Page 5 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 141 to 175 of 375
Thread: mk5 Jetta/Golf 4motion conversion findings
    Oct 5th, 2004
    Sterling, VA
    2K6 1K2 BRM & 2K8 7L6 BWF & 85 19 MF
    11-24-2008 10:11 AM #141
    Two more items crossed out of the list: ABS pump/controller and ABS multi-sensor.
    Bonus feature of the ABS controller I found is Hill-Holding. Not that I really need it, but it will be nice to have it (I wish I had it in San Fran ). I need to check if it requires additional button as in Tig or it works straight forward (as in my wife's MCS).
  2. Member YoungMedic's Avatar
    Mar 21st, 2006
    Jacksonville Fl
    11-29-2008 01:01 PM #142
    so was it determined that the transfer case could be bolted to the US FWD 6MT? or would the input shaft not work?
    im glad i found this thread, i have been mulling an AWD conversion through my head for the last week or so. would the 02M 121C 4WD from the 2.0t S3 work on the GTI?
    also also you completely clarified the ?'s i had about how the Haldex controller works with the ECM.
    cheers! and good luck!
    '12 Golf R 2D Rising Blue #1026
    www.oemplus.com
    www.goapr.com
    Oct 5th, 2004
    Sterling, VA
    11-29-2008 06:55 PM #143
    Quote, originally posted by YoungMedic »
    AFAIK no.
    That should work just fine.
    No, this is still open. If my ECM will not work, I will grab 2.0L TDI CR 170HP from EU Tig 4M and swap the engine .
  4. Member YoungMedic's Avatar
    Mar 21st, 2006
    Jacksonville Fl
    11-30-2008 11:29 AM #144
    haha, way to work the problem!
    thanks
    www.oemplus.com
    www.goapr.com
  5. Member XM_Rocks's Avatar
    Jan 29th, 2005
    Austin, TX
    '07 Mazda 3 Hatch and '10 Golf
    12-05-2008 08:25 AM #145
    Subscribed...
  6. Member Pelican18TQA4's Avatar
    Dec 13th, 2000
    East Norriton, PA
    2013 Jetta Hybrid SEL Premium | 2010 GTI 6MT | 2002 Golf GL TDI 5MT | Audi R10 ;-)
    12-05-2008 01:36 PM #146
    Skimmed through this very interesting thread and didn't see this mentioned, but another reason the R32 rear pan is different is becasue the battery is in the trunk. Not sure if this is the same with other 4Motion MkVs.
    Oct 5th, 2004
    Sterling, VA
    12-05-2008 01:52 PM #147
    Quote, originally posted by Pelican18TQA4 »
    2nd page:
  8. Member Pelican18TQA4's Avatar
    Dec 13th, 2000
    East Norriton, PA
    12-05-2008 01:54 PM #148
    Saw the pic, didn't see any reference to the battery. My mistake!
  9. 12-12-2008 05:18 PM #149
    Good luck on the project! I'm looking forward to seeing the finished product.
  10. 12-12-2008 08:06 PM #150
    Wow, I remembered this thread from when it started, but I'm glad that you've been finally making progress!
    So why are you going with a dual mass flywheel instead of a single mass? If there isn't a difference in flywheels and clutches between FWD and AWD transmissions, then you should be able to use a G60 flywheel and VR6 clutch. Most people over at tdiclub.com would probably suggest this over a dual mass flywheel. I'm mostly curious, as these would be easier and cheaper to get than the ones from a PD170, though it looks like you've already got them.
  11. Member
    Oct 5th, 2004
    Sterling, VA
    12-12-2008 10:35 PM #151
    Quote, originally posted by Berlinetta Boxer »
    The mayor reason is PD170 (and all PD100, PD140) in mk5 Golf/Jetta paired with 6MT tranny use 240mm clutch. G60/VR6 is 228mm.
    The other reason are vibrations from SMF.
    I am planning to keep my G60/VR6 setup just in case I decide to go back to it, but at this point I want to try PD170 DMF/clutch.
  12. Member rallydiesel's Avatar
    May 10th, 2006
    SK
    2006 Jetta TDI, 2001 Golf TDI, 1991 Jetta TD (sold)
    12-12-2008 11:01 PM #152
    I admire your DIY-ness but if I was looking for an AWD TDI, I would wait for an xdrive BMW 335d or a 4motion 170 hp Passat CC.
    Once you go "clack", you never go back.
  13. Member
    Oct 5th, 2004
    Sterling, VA
    12-12-2008 11:59 PM #153
    Quote, originally posted by rallydiesel »
    And I would wait for R8 V12 TDI .
    Not sure if 335xd will ever come to US. Plus it will most likely be in auto only. Same with CC: current gasser vr6 is sold with auto (not-DSG) only. The stupidest configuration ever invented.
    But I would love Audi A4 Avant with V6 TDI 6MT AWD. The day it hits this shore, I wrap up my Jetta and let it go.
  14. Member R32dreamer17's Avatar
    Oct 11th, 2007
    Central Coast
    2012 DBM GTI
    12-13-2008 02:51 PM #154
    hey i'm the dude who lives in cville and asked about a month ago or so if i could come see your project in sterling. looks really cool just wonderin you'd still be down to let me see it.
  15. Member
    Oct 5th, 2004
    Sterling, VA
    12-13-2008 06:47 PM #155
    IM sent.
  16. Member R32dreamer17's Avatar
    Oct 11th, 2007
    Central Coast
    2012 DBM GTI
    12-13-2008 07:34 PM #156
    saw you im'd me. not quite sure when. I can let you know tomorrow probably and then I guess we'll also see when would be convenient for you.
  17. 12-15-2008 11:59 AM #157
    Wow, this looks great, I had thought about this on my GLI but did not have the money or time, can't wait to see this finished.. great work so far.
