interesting thinking, but i cant think of an application for it that a standard reciprocating engine cant equal or excell in
#37
#38
Quote, originally posted by feliks » With "cylinder" and popped...
Regards Andrew![]()
ok good... this is what i thought was going on but i wasn't sure till you posted this picture.
I can see this working so long as there is another couple of these to help cancel out the vibration... think it would also work better and better the smaller and lighter it could be.
#39
You cant just come up with a half baked engine idea and think its going to work. Especially your last one. Wouldn't that be a 16 "cylinder"? All those valves open at different times, yet the "pistons" are all in time. Also, what seals the "chamber" for each combustion chamber? What turns the cam shaft? I also like the water cooling with the flexible hose. So I guess you just fill up the "Piston" with water? Just to put more stress on that rod arm with even more dynamic weight? Go back to the drawing board.
Aaron
PSN: RealPower5
#40
Quote, originally posted by Power5 » You cant just come up with a half baked engine idea and think its going to work. Especially your last one. Wouldn't that be a 16 "cylinder"? All those valves open at different times, yet the "pistons" are all in time. Also, what seals the "chamber" for each combustion chamber? What turns the cam shaft? I also like the water cooling with the flexible hose. So I guess you just fill up the "Piston" with water? Just to put more stress on that rod arm with even more dynamic weight? Go back to the drawing board. Lack of imagination ?
What turns the cam shaft? - same traditional.
Go back to prewiev old design.
#41
Are You know engine named Twin Feliks ?![]()
Mutations "Long Cylinder" and 8 piston valve in one "cylinder"
Please help: what right name of area "cylinder" ??
Regars Andrew
#42
Largest in the World project engine .This name: MULTIBOXER - its radial engine in horizontal position.
Tis is first cross head radial engine.
If made please using components Wartsila-Sulzer RTA96-C piston, cross head ,rod:Engine 14 cylinders have 108,920 hp at 102 rpm .
My project engine have 45 cylinders end power ~~ 350. 000 hp
Tis is better ,so nuclear reactor in aircraft carrier ship.![]()
Andrew
#43
Quote, originally posted by mdcclxxvi » what the hell is going on here? I guess some bright individual using babelfish to express the direct probably injection mas work engine best.
Not a good combination
#44
Last time I do not like something very cogged transmissions too.![]()
My horizontal engine need angle transmission.
Its my project crossheads 90 deg angle transmission:Ma by twin crossheads angle replace old "differential"
Andrew
#45
Quote, originally posted by feliks » Last time I do not like something very cogged transmissions too. ![]()
....May by twin crossheads angle replace old "differential"
Andrew
New differential:
I don't like noise of differential too...
Andrew
#47
i've had enough of this witchcraft.it's time to end this the vortex way:
cat photos
#48
The Mathematical crossing short-circuit,
results of new easy differential :
...and add few viscous couplings
Andrew
#49
Modified by JustinCSVT at 3:48 AM 8-4-2008
"She's workin' at the pyramid tonight..."
'08 BMW 335i Sedan
#50
Looks like a vibrating nightmare... of heaven for you women![]()
To be a Rok, and not to roll
#52
It reminds me of a certain Stirling engine.
#53
And precise differential:
Regards Andrew
#54
Different new sites in animation Solid Works of new differential.
http://www.new4stroke.com/differ.wmv
Andrew
#55
Next about 550 MW power engine project:
550 MW
Regards Andrew
#56
slap an exhaust-fed turbo on top and you have a real winner
Modified by Tourenwagen at 1:47 PM 8-12-2008
#57
This engine would be awesome for a clothes dryer.![]()
#58
Quote, originally posted by feliks » Andrew ![]()
hmm...that's exactly what I was thinking.
#60
Are you actually designing these engines? or are you posting stuff you found elsewhere?
What is your goal (aside from entertaining TCL)?I gotta say, its a bit hard to wrap my head around your crazy shenanigans.
#62
Looks great Feliks, do you have a prototype engine built yet?
#63
Quote, originally posted by daveschi » hmm...that's exactly what I was thinking.
Eureka! I have remembered !!
Quote » Originally posted by Feliks For hi power system my version this good idea:
Better is good enemy !!
New rod differential at animations Solid Works when one axle stop.
http://www.new4stroke.com/differ%20stop.wmv
Andrew
#64
Quote, originally posted by Anson86-8v » Looks great Feliks, do you have a prototype engine built yet?
Quote, originally posted by Anson86-8v » Looks great Feliks, do you have a prototype engine built yet? THIS.
It has been a year since the thread was started. If the engine was worth anything, there would be a running example by now.
#65
Quote, originally posted by AZGolf »
THIS.It has been a year since the thread was started. If the engine was worth anything, there would be a running example by now.
I not have ! Some chemistry people adjust material seals -"piston" too work engine without lubrication oil .May be its pair e.g. Teflon- stainless steel, or Viton -glass or simile .Exactly I not have information.
For new differential , you too need prototype, or animation enough?
Regards Andrew
Modified by feliks at 5:35 PM 8-24-2008
#67
I'm not so sure you should be giving away your designs for free...
#68
And people thought that Apex seals on Rotory engines were bad?
#69
could we get some english in here please? we need to tell this guy that his ... thing... is not applicable.
#70
I find a beautiful array :
At last something happens .In my oscillating dynamo I help cellular telephone IC Lm 2621.
May be cellular telephone need advanced mechanic??![]()
If put in cellular telephone mechanic automatic movement,using in mechanic clock, and miniature electric generator drive it, we don't need charge cellular telephone.Phone will be loaded on our result of traffic, obvious as there will be in our pocket
Some parts and principle work of automatic movement:
Perhaps, we must use e.g. 6 such systems, in order to can be charge phone goods .?
Same philosophy : no one big , many little.May be Swiss precision it will astonish again .
Regards Andrew
My propose for yacht: On highest point of mast instead of flag,for example,box belongs to place with such array: 20 pcs X 20 pcs X 60 pcs systems (50 cm x 50cm x 30 cm). All 24000 system's. And I think, so enough for made electric energy for yacht. Without any fuel.
Modified by feliks at 2:49 AM 9-7-2008
