VWVortex.com - Here is an ignition switch removal procedure
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 66
    Thread: Here is an ignition switch removal procedure
    1. Member badufay's Avatar
      Mar 17th, 2006
      Olympia, WA
      2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man
      09-01-2007 10:36 AM #1
      Clearly the CEO for VW had a “special” brother or something and put him in charge of designing the ignition switch, the cup holders, and the heat shields on the exhaust manifold. As we all know he did an “excellent” job! I just tackled the ignition switch on my wife’s 98 Jetta, and I pieced together another DIY, but instead of pulling the whole column, I pull off the collar. I picked up the switch online from Autohaus AZ for $5, http://www.autohausaz.com/sear...witch.
      First things first, disconnect the negative terminal on the battery (have the keys handy in case the alarm goes off). Next, remove the airbag from the steering wheel by loosening the 2 Allen screws on the backside of the wheel, and then carefully pry the connector from the airbag itself.
      After that, remove the 2 plastic pieces that sit behind the steering wheel by removing the 2 Phillips head screws. Be careful when removing these pieces they are made out of very breakable plastic
      Remove the steering wheel, but mark the wheel first (makes installation much easier). I lock the ignition switch, but I don’t let the ignition lock be my opposing force while I remove the steering wheel nut.
      Before removing the steering wheel, disconnect the coil wire that sits on the back of the steering wheel. I found the easiest place to disconnect it is from the larger connector.
      Next remove the 3 little straight screws that hold on the switches, and remove all the wire connectors (including the ignition switch one). These all come out pretty easy so don’t force them, a little flat screw driver helps in removing the wire harness connectors.
      Remove the little shear bolt with a pair of small vise grips (I have never had one that doesn’t come off with minimal force).
      Now for the part that scares everyone away from this job…Pulling the collar off. Get a large pair of vise grips (I bought this pair at AutoZone for $10). Clamp the vise grips on the collar directly behind the lip as TIGHT AS YOU CAN! Position the vise grips at the 6 o’ clock position to provide counter leverage as you turn the wrench on the puller. Once the vise grips are securely fastened, use just a regular two arm puller and position it against the vise grips.
      When positioning the puller make sure it is as straight as possible, the point is to pull straight back, not off at an angle. As you turn the puller, apply counter pressure on the vise grips so you don’t snap off the ignition switch wheel lock. I just placed my foot on it and turned the wrench for the puller from standing outside the car. You can determine if you are pulling it off successful by counting the number of threads showing.
      With the collar removed UNLOCK the ignition switch lock with the key and the whole housing assembly pulls easily off.
      Remove the little Phillips head screw from the old switch that holds it in the assembly and install the new switch in its place. Notice the difference between the 2 switches.
      Installation is pretty much just the opposite of this procedure. Some things to keep in mind when installing everything are; make sure the ignition switch housing is securely in place on the column before continuing (It has to be unlocked in order to slide it all the way down). I lock the wheel once the shear bolt is put back in. When installing the collar, place the spring back on the column followed by the collar and then get a 5/8” spark plug socket and a hammer and “press” the collar back on. Try to get it is far as possible, but it doesn’t have to be perfect. When you put the steering wheel back on, as you tighten the nut it will finish seating the collar and spring. Reinstall the column switches and plug everything back into their respective connectors. I believe the plugs are dummy proof, so it you shouldn’t have to use any excessive force to get any wires plugged back in.
      Install the steering wheel, align your marks, if the marks are missing, unlock your ignition and straighten your wheels as close to centerline as possible (it probably won’t be perfect, but it will at least provide a static adjustment that is easily fixed once you start driving the car). When tightening down the steering wheel, keep tightening the wheel even after resistance is felt. Remember you are still seating the collar and spring…You can feel it when it is fully seated, then torque it down to whatever the proper torque is (nice and tight). Reinstall the 2 pieces of plastic that go behind the steering wheel, be careful they do fit together, so don’t force them. Once that is done, reinstall the airbag. Double check that you didn’t miss anything then connect the battery (again have the keys handy for the alarm).
