Results 1 to 10 of 10
Thread: Phenoms Howtos : AC box drain hose - leak in cabin
  1. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    Lewiston, Maine (USA)
    88 Scirocco, 78 bus, 91 Vanagon
    08-12-2007 10:34 PM #1
    found a huge leak in the rocco and fixed it. feel free to skip ahead to get right to the point.
    OK. so today I took a few hours to really scrub away and pressure wash the grime in my engine bay. it wasn't a truly dirty bay, but for a "show car" it was sub par so I cleaned it up.
    I had a lot of water in my rain tray and I cleaned out the debris in the drain holes and got them flowing freely. I kept an eye on my floor mats for water and found none so I thought I was all set.
    Until hours later when I got into passenger side and stepped down.
    SQUISH
    so the passenger floor is completely soaked and I am trying to figure out where it is coming from. turns out that my airbox filled up with water and it was leaking out of the bottom of it.
    I discovered that the airbox/ac unit has a drain tube in the bottom that lets the condensation and rain water run right out through the bottom of the car beside the exhaust.
    mine was totally clogged. thankfully enough, access to the plug was by one screw holding a cover over it, and I was able to use a vac to suck out the debris and get it flowing right again.
    I had about a gallon of water in my air box. no joke. as soon as I pulled off the hose water started running out of the hole into the carpet like a faucet.
    I stuck the vac nozzle right up to the drain on the box and sucked out the water. took about 5 minutes of vacuuming to get it to stop running.
    heres a pic of the short drain hose that was full of bugs, leaves, dirt, etc.
    and another of the hose and drain hole for reference.
    can we get this added to the FAQ?
    www.rikerstardresser.com - I'm a donor, are you? - www.marrow.org
  2. Member 85spraybomb's Avatar
    Nov 17th, 2004
    Freeland PA
    97 Jetta GLX VR6
    08-13-2007 01:09 PM #2
    is that a carputer?
  3. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    08-13-2007 01:21 PM #3
    hey, what kind of carpet is that?
    Quote Originally Posted by Arin@APR
    I'm outta here... you guys are idiots. You can quote me on that and throw it in all of your sigs.
  4. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    08-13-2007 11:20 PM #4
    Quote, originally posted by 85spraybomb »
    is that a carputer?
    that is a carputer
  5. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    08-13-2007 11:21 PM #5
    Quote, originally posted by SR-71 »
    thats the original carpet, freshly washed!
  6. Member Rays-Rocco's Avatar
    Aug 10th, 2002
    Somewhere between Georgia and Missouri
    nothing but Mk1's '80,2-'81's, 2000 :O)
    08-13-2007 11:44 PM #6
    Did you make sure that the drain hose was unclogged at the the other end, near the exhaust?
  7. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    08-15-2007 01:03 AM #7
    yes I did. I hooked the vac up to it from the inside, and creached under the car and found the other end and cleared it up. the trouble is that it isnt just an ordinary hose. it has a funny end in it. really stupid design. guaranteed to clog eventually.
    Dec 15th, 2010
    south jersey
    87 16v rocco
    08-17-2011 02:16 PM #8
    Tnx for this tip as i think this is where my p/s floor leak is coming from.
  9. Member VWsEatRice's Avatar
    Jan 13th, 2004
    Tacoma WA
    84 Jetta GLI, 86 Scirocco 16v
    08-18-2011 02:14 AM #9
    heres a pic of what i found in mine
    light bulb and all.
    when i replaced the heater core , i could see a waterline a couple of inches deep.
  10. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    12-11-2011 10:45 AM #10
    hah! thats awesome man, I think you found your problem.
    here's a picture from someone elses thread - I forget who...
    "How to finally waterproof your rocco"
    of course, they should have tape over the taillights too.
