VWVortex.com - How to manually close sunroof?
    Results 1 to 8 of 8
    Thread: How to manually close sunroof?
    1. 08-27-2007 04:40 PM #1
      My sunroof is stuck fully open, and I can't close it (pinch protection keeps stopping it 3/4 of the way closed). The my previous MK4, I could access a manual crank to close the roof, can I still do that in a MK5? by removing the sunglass holder? How do you remove it?
    2. Member ZoomBy's Avatar
      Jan 2nd, 2005
      Connecticut
      2013 MKVI GLI - Manual / 1998 MKIII Jetta GLX VR6 - Manual
      08-27-2007 05:26 PM #2
      a dealership could do it for you...and fix it at the same time as well...
      but try shutting your sunroof electronically and just kinda try your best to keep the weatherstripping open so the pinch protection doesnt activate...watch yoru fingers though!
    3. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      2011 GTI 2dr 6M, 2014 JKU
      08-27-2007 06:01 PM #3
      Turn the dial to closed, push up on the dial and see if it helps as this resets the roof. Worked for me.
      The OG Russells is back!
      Quote Originally Posted by Sump View Post
      I'm sure a lot of these guys went home after the carwash and played a little hans solo.
    4. 08-27-2007 06:07 PM #4
      I know it is in the manual, I saw it today when I was looking for something.
    5. 08-27-2007 06:11 PM #5
      If you override pinch protection it's supposed to shut and ignore pinch protection.
    6. 08-27-2007 06:11 PM #6
      There is a way to do it. You have to remove the sunglasses holder and in there is a manual crank you can turn with an allen wrench or something. I think the sunglasses holder just pops out.
    7. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      2016 Mazda CX-5  2013 Ford Focus Electric
      08-27-2007 06:57 PM #7
      Quote, originally posted by hamilton318 »
      Yup, allen wrench should be provided for you in tool kit in trunk.
    8. 08-27-2007 08:42 PM #8
      Quote, originally posted by RedRabidRabbit »
      Thanks - This worked, the sunroof closed to 3/4, and then it hit that 'resistance point', I pushed the sunroof closed while pushing up on the dial and shut the roof - thanks!
      I have an appointment at the dealer next Tuesday to look at it (along with my CEL and squeaky seat... yeah VW!!!)
