sedan
    05-03-2012 12:23 AM #857
    I have an 07 4mo
    I am installing Neuspeed sport springs soon. Maybe tomorrow.
    I have the replacement bolts install kit.
    Anything else critical to replace when doing this install?
    I have read about a bushing or barring that might need to be replaced.
    Can you give me part numbers and names please?
    And classify it's importance of being replaced? (scale 1-10)
    Thank you.
  18. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    05-03-2012 07:43 AM #858
    Quote Originally Posted by Juniorfeel View Post
    It is actually revised further to 3C0-201-550-N, I have one in stock, $16.50 plus shipping. Give me a call if you would like to order
  19. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    05-03-2012 07:48 AM #859
    Quote Originally Posted by Born²VW View Post
    I have an 07 4mo
    Thank you.
    I would do the front strut mounts and bearings while you have them off:
    1K0-412-331-B x2 (Strut Mounts)
    6N0-412-249-C x2 (Bearings)
    As long as you have the bolt kits I believe thats all you will need
  20. Member Born²VW's Avatar
    Jan 28th, 2012
    CT
    07 VW B6 4Mo Sedan
    05-03-2012 08:35 AM #860
    Thank you.
  21. Member GR8FL DAD's Avatar
    May 9th, 2010
    08 B6 TSI M/T
    05-04-2012 02:07 PM #861
    Quote Originally Posted by Adam@CheckeredFlagVW View Post
    3c0-854-939-a-9b9 cover - $32.44
    3c0-854-940-a-9b9 cover - $32.44
    3c0-854-949-a-9b9 cover - $28.31
    3c0-854-950-a-9b9 cover - $28.31
    I do have to order these. just give me a call if you would like to order
    I may be interested in purchasing these pieces as well. I just painted and installed votex sides and would like to color match the lower doors.
    Do you know how they attach? I have read some different threads talking about having to modify the tabs on the front door pieces to make them fit and that you have to then put them on with adhesive tape. I have a late 08 TSI Passat if that makes any difference.
  22. Member vw_nc_dude's Avatar
    Jan 29th, 2012
    North Carolina, USA
    2012 Tiguan 2.0 TSI, 2008 Passat 2.0T FSI
    05-04-2012 02:21 PM #862
    I have a question:
    I ordered the below OEM 4-spoke leather steering wheel for my 2008 Passat. When installing this in my car, I will not use the multifunction buttons on the left and right side of the wheel. Are there any plastic inserts for these spots if I want to take these buttons out?
  23. Member MDAce15's Avatar
    Aug 10th, 2010
    NYC
    07 3.6 4Motion Wagon
    05-23-2012 02:39 PM #863
    Can you tell me the part number for the oil dipstick on an 07 3.6 Passat? Thanks. I think I may have the wrong one...
  24. Member
    Sep 17th, 2007
    PA
    '07 Passat Wagon
    05-25-2012 10:09 AM #864
    Can someone confirm if the following part number (steering wheel control module) supports MFSW?
    3C0-953-549-N
    It's not listed on the Ross-Tech site: http://wiki.ross-tech.com/wiki/index...er_3C0-953-549
    I've got a VAG-COM/VCDS in Central PA, PM me if you need help. Micro-CAN (USB).
  25. Banner Advertiser Adam@CheckeredFlagVW's Avatar
    Apr 22nd, 2011
    Virginia Beach
    2012 Jetta
    05-25-2012 10:47 AM #865
    Quote Originally Posted by mdace15 View Post
    can you tell me the part number for the oil dipstick on an 07 3.6 passat? Thanks. I think i may have the wrong one...
    03h-115-607-c
  26. Member MDAce15's Avatar
    Aug 10th, 2010
    NYC
    05-26-2012 12:27 AM #866
    03h-115-607-c
    Thanks a lot! Much appreciated.
  27. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    06-12-2012 09:18 AM #867
    Can any of you parts guys confirm for me what part these are:
    ZSB 3C5.945.095 C
    ZSB 3C5.945.096 C
    Trying to see if these are standard USD or if they are the EU ones with amber turn LEDs.
    Gracias!
  28. Member
    Mar 28th, 2007
    iowa
    07 uni black rabbit
    06-26-2012 02:26 AM #868
    kind of a mkv/b6 mash-up question...
    i'm planning on driving my parking brake via linear actuator and want to hack the passat center console into my rabbit. it appears that the climate controls roughly line up and i can feel the passat mount holes beneath the carpet along the side of the center hump. are there different passat-specific braces beneath the ashtray area to help support the console? part #'s or pics would be very helpful.
    EDIT: looks like the part #s i need are the left/right/center retaining brackets from the passat front console.
  29. Member BPhillipsGLI's Avatar
    Oct 6th, 2004
    NC
    04 Jetta GLI, 07 Passat 2.0T
    07-18-2012 08:13 AM #869
    Does anyone have a part number for the OEM Chrome roof rails that come on the 3.6 4mo VW Passat wagon, as well as a price? Thanks.
  30. Junior Member
    Jan 22nd, 2012
    NE PA NJ Area
    08 B6 Passat
    07-18-2012 10:30 AM #870
    Do the Side mirrors on a 08 Passat snap into the mirror housing or are they stuck with an adhesive backing?
  31. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    07-18-2012 10:39 AM #871
    Quote Originally Posted by chris.betsch View Post
    They snap in, check this link from ECS it has a video on there for the replacement of the mirrors:
    http://www.ecstuning.com/Volkswagen-..._BIS_ES252586/
  32. Member jachong's Avatar
    Mar 16th, 2008
    B'more, MD
    '08 B6, '93 Cabby, '84 GLI, '75 Brasilia
    07-24-2012 07:02 PM #872
    Anyone has a Votex front lip on stock? If so, please msg me.
    Thank you very much!
    ~ja
  33. Semi-n00b
    Jul 8th, 2012
    2008 3.6 Passat 4motion
    07-26-2012 03:28 PM #873
    I'm going to change the Haldex and differentials fluids in my 2008 Passat, 3.6L, 4motion. I need drain and fill plugs for both front and rear diffs and the Haldex. I also need the Haldex oil filter. I'm assuming that the plugs come with gaskets/seals. I do not have part numbers. I'd like to get these ordered as soon as possible. Can anyone help me out? Thanks.
  34. Junior Member miki2006's Avatar
    Jun 18th, 2010
    Long Island, New York
    VW Passat B6 2006
    07-27-2012 10:13 AM #874
    Hello to all part guys !!! I just need a little help trying to find out which is the right part number of a multifunction airbag harness with double stage bag, mycar is a b6 2.0t 2006. The #'s are:
    1k0 971 584 or 1C0 971 584, the one 1c0971585B is for single stage airbag. I haven't buy yet the control module which is the 3C0-953-549-AH* so can anyone give a quote of harness and module + shipping to 11746.
    Thanks
  35. Member
    Mar 3rd, 2010
    Montclair NJ
    2008 Passat "Komfort"
    08-02-2012 02:42 PM #875
    Hey, do u know if i am able to swap out my frame with another b6 passat frame? also do you know if the engine bay frame is removable by itself? i was informed that it is a bolt on frame, does that mean if my engine bay frame is bent, i can replace just that part of the frame?
