VWVortex.com - higheest milliage?
    Page 13 of 21 FirstFirst ... 391011121314151617 ... LastLast
    Results 301 to 325 of 522
    Thread: higheest milliage?
    1. Junior Member
      Jul 22nd, 2010
      Va
      03 24v BORA
      07-25-2010 11:09 PM #301
      120150.....got it a little over a year ago with 95000
    2. Member Emron's Avatar
      Mar 27th, 2007
      Miami, FL
      2004 GTI Swapped to R32
      07-27-2010 01:48 PM #302
      Quote Originally Posted by Emron View Post
      I bought it at 22,900 Feb. 2007. I'm at 45,500 as of now.-Emron
      I'm at 75,864 now.
      I haven't had any issues yet.
      I've never had a check engine light that wasn't directly caused by me.
      I've done some preventive maintenance--spark plugs a couple times, coilpacks, fuel filter, air filter, oil changes, transmission fluid changes, and MAF cleaning.
    3. Member Ld7w_VR's Avatar
      Apr 21st, 2006
      Fairfax, VA
      2003 Gti, 2001 Wolfsburg
      09-03-2010 05:33 PM #303
      At 99,331 as of now. Almost to the big 100,000.
      The Elite 24v VR6 Club: Member #268 "Like 6 cylinder of 15 degree sex"
      (_fishbowl society_)
    4. Member
      Apr 7th, 2007
      College Station, TX
      2003 Jetta GLI, 1966 Bug, 2008 Rabbit
      09-03-2010 05:55 PM #304
      Quote Originally Posted by brad44 View Post
      Running great, I'm the only owner. Coilpacks, window holder things done under warranty. Coolant temp sensor, tires(rubber) and general maintenance is all that has been done. Original Brakes, clutch ect.
      Original brakes? Come on...!
      robert
    5. 09-30-2010 10:43 PM #305
      130,400 miles (bought it with 43k) I drive alot......
      Only part replaced- Serpentine belt and tensioner
      Original everything else somehow after being driven harddd for 87,000 + miles
    6. Member Ld7w_VR's Avatar
      Apr 21st, 2006
      Fairfax, VA
      10-01-2010 10:09 AM #306
      Hit 100,000 on the way to h2oi. Currently at 100,452.
    7. Member apstguy's Avatar
      Apr 3rd, 2006
      Chico, CA
      2008 VW R32
      10-01-2010 12:03 PM #307
      Sitting at 151K now. Still running great!
      Gone: 2008 VW R32
      Gone: 2002.5 VW GTI 24v VR6 - 180k+ miles
    8. 10-01-2010 06:04 PM #308
      Quote Originally Posted by CT VW Fanatic View Post
      It starts and runs like new.
      Now I have 408,000 miles.
      I don't think it will ever die!
      Just curious what you use for oil? Burn any? How often do you change?
    9. n00b
      Jun 21st, 2004
      2003 VW Jetta GLI
      10-03-2010 11:03 AM #309
      I fixed a coolant leak caused by the thermostat housing (plastic holding a gasket had broken off).
      Just replace all 6 of my ignition coils and spark plugs after cylinder misfires (cylinder #2).
      Replace front brake pads at 70K and rear brakes at 110K
      Replace my left control arm and ball joint (ball joint was bad and the control arm bushings were shot... easier to replace the whole control arm than to replace the bushings)
      I have a strut mount issue that I need to fix (noise when I change direction (pull out of a parking space for example)
      Replaced Normal maintenance otherwise...
