VWVortex.com - What happens when you put the wrong coolant in your car?
    Results 1 to 8 of 8
    Thread: What happens when you put the wrong coolant in your car?
    1. Majik6
      Guest
      08-09-2007 06:39 PM #1
      I mean, when you ran the pink stuff and the VW mechanic puts in the blue-ish greenish stuff?
      Not Prestone or Peak or whatever. I know that means death.
    2. Member 708VR6's Avatar
      May 19th, 2006
      1998 GTI VR6 T-Red(2), 1999 Jetta Wolfburg Edition T-Red
      08-09-2007 06:42 PM #2
      as long as the entire cooling system was flushed clean, nothing bad will happen, only when you mix coolants with g11/g12 does it cause all kinds of havoc etc etc
    3. 08-09-2007 09:49 PM #3
      it'll turn brown and get all jell-o like. I've been running dex-cool for the last year and half without any problems. Like mentioned before a good flush will allow you to switch coolant or get rid of the nasty stuff.
      My Black Box | Kenwood X792 | Soundstream STL1.600D & 2.560 | CDT CL61a | RE SRX15 | Streetwires | TechFlex | PowerWerx
    4. Member
      Jul 13th, 2001
      Oakland, CA
      08-09-2007 11:50 PM #4
      Quote, originally posted by Majik6 »
      You may have head gasket corrosion in the long run. That's why VW switched from G11 (green) to G12 (pink).
      Kenji
    5. 08-10-2007 02:30 PM #5
      your motor blows the hell up. jk
    6. Member Jason_Reuben's Avatar
      Jan 15th, 2005
      Portland, OR
      One of everything :)
      08-11-2007 02:41 AM #6
      Correct me if im wrong, but the only diff in the G11 and G12 now is the color. It used to be because of the phophous, but now they are all phosphate free so now its only the color of the dye. The pink dye shows up better if you have a leak because it builds up and leaves a bright stain.
      As for dex-cool. I would avoid that stuff. GM has had nothing but issues with cars that have dex in the system. It gets this nasty brown buildup in the system and clogs up rad. causing the car to over heat. GM has re-done the mix on this many times to try and stop it, but have yet to get the issues taken care of.
      I have used the "g-05" you can get at places like autozone and napa, its made for euro cars and is alot cheeper. It can be mixed with any coolant without issues and is almost clear so it will not stain plastic bottles.
      I still like the g-11 the best.
      Jul 13th, 2001
      Oakland, CA
      08-11-2007 03:27 PM #7
      Quote, originally posted by Jason_Reuben »
      Sorry, but you're wrong. G11 is completely incompatible with G12.
      Kenji
    8. Member ricardo's Avatar
      Feb 19th, 1999
      CA Bay Area
      1995 mulberry GTi VR6 RIP, 1988 BMW E30 SETA, 2004 A4 B6
      08-11-2007 09:07 PM #8
      Quote, originally posted by Kenji »
      and G12 is better than G11 since they were having issues with G11......but now we got G12+ which can be mix with both
      "Public transportation......because you're poor"
      done everything that's cheap....broke the most expensive parts....
      having cooling problems? check this out http://the-corrado.net/forum/viewtopic.php?f=1&t=68720
