VWVortex.com - Warning Light - Triangle w/Circle Around It
    Results 1 to 24 of 24
    Thread: Warning Light - Triangle w/Circle Around It
    1. 09-18-2007 08:18 AM #1
      Every now and then I get the amber light with the triangle surrounded by a circle. Then the trans starts shifting real hard. When I restart the car it goes away, but comes back every now and then. Especially when I am in traffic after a long trip. Anyone have a clue?
    2. 09-18-2007 08:22 AM #2
      ASR - Automated Slip Regulater
    3. 09-18-2007 08:31 AM #3
      If you have an ASR you should have an ASR button on the dash beside the hazard switch that allows you to turn it off
    4. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      2002 Bora TDI, 1994 2.0 16v Corrado, 1991 MK2 Golf, 1983 MK1 Golf Driver, MK4 Golf, 1971 Fastback
      09-18-2007 08:37 AM #4
      you probably have a broken abs sensor wire at your front brakes.
      Baz
    5. Member lowBUDGETveeDUB's Avatar
      Nov 12th, 2002
      Heidelberg, Germany
      '05/VW/GTI 1.8T & '09/VW/Jetta 2.5
      09-18-2007 08:43 AM #5
      Quote, originally posted by lama_daboul »
      Just a quick question....not too far off topic.....when did they change from ASR to ESP? Or are they 2 different things????
    6. 09-18-2007 08:49 AM #6
      So how do I handle this until I get the car serviced?
      Should I just turn off the ASR when I start the car or turn off the ASR when the light comes on?
      Thanks for the quick resposes...
      Is that sensor easy to repair or will I have to take it into the shop?
    7. 09-18-2007 09:08 AM #7
      Electronic Stabilization Program
      ESP can help prevent crashes and rollovers by stabilizing a vehicle at the onset of a skid. Using a variety of sensors, ESP helps stabilize the handling of the car by braking the individual wheels selectively and by automatically adjusting the engine’s output. The system works in conjunction with the anti-lock brakes and traction control systems that are already standard on every Volkswagen model.
      Anti-Slip Regulation
      Anti-Slip Regulation improves driving and steering characteristics by preventing the front wheels from spinning under acceleration. When a difference in driving wheel speed is detected, the system automatically reduces engine torque. Electronic Differential Lock uses the ABS sensors to determine if one wheel is spinning faster than the other.
      Modified by Sub-Zero Carvings at 9:15 AM 9-18-2007
    8. 09-18-2007 09:17 AM #8
      Quote, originally posted by Sub-Zero Carvings »
      so would it be better to race with asr on but with esp it would need to be off?
    9. 09-18-2007 09:20 AM #9
      Never race with ASR on. Your car will apply braking power to the engine whenever the wheels loose grip.
      ASR will stop you in the middle of your burnout comming off the line or when your car breaks loose after a hard shift.
      Just lay a brakestand before any race to heat up your tires. Warm rubber grips asphalt better than cold rubber.
      As for that sensor, try leaving it off and see how your car behaves without it. And I wouldn't imagine you could fix that yourself, unless you're a mechanic.
      Modified by hipsiguy at 6:31 AM 9-18-2007
    10. 09-18-2007 06:51 PM #10
      Well on the way home with the ASR off the problem happened again. Tranny started slamming gears, so I pulled over and restarted - fine for the rest of the trip home.
      Could I have a leak of some sort, vacuum or something...
    11. Member keystervr6's Avatar
      Dec 27th, 2006
      2002/VW/Jetta 24V VR6
      09-18-2007 06:55 PM #11
      no cel?...sound like MAF on the way out...hittin limp mode maybe
      i dunno, i've been drinking a lot already
    12. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      09-18-2007 06:56 PM #12
      esb incoporates asr, if you have esp you have to turn both of them off, it can't be one or the other (at least via the switch in the car).
      all asr does is cut the throttle. if you are seeing the warning light when accelerating it's because the car is detecting wheel slip, and cutting the thottle.
      Dave
    13. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      09-18-2007 06:58 PM #13
      Quote, originally posted by Bazmcc »
      Baz
      if the abs sensor wire was broken you would get an abs light and it would stay on.
