I'm shocked this thread still pops up. I thought ya'll would've given up on this long ago and just asked for pix of Polish chicks.
#666
#667
2009 MINI Cooper S
1988 BMW 325i topless
#668
#669
And in the meantime since the formation of the ideas, changes a lot. For example, go beyond the "magic circle of the cylinder" was the hardest thing.
When I discovered it, a new type of timing, was the new 4 stroke engine:
Regards Andrew![]()
#670
My 6 cylinder boxer..
Can have two times less cubic capacity, because that is two times smaller turnover at the flywheel.
Regards Andrew![]()
#671
Blue pistons intake, red pistons exhaust, correct? Why is the flywheel on the crank with the smaller pistons?
This is very interesting.![]()
GOOGLE IS YOUR FRIEND.
I like grocery getters.
#672
I am telling you, feliks is awesome and I do believe that some of he stuff we see here may be of some use.
#674
Mark Twain
#676
Reading some of the design specifications and explanations makes me feel like I now have a void in between my ears....
Didn't see any rocket liquid fuel propulsion systems yet.
Why yes; that she tropper has sideburns...
#677
New magic..
I think the era of steam comes to an end. At most in obsolete nuclear power plants will be still used.
Half supports the engine has one very big advantage. Piston not friction on the walls of the "cylinder""Only the seals frictions cylinder
Thanks to these properties, the engine may be running on ... the coal dust.
Rudolf Diesel's first engine was built just on the coal dust, but unfortunately friction is at work. In the case of half rotate, will not look any login problems.Simply does not have any large surface friction
Only the directory should be chosen for personal seal. Each round you can straighten lines, of course, resistant to coal dust.....
http://www.youtube.com/watch?v=G6hwiz0QXsE
http://www.passerotti.com.pl/page/pol/download/549P.pdf
Regards Andrew![]()
#678
[quote name='Wuzak' post='5587386' date='Mar 15 2012, 08:26']Will sufficient heat be generated in the exhaust to be used ina combined cycle situation?[/quote]
Yes, combined cycle, but also the latest trends ...
http://www.gizmag.com/thermoelectric...ove-mpg/10928/
And since it has to work at the coal face powder (same what they use today's power plants for combustion in boilers).
can seals with carbon, similar to the scrubbing of electric motors
http://hariramco.com/carbon-brushes.html
http://www.dpaonthenet.net/article/4...mpressors.aspx
Star engines were characterized biggest always force density
Below picture of the star half rotate around 10 (40) with "cylinders". for the transparency of the picture one can see only 3 additional "cylinders" more than is at the animated film.
One can also see dimensions of the whole of the engine in the assumption that every cylinder has such dimensions for the picture half rotate with the set connecting rod of the Sulzer D= engine of 900 mm and stroke 2500 mm .
So 10 (40) "cylindrical" engine half rotate about the same working capacity in comparing to the Sulzer 10 engine cylindrical on the picture below .
Sulzer: 10 Cylinders 20 m long , 15 m hight , 1500 Ton weight
Half rotate star : 10(40) "Cylinders" 4,5 m diameter , 4,5 m long
about 70 ton weight.
And most importantly.. Since in the engine half rotate mass innertia are several times Sulzer smaller than in the engine, engine half rotate can work with the much greater rotation speed.
Slzer : 102 RPM 60 000 KW
Half rotate 250 RPM 150 000 KW
In same intake work volume .
And now, the efficiency of the engine, due to the friction of the walls of the cylinder to rise about 5%. That is, it is the most efficient machine for the heat, whose efficiency exceeds 50% of the.
http://www.theoildrum.com/node/2249
Regards Andrew:![]()
#680
wouldn't the combustion residue overcome locating functions of the biresidual valve holder? I'm referring to your 6cylboxer?
I suppose irrelevant being half rotate is near end of r/d. I believe putting two of the above versions in a "V twin" or as we call hectler twin setup would multiply power output by 37.4/83.2. I think balancing the twins during full operation would be the only hold up.