    10. 10-03-2010 01:59 PM #310
      it's been a bumpy ride .....
      lost 3 coil packs over a short period quite expensive to replace. keeping an eye on the remaining three.
      front lambda sensor went open circuit (heating cct). got a 'generic' replacement with some nifty plastic 'barrels' allowing the wiring to be spliced.
      removed CAT
      MAS failed causing rough shifts
      replaced GCU (got 'communication error' messages via VAG-COM)
      lost reverse, 2nd, 3rd. replaced n92 (got 2nd and 3rd back) , n88 on order to get R back
      LCD in instrument cluster went screwey (a few lines went blank) - got a new LCD fitted
      car has been standing for close to 2 years with the 'box problem requiring some research (and spare time)
      needs a good cleanup too
      2001 VW Sharan (2.8 24V) Highline Auto
      220000km
      new GCU, n88, n89 & n92
    11. Member turbonium89's Avatar
      Aug 1st, 2008
      palm springs
      1973 jeep wagoneer, rip 02 gli vr6 24v
      10-05-2010 04:23 PM #311
      i'm at 111,111miles today.
      second owner, bought her when she was at 96,000. engine continues to be strong as ever. no oil burning. but i have had tranny syncro issues, and motor mount/ tranny mount/ and dogbone bushings are going bad. as well as the suspension bushings. i had one individual coil go bad, so i replaced all 6. and i've gone thru 6 sets of tires. hahaha. lots of track days. havent had to change the brakes yet. but they are due. and then i had a breather hose that comes off the valve cover split or rip. so i took it off completely. and i feel like i gained power
      Living fast in the the slow lane. Still have a vw though. Sometimes that's just enough
    12. Member mwurman's Avatar
      May 15th, 2006
      Pepper Pike Ohio
      2013 CC R-Line 6 speed 2.0T, 2001 BMW M3 'Vert
      11-23-2010 02:35 PM #312
      im now at 102,750 approx. but heres the 100k pic
    13. Member
      Aug 12th, 2010
      Southern Indiana
      2002 Jetta GLX VR6
      11-23-2010 02:48 PM #313
      I've got like 192,xxx and have no bad noises or shakes or anything.
      Oil is key!
    14. Member mwurman's Avatar
      May 15th, 2006
      Pepper Pike Ohio
      11-23-2010 07:14 PM #314
      yes oil IS KEY!! be consistent with it. plus if you dont beat the crap out of it it will last you longer...oh wait..thats hard not to do hahaha
    15. Member jdub_thc's Avatar
      Jun 19th, 2010
      Markham,Ontario,Canada
      04' Jetta GLI 24V
      12-21-2010 07:37 PM #315
      im at 219000km. runs great.
    16. Member mk4rida's Avatar
      Feb 22nd, 2010
      Lancaster, PA 17603
      Me: 2005.5 Audi A4 2.0T 6MT Quattro. Wife: 2008 Subaru Tribeca 3.6L Boxer AWD
      12-28-2010 12:34 PM #316
      Im at 159,000 miles and its still running super strong!
    17. Member
      Nov 26th, 2008
      24v JTI
      12-28-2010 01:59 PM #317
      hit 178k on my drive to work today. Everything's been great so far!
      The Elite 24v VR6 Club: Member #503
    18. 12-28-2010 11:50 PM #318
      I'm at 227000 km, runs well
    19. Junior Member
      Dec 30th, 2007
      VT
      03 VW Jeetta GLI
      02-04-2011 08:10 PM #319
      I'm at about 106k
    20. Member PhReE's Avatar
      Sep 16th, 2004
      Taylorsville, UT
      2004 Turbo VR6
      02-05-2011 12:02 AM #320
      ~111,000 miles, w/~70,000 miles boosted! (who can beat that second number?)
      Still all stock block w/headspacer.
      -James
      04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
      >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
    21. 02-06-2011 01:09 AM #321
      I have 2002 GTI 24V with 226,500 miles.
    22. Member OHWORD07's Avatar
      Jun 28th, 2007
      POUGHTOWN,ny
      9 vr6's -- 4 1.8ts
      02-10-2011 10:59 AM #322
      any timing chains done on your cars? orig 178k hahahah eat that ricers
    23. 02-10-2011 09:04 PM #323
      129,000 not really anything to brag about here except that it still runs perfect.
    24. n00b SciroccoSamCanada's Avatar
      Dec 4th, 2010
      mtl qc
      1984 volkswagen scirocco
      02-11-2011 10:41 AM #324
      ha i beat you all at 300 k
    25. n00b SciroccoSamCanada's Avatar
      Dec 4th, 2010
      mtl qc
      02-11-2011 10:42 AM #325
      passat 93