    Ryan Gravelle
    club.broke.status : flickr
  18. Member
    Oct 5th, 2004
    Sterling, VA
    12-31-2008 09:33 AM #158
    I was able to locate the 4M TDI fuel tank real cheap. The problem is this thing is big, so my carrier will not be able to bring it here. Any leads for how to have it shipped here in the least expensive way are highly appreciated.
    Anybody stationing in EU, who plans to come back soon and could help me with that?
    Modified by maloosheck at 9:38 AM 12-31-2008
  19. 01-16-2009 11:37 AM #159
    any updates? Great project!
  20. Member
    Oct 5th, 2004
    Sterling, VA
    01-16-2009 10:39 PM #160
    Quote, originally posted by Gotsol »
    Not much. Have a bunch of stuff to ship from EU and looking for the most inexpensive option. Once it all is here, I should be able to start tranny swap.
  21. 01-17-2009 02:31 AM #161
    A+++ on this project. You should get a PhD in Volkswagens when you're done with this. I was thinking of doing a 4-motion GTI myself, and your thread has encouraged me even more. Anyway you can post a gathered list of all the parts you would need? Also, how are you setting the coding? With a normal ROSStech VAG cable?
    07' VW GTI TR. APR Edition 30 K04 & S3 injectors with full flash, Turbo back RSC, Neuspeed intake, APR Intercooler, Neuspeed throttle pipe, Forge DV, Neuspeed pulley, APR HPFP, VF Engineering full mount kit, H&R 28mm Front/24mm Rear sway bars, Neuspeed sway bar endlinks, Koni FSD's, H&R Sport springs. Minor cosmetic just to make her look good, but keep the cops from looking twice...
  22. Member
    Oct 5th, 2004
    Sterling, VA
    01-25-2009 10:51 AM #162
    Quote, originally posted by Hello Bob »
    As soon as I finalize the project, the parts will be listed. At this point it is hard to determine if I still need anything else.
    Now, this is an excellent question, but I do not know the answer. Everything can be coded with VCDS, but the list of modules that need to be recoded is still unknown.
  23. 01-26-2009 02:27 AM #163
    Bro- you're my hero. I will reward you with my hot asian wife after this project is over.
  24. Member
    Oct 5th, 2004
    Sterling, VA
    01-26-2009 09:11 AM #164
    If my wife reads that, the project will never be finished, because she will kill me first .
  25. 01-26-2009 01:59 PM #165
    Quote, originally posted by maloosheck »
    If MY wife reads that, I won't be able to read the rest of your write ups!
  26. Member
    Jun 1st, 2002
    YUL
    '01 Wolfie, '08 Rabbit
    02-17-2009 11:10 PM #166
    any updates?
  27. Member
    Oct 5th, 2004
    Sterling, VA
    02-17-2009 11:24 PM #167
    Quote, originally posted by Teknojnky »
    any updates?
    Hopefully by the end of March I should have all I need for tranny swap in my hands.
  28. Member jaah's Avatar
    Dec 29th, 2006
    Finland
    2007 VW Golf 2.0TDI 4motion, 1992 Golf 1 Cabriolet, Polo classic -84, Jetta CL 1.5 AT -83
    02-26-2009 01:58 AM #168
    Hi..
    I found some weird oil leak (maybe) from bevel box.
    http://tos.pp.fi/images/album/vuoto/
    ^It needs / to the end, and then the adress should work.
    Did you have any pictures; if there is some kind of breather tube or something in bevel box or gearbox?
    I checked oil levels: normal
    Thanx
    ps. I also updated my front bumber:
    http://tos.pp.fi/images/album/puskuri//
    Modified by jaah at 9:00 AM 2-26-2009
    Modified by jaah at 9:25 AM 2-26-2009
  29. Member
    Oct 5th, 2004
    Sterling, VA
    02-26-2009 09:31 AM #169
    Quote, originally posted by jaah »
    http://tos.pp.fi/images/image/vuoto/DSC00104.JPG
    What is this wire connected to? Oil level sensor in the oil pan?
  30. Member jaah's Avatar
    Dec 29th, 2006
    Finland
    02-26-2009 10:54 AM #170
    Yes thats it
  31. Member jaah's Avatar
    Dec 29th, 2006
    Finland
    02-26-2009 12:38 PM #171
    I found this from etka, 5B
    There is a breather.
    Maybe I have just a little hope, and it was frozen and then just a few oil comes out.
    Modified by jaah at 7:42 PM 2-26-2009
  32. Member
    Oct 5th, 2004
    Sterling, VA
    03-02-2009 09:46 AM #172
    Update: ok, I found a fuel tank and a shaft. And Rich from oempl.us offered his help with shipping everything to US. The last parts missing are rear hubs, which I can source here.
    So hopefully next winter / snow driving will be easier with a little help of 4Motion...
  33. Member EL_3grab's Avatar
    Mar 25th, 2006
    AJ - UAE
    MK5 GTI
    03-03-2009 06:59 AM #173
    All the best
    • Agent 47 Drives a Golf ..
  34. Member Zupek's Avatar
    May 10th, 2000
    Hell has frozen over, WI
    2000 Stage 3+ Audi S4, 1998 24v 3.1L Syncro'd GTi w/ 6speed quaife add-on, 1988 Quantum Syncro Wagon
    03-03-2009 05:42 PM #174
    sorry if this is common knowledge already, but you'll need the front diff out of a AWD car and if you use a FWD bell housing, you'll need to rip it all down and swap the AWD front diff in....
    Again sorry if its common knowledge I just ran through this with my syncro... I put O2J gearset in my 02c.
    My 24v 3.1L Syncro Mk3 build here
  35. 03-04-2009 01:49 PM #175
    pm sent