      Dave
    14. Banned
      Feb 26th, 2006
      09-18-2007 07:06 PM #14
      wheel speed sensor..
    15. 09-19-2007 04:00 AM #15
      I may sound extremly stupid but my Jetta did the same thing and I researched and traced it to a boost leak at the DV (Stock ones notorious for failing)... swapped out the DV and never had a problem again.
      Modified by Alpha Wolf at 3:08 AM 9-19-2007
    16. 09-19-2007 07:59 AM #16
      Thanks fellas, dang thing happen twice this morning on the way in. Seems to happen when I am in traffic and the foot is on the brake for long intervals. I do have a modified dv forged007 and a stock air box.
      Well I will check all my clamps and try again, either way it as been a while since the car has been in the shop - may be time for a check up...
    17. 09-20-2007 09:24 AM #17
      I checked the clamps on the dv valve and they needed a tightening. Either way, still turning the asr light on and slamming my gears as they shift.
    18. Member lowBUDGETveeDUB's Avatar
      Nov 12th, 2002
      Heidelberg, Germany
      09-24-2007 07:12 AM #18
      Thanks a lot for breaking it down for me. Much appreciated. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member phill0046's Avatar
      Oct 14th, 2005
      South East
      1970 Karmann Ghia, Mk2 Diesel Beast
      09-24-2007 09:16 AM #19
      thats service right there
      Pelican club VIP
    20. 09-25-2007 06:11 AM #20
      When was the last time the DV was greased? Is it opening and relieving the pressure? I only stress this cause another friend of mine had the same problem on hers 1.8T on Saturday and it was also a malunctioning DV.
    21. 09-25-2007 08:17 AM #21
      I have never greased it. I check the clamps on it after a road trip and they were loose, also the valve was really hot too - is this normal?
      Is there a procedure that I can follow to grease it and with what grease?
      The weird thing is if I shut the car down and then restart everything is fine... Can you explain that?
    22. 09-26-2007 09:05 PM #22
      Quote, originally posted by 2002GLS1.8t »
      The valve getting hot is normal (unless its glowing red)
      Here are the servicing instructions:
      http://www.forgemotorsport.com/valve_service.pdf
      I can't explain why it resets when the car is turned off... probable cause there is no boost or vac keeping it open or closed. Could also be just the ECU restting itself like the problem never happened.
      Do you have VAG-COM or know anyone that does? See what kind of code its throwing.
      It is a very wierd mystery.
      Modified by Alpha Wolf at 8:09 PM 9-26-2007
    23. 07-20-2015 02:23 AM #23
      at first i thought the asr light was related to the EPC but once i fixed that w/ a fuel pump relay the ASR triangle(!) light was still on... but i do have an abs light on as well but i replaced all abs sensors except for drivers rear one... i suspect it's the wire or wheel hub splines its self... but anyways so whenever it rained while i was driving or on a hot day after it rained if i drive it for a while the abs turned off but the brake pedal started to fight like the brake booster wasnt working and yes my shrinkwrapped brake booster tube is cracked and believe it leaks right at the rubber fitting... going to have to pick up a tube tommorow maybe why the abs light won't turn off... but in NO WAY when the abs light turned off did the ASR light ever turn off while i was driving... i'll have to fix this break booster leak... hopefully it fixes the dangerous release of brake booster assist to brake pedal. Why the abs light turns off when the pressure to brake booster is released is as funny as it could be the problem for the abs light all together... but when the abs light turns off it's as if the brake pedal still works and brake booster has pressure but loses brake pressure and makes a wierd noise kind of like a quiet rumbling noise coming from the brake pedal...unless it's the abs system taking control but its all messed up sounding.
    24. 02-21-2016 12:44 PM #24
      SOOOO Close on this thread, yet so far away. I have the exact same problem.
      ASR light comes on, bad shifts, turn car off/back on magical cure but only temporary, happens again pretty soon.
      The forum author 2002GLS1.8 has this exact same problem but didn't post the solution.
      The forum contributor Alpha Wolf suggests it's related to a "malfunctioning DV" and that maybe tightening / greasing it might help.
      So, I'm hoping that 2002GLS1.8 will read this and clarify how to solve the problem.