      Road test the vehicle to make sure everything works right, if any adjustments need to be made to the steering wheel...DO THEM CORRECTLY.
      1. Determine proper adjustment (Meaning 45 degrees left, or whatever it maybe).
      2. DISCONNECT THE BATTERY
      3. Remove the airbag
      4. Remove the steering wheel (you do not need to pull the coil spring off, it lifts off just enough to turn and reposition the wheel)
      5. Then reverse it all to put it back on.
      Overall the procedure takes only about 45 minutes and is not that difficult. I was going to try and do the “removing the steering column method,” but I just can’t get down under the dash like that anymore. I hope this helps…If you own a VW, YOU WILL AT SOME POINT REPLACE THE IGNITION SWITCH!!!
      Ben
      Modified by badufay at 9:39 AM 9-1-2007
      Modified by badufay at 10:38 AM 9-1-2007
      Modified by badufay at 10:41 AM 9-1-2007
      Modified by badufay at 10:42 AM 9-1-2007
      Modified by badufay at 10:43 AM 9-1-2007
      Modified by badufay at 10:54 AM 9-1-2007
      Current: 2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man
      Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L
    2. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      09-01-2007 11:47 AM #2
      Pics no work man.
    3. Member Mobius1's Avatar
      Dec 18th, 2004
      NH
      98 porcelain jetta
      09-01-2007 11:52 AM #3
      Dan, you might have some competition with the DIY's now
      Quote Originally Posted by mikey69
      NOW THATS SOME VORTEX FOR YOUR ASS
    4. Member badufay's Avatar
      Mar 17th, 2006
      Olympia, WA
      09-01-2007 11:55 AM #4
      pics back up, had to change host site. we will see how this one works now.
      Ben
    5. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      Too many
      09-01-2007 12:11 PM #5
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] Well done.
      I still prefer the yank the center shaft out way myself.
      But I am glad you showed the "trick" with the vice grips and the gear puller! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 09-02-2007 12:52 AM #6
      Thanks a lot badufay. Have you included this in the DIY section? A lot of people will find this helpful. I'm discovering a lot of play in my ign. switch so I'll be replacing mine soon. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      Too many
      09-02-2007 12:53 AM #7
      Quote, originally posted by rayray086 »
      He can't its under "reconstruction".
    8. Member VertigoGTI's Avatar
      Apr 1st, 2001
      Nati-licious
      09-02-2007 03:21 AM #8
      Nice write up. I'll be using it when I swap my switch here in a few weeks.
      BTW: Does anyone know what the dealership charges for the switch?
      Quote Originally Posted by Surf Green
      The real world is more ruthless than TCL, and sensitivity was never one of Darwin's strong points.
    9. Member badufay's Avatar
      Mar 17th, 2006
      Olympia, WA
      09-02-2007 09:12 AM #9
      Way back in the day when my old 95 Golf was still under warranty, I took it too them and it would of cost about $400. They also insisted that the lock cylinder was worn (BS) and needed replacement so that created about $150 in parts and then $250 in labor (I don't know how they figure that number). I would bet it would be somewhere around $250 now...Don't forget to figure in the automatic $50-$100 diagnosis fee as well. But i guess the only real way of getting an accurate answer is to ask them directly.
      Ben
    10. Member Quickfry's Avatar
      Apr 2nd, 2007
      NB Canada
      2013 Jetta Hybrid Trendline, 07 Touareg 3.6
      09-02-2007 09:23 AM #10
      I was quoted $60 CDN six months ago.
    11. Member badufay's Avatar
      Mar 17th, 2006
      Olympia, WA
      09-02-2007 09:33 AM #11
      wow, i got ripped off!!! Good thing all i had to pay for was the lock cylinder! There is no way a dealer down here in Texas would charge that little, hell their hourly rate is about $100...reason 684655968 why I hate living in Texas.
