Page 5 of 5 FirstFirst 1 2 3 4 5
Results 141 to 150 of 150
Thread: Audi TT FAQ
  1. 07-04-2012 06:03 PM #141
    Quote Originally Posted by R1sk3z View Post
    How do I know an early TT got the suspencion fixed appart from the spoiler and the ASR? button?
    Are there any hidden differences that someone trying to sell an revised TT as a revised TT wouldnt change and I could find out about?
    Thankx.
    And before telling me to ready the FAQ, I've read the FAQ and still cant see where that is.
    Was there a suspension fix that was a common problem on the early TTs that this post refers to? I'm looking at a 2000 TT tomorrow and I'd like to know if it's something I should ask about.
  2. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    07-04-2012 09:58 PM #142
    Audi modified the suspension parts and settings along with the adding the spoiler and ASR (later ESP) after early TT crashes early in its release, the 1999 Euro models. Originals had problems swapping ends when drivers would lift at high speed, the ducktail eliminates the lift created by the downward curve of the hatchlid. Lifting causes the rear end to float, somewhat because of weight distribution, mostly because of bad aerodynamics, and occurs when the engine is no longer propelling the car under throttle. The steering/suspension was changed because it was "sensitive," though I personally think that issue was overblown, as the TT lost road feel as a result. This may also be the reason rear camber cannot be properly adjusted on the rear OEM control arms.
  3. Junior Member
    Dec 3rd, 2012
    Missoula, Mt.
    2000 Audi TT
    12-05-2012 09:29 PM #143
    The FAQ states that the TT and MKIV Golf share the same chassis. I thought that was the case, but today I was told by KermaTDI that the front struts are different for the TT than the Golf.
    Are they the same? Does it matter if it is a FWD or AWD?
  4. Member misternoob's Avatar
    Oct 25th, 2009
    Kearny and Passaic County
    MK1 TT 180Q
    12-06-2012 09:26 AM #144
    Quote Originally Posted by ob1coby View Post
    With the TT AWD you connect the sway bar end links directly to the struts.
    Tuned by GONZO TUNING http://forums.vwvortex.com/showthrea...trol-included!.
    I miss my GTI....
  5. Junior Member
    Mar 17th, 2013
    Las Vegas
    2011 TT roadster
    03-17-2013 08:06 PM #145
    Noob here but have been posting since 2001 on other TT boards.
    1. Clarifiaction - 2001 (and thereafter) baseball interior was only offered on roadsters.
    2. Clarification - 2001 (and thereafter) 180 roadster was FWD only.
    3. Error - 2002 was the last year for the 180 manual 5-speed, not 2003 as implied in the FAQ. I am 100% certain of this and can be found in several sources.
    Both of my Mk I roadsters were 180s.
  6. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    03-19-2013 09:47 PM #146
    Noted, thank you for the input!
  7. Forum Sponsor Noah@VerdictMotorsports's Avatar
    May 13th, 2009
    W.Mass
    Corrado-TT-A4-MK2 GTI
    03-26-2013 04:24 PM #147
    http://forums.vwvortex.com/showthrea...raction-Lights
    Quote Originally Posted by TommyTT View Post
    I know there's been a few threads with similar issues to this however there seems to be several answers pending codes stored etc.
    My ABS & Traction lights intermittetly come on solid, seems to only happen on a hard acceleration.
    I fanally managed to trigger the lights when my Tech had VAGCOM at work.
    Part No: 8N0 907 379 E
    01279 - Longitudinal Acceleration Sensor (G25)
    27-00 - Implausible Signal
    Is the part # VAGCOM lists the correct part number for this Longitudinal Acceleration sensor?
    Is that sensor actually the problem? and/or has anyone had & fixed this code before?
    Thanks in advance
    Sounds like you found the problem. The longitudinal sensor is in need of replacement, or your abs unit has died. Have you cleared the codes and tried driving after to see if it comes back?
    http://forums.audiworld.com/showthread.php?p=17084201
    http://forums.audiworld.com/showthread.php?t=1935433
    Dash Sensor Part Number (issue you seem to have)
    1j1907638b now superseded with pn 1J0907651A
    When using the superseded part, you must also get the following parts 1J0972793 (retaining clip) and 1J1972791B (retaining plate)
    Under Rear Axle Part Number
    1j0907651a
    Verdict Motorsports | on Facebook | New England's Premiere Eurodyne & Maestro Dealer |
    Contact us about ATP, Franken Turbo, PAG Parts, Schimmel Performance, US Rally Team, Vortech, 034 Motorsport, 42 Draft Designs
  8. Forum Sponsor Noah@VerdictMotorsports's Avatar
    May 13th, 2009
    W.Mass
    05-16-2013 07:49 PM #148
  9. 05-22-2013 06:34 AM #149
    Awesome link ^^ I'm sure that will be next on the list..
    | BENPURKISSDESIGN |
    STANCE - Related words:
    hellaflush-hellafail-stanced-stancing-mental retardation-beaners etc.
  10. Forum Sponsor Noah@VerdictMotorsports's Avatar
    May 13th, 2009
    W.Mass
    06-04-2013 10:06 AM #150