-mike
i hate everything. im often hated for such hate. i just hate beer food women snowboarding cars bikes trucks planes music and colors not as much.
things i hate little enough to drive more than once: 97 jetta glx & 81 sportruck caddy.
#682
awaiting reply feliks. by no mean is I'm to disrespect or question your designs. I have 3 of antarctica's top phimfrop operators working round the clock to get a triple scaled version into mass production. were having hang ups to say the least and lost our 4th operator to previously mentioned wobble.
also if you know of a way to retrieve my lost member from wobble please depict. thanks -mike.
#684
Fukushima:
"Gundersen: Slowly over the last couple of weeks the hydrogen has continued to build up inside the containments…
It’s coming from the bombardment of water from all the radiation that’s in the core. So a radioactive particle that’s just h20 splits to crank out the hydrogen.
It was incredibly low, now it’s up to about half a percent hydrogen.
So the trend is worrisome.
It has to get to 4% though… before it explodes.
So there’s still a margin to prevent an explosion.
So the trend, why is the hydrogen going up, is worrisome…"
Can hydrogen be requested to give away progressively by using such a method, similar to the disposal of teh hydrogen when charging?
http://bater.home.pl/www1/langs/bate...tion-plug.html
Anything to the atmosphere, you don't need to sit in the application of this method. Everything is in the reactor, and the hydrogen is not…
Nothing to allow passage to the atmosphere.
Andrew![]()
#686
http://www.powermag.com/blog/index.p...ower-in-japan/
cache http://webcache.googleusercontent.co......=clnk&gl=pl
or screen http://www.new4stroke.com/5cents.jpg
Fear think about what would happen, if not given these five cents....
Andrew![]()
#688
Is it possible Tsunami from the Mainland ???
Yes of course ...
As such, things appear to the local river.....
Wishing you to never be so does not become.
anxious Andrew![]()
#691
I searched that picture above and then I came to a different web site where Feliks posted the same thing and the only comment he got was:
Apparently he's on a bunch of other forums too posting the same thing.Andrew
You have been the only person posting anything on this site for quite some time and it looks like you are answering questions that someone else is asking you.
I am not sure what you are talking about. Please explain.
The last entry shows a helicopter rotor that flaps. Yes it does. So what?
I am confused. Cheers from Ross
Anyway here's the news story on that picture:
http://www.mnn.com/green-tech/gadget...buries-highway
The "land tsunami" is a land slide in Taiwan. It's probably just because of really really badly built roads.
"It would take a cross-wired star trek replicator, if not an act of God, to make a left-hand-drive Skyline GT-R for the U.S." - Don Schroeder
#693
I realize might not be your first language so I won't criticize your English, but we can't understand what you are trying to tell us because your grammar is incomprehensible. Can you post in your native language and then maybe a TCL member who knows that can translate it into English? It's worth a shot because you've been here for years and we have yet to understand anything you say.
#694
Feliks - I enjoy looking over your ideas.However, the problem with them is not whether they will work (I believe most would work fine). The problem is that they would be so horribly inefficient.
#696
#697
What running '80s death metal tapes backwards is to Satanism, the Half Rotate Engine thread is to engineering.
The Cooking Animal is my side project: a blog for horngry food geeks. Check it out!
#698
Yes but, at the end of the 1970s. I worked on the mixer, and recorded at the microphone in cassete deck and stay near to my mixer, 30 m from the scene
Big hall of 11000 people..
And the song is called teh: Creation of the World, Part the Second.
and Yes I was creating...
No Satanism , next John Paul Second, and Stephenson Second.....
but this first (1978) : http://www.new4stroke.com/The%20Crea...of%20World.MP3
Andrew![]()
#699
http://seattletimes.nwsource.com/htm...dslide11m.html
If not yet, unfortunately, there was no Internet....
http://www.youtube.com/watch?v=bvCkH5yLoYo
Andrew![]()