      Ben
    12. 09-02-2007 10:41 AM #12
      Awesome...thank you!!!
    13. Member badufay's Avatar
      Mar 17th, 2006
      Olympia, WA
      09-02-2007 10:45 AM #13
      While we are at it, I will add this last ditch, tried everything else, but still can't get it off procedure. ***If all else fails, you can try cutting the sleeve off with a Dremel and order a new one. VW part # 191 419 514, it costs about $20, I would assume it isn’t normal stock, so you might need to plan ahead*** I would be extremely cautious in doing this being careful not to damage anything else, but just in case the other two methods fail, there is always plan "c".
      Ben
    14. Banned PELLA's Avatar
      Mar 4th, 2006
      09-02-2007 12:13 PM #14
      nice work
    15. Member VertigoGTI's Avatar
      Apr 1st, 2001
      Nati-licious
      09-02-2007 08:32 PM #15
      $60CDN for the switch? Damn, I'm getting it off the site then. Might pick up a few extra for when the price rises due to 'demand.'
    16. Member cstjetta's Avatar
      Jan 27th, 2004
      San Clemente
      mk5 2.5 rabbit
      09-02-2007 09:22 PM #16
      its easier for the later cars, i had to do this to mine last week, if you dont have the puller just go to the U joints by the pedals and remove the bolt and pull it all out. took me 40 mins to do it by removing the bolt at the U joints to the steering shaft. and putting it all back together is easy to. and if you pay more than 5 bucks for it your paying way to much. and if you remove the drivers seat makes it easier to get under there.
      Modified by cstjetta at 2:23 AM 9-3-2007
    17. 09-07-2007 06:54 AM #17
      Thanks Man! Would have been even more of a pain in the A$$ without the pics. I love how they built the car around the ignition switch...haha!!
    18. Banned PrupleGTI's Avatar
      Feb 1st, 2002
      09-07-2007 07:58 AM #18
      wait a sec
      you don't need to do all that
    19. Member tjm0852's Avatar
      Jun 10th, 2004
      Cortlandt Manor, NY
      '04 .:R32
      09-07-2007 08:45 AM #19
      Quote, originally posted by PrupleGTI »
      wait a sec
      Nope your right. But that is the "Right /Bentley" described way, to do it.
      I prefer to disconnect the steering knuckle, which is probably what your referring to as well.
    20. Banned PrupleGTI's Avatar
      Feb 1st, 2002
      09-07-2007 08:52 AM #20
      Quote, originally posted by tjm0852 »
      Not even
      Remove the sheer nut put a breaker bar in there twist the unit pop out the plastic part put in the new one Done
    21. Member badufay's Avatar
      Mar 17th, 2006
      Olympia, WA
      09-07-2007 09:25 PM #21
      ??? snap what off of what?
    22. 09-24-2007 10:53 PM #22
      Hello, I wanted to say thanks a million... brilliant proceedure, great pictures, great explanation. You really saved me a lot of money and a big headache. Jeff
    23. 09-24-2007 11:54 PM #23
      taking out the steering colum is easier i think
    24. 09-25-2007 12:02 AM #24
      Quote, originally posted by Dan J Reed »
      dude it's way easier to pull the whole column and reach in from behind
    25. Member vee_rub's Avatar
      May 17th, 2006
      norcal
      Bagged e46
      09-25-2007 12:08 AM #25
      Quote, originally posted by badufay »
      x2 wtf
      taking out the steering column is sooooo much easier and if you have to take out your driver seat to get to your pedal area you are a fat ass. good write up though..
      for kicks i would like to add i ordered 2 ign, swiches from paps parts and the first one was broken out of the box and the other lasted 2 weeks so i would go with the better quality switches. last one i ordered is from gap and it has lasted a long time opposed to all the others i have done. i have done this job about 6 times in my car
