VWVortex.com - Can anyone complete this German word?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 26
    Thread: Can anyone complete this German word?
      Dec 27th, 2005
      Burr Ridge, IL
      81 S, 84 GTI, 86 16V, 92 Cabby
      09-30-2007 09:29 PM #1
      This is for the sticker on the fan motor of an 81 S.
      Surprisingly, my German wife, nor her folks were able to complete the word
      Anyone?
      Thanks in advance!
      Work: it works, ibtches.
    2. Member My Old Roc's Avatar
      Aug 14th, 2003
      Kashyyyk
      78 Scirocco MK1 8 Valves of Furry Fury
      09-30-2007 09:45 PM #2
      Dunno the missing letters there on that sticker...
      All I know is everytime I checked the brake fluid on the Jetta, I was offended!
    3. Member Nataku's Avatar
      Dec 25th, 2005
      Andover, Minn.
      1980 VW Scirocco
      09-30-2007 09:55 PM #3
    4. 10-01-2007 12:18 AM #4
      On the '84 it is "nahentstört."
    5. 10-01-2007 12:24 AM #5
      Quote, originally posted by My Old Roc »
      lmao... never bought *** bearings?
    6. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      Scirocco 16v, E34 540i, V50 T5 AWD
      10-01-2007 12:53 AM #6
      I would guess it translates to "approach w/ caution"
      nahen = to approach
      stören = to disturb or interfere
      The blues ain't nothin' but a good man feelin' bad.
      Tschüß Gilda, Hallo Birgit
    7. Member superloaf's Avatar
      Aug 4th, 2005
      Los Angeles
      87 scirocco 16v, 86 porsche 944 turbo, 77 alfa romeo alfetta sedan, 87 alfa romeo milano
      10-01-2007 02:33 AM #7
      Quote, originally posted by 1sciroccofahrer »
      i got a bad case of "nahenstort" from some hoochie in berlin a while back . . . .
      87 Scirocco 16v-9A block.PL head.Delta cam.TT exhaust.8lb. FW.Peloquin 80% LSD.22 & 25mm ST Swaybars.Bilstein Sports.400# F & 350# R DIY coilovers.Poly bushings.Porsche 16x7&8 Phonedials.Falken RT-615k 205/40-16.Powerslot Rotors.Hawk HP+ pads.SS brk lines.Porsche Carrera steering wheel.euro lights
      Build Thread:http://forums.vwvortex.com/showthrea...&daysprune=365
    8. Member 16V_Scirocco_GTX's Avatar
      Jul 18th, 2001
      In the 94086 California
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTI
      10-01-2007 02:39 AM #8
      It has to do with electronic interference. The fan motor was built so that it doesn't cause it. Same thing for the wiper motors I believe ... otherwise, you turn on the fan when the radio is on and you get noise.
      Tobias
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTi
    9. Member Michael Bee's Avatar
      Nov 4th, 2004
      City of Poughkeepsie
      1980 Scirocco | 2015 528xi | 2016 328xi GT
      10-01-2007 08:40 AM #9
      If you were in England, it could also mean that you are asking for a cigarette.
    10. Member Kar98's Avatar
      Apr 20th, 2002
      Not Fancy DFW
      2011 Naruhito Zelas
      10-01-2007 09:30 AM #10
      Quote, originally posted by CodeMan »
      nahen = to approach
      You would guess wrong though.
      On the other hand, I don't read it as "nahentstört" either.
      Nowdays us made cars what you're proud of
    11. 10-01-2007 09:43 AM #11
      It should read nahentstört, meaning not causing interferences within a small distance.
    12. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      10-01-2007 02:16 PM #12
      Quote, originally posted by Stormee »
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] I'll go with this guy's translation.
      Ich bin kein Berliner
    13. 10-01-2007 02:24 PM #13
      Ich auch nicht!
    14. 10-01-2007 04:23 PM #14
      I guess my only question is why it's "nahenstort" when on the label it starts with "NE---"...
    15. 10-01-2007 04:43 PM #15
      hi
      donno how to explain but if you here something in the radio. like your rpm or something you must "entstören" it
      The sign means that its suppressed (thats the word i found ) !!
    16. Member
      Dec 27th, 2005
      Burr Ridge, IL
      10-01-2007 05:04 PM #16
      Thanks, I'll bet it's Nahentstort.
      I thought the second letter was an "e". It was faded, so I wrote over it.
    17. Member
      Dec 27th, 2005
      Burr Ridge, IL
      10-01-2007 08:36 PM #17
      OK! Thanks for the info folks.
      Here is the final result:
      I tried a new way of reconditioning the sticker:
      I kept the original sticker since most of it was good. I wiped off the worn "nahentstort" with gasoline, leaving a clean canvas.
      Then I printed "nahentstort" on Microsoft Word many times, playing with the font 'till I got tired of it.
      Then I printed the final result on paper. I covered the word with two layers of Scotch tape, reloaded the paper into the printer the same way, and printed the word onto the tape.
      I let the ink dry and covered with a third layer of tape.
      Then I peeled off the outer two layers, so that the ink is sandwiched between two layers of tape. The third layer was just to keep the new "sticker" from sticking to the paper.
      Trim the "sticker" and apply, taking care to handle it only with a blade. No fingers (fingerprints).
      I think it came out pretty nice!
    18. 10-01-2007 08:43 PM #18
      Das ist sehr gute!!!
    19. Member Kar98's Avatar
      Apr 20th, 2002
      Not Fancy DFW
      2011 Naruhito Zelas
      10-01-2007 09:03 PM #19
      Holy crap, I thought I was anal.
    20. Member
      Dec 27th, 2005
      Burr Ridge, IL
      10-01-2007 09:08 PM #20
      You may be anal, but I doubt as bad as me!
      Here is the entire engine bay, I think worth the effort in details:
      The car is all original.
    21. Member tmechanic's Avatar
      Nov 17th, 2004
      Western WI
      '85 Scirocco Wolfsburg, '86 Scirocco, '88 cabby, '73 MGB-GT, '73 International Travelall
      10-02-2007 10:49 AM #21
      Ich bin ein Berliner
      I am a jelly doughnut?
      "Imagination will often carry us to worlds that never were. But without it we go nowhere."
      Carl Sagan 1934-1996
    22. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      10-02-2007 11:43 AM #22
      Quote, originally posted by tmechanic »
      You've misquoted me.
      I have denied all pastry-ness
      (Ich bin kein Berliner)
      Ich bin nicht so dumm wie deinen typischen Auslander.
      Proesten fur den Vaterland
      My apologies for any grammatical errors in my German
    23. Member Fein1's Avatar
      Mar 8th, 2002
      Chicago
      77 Rabbit
      10-31-2007 10:10 PM #23
      Quote, originally posted by echassin »
      Still pretty dirty up by the rain tray...
    24. 11-07-2007 08:40 PM #24
      DOes anyone know how to say "Baby Blue" in german? I found words for Baby and the word for blue but I am sure there is some mash of the two words...
    25. Member first_rocc's Avatar
      Apr 9th, 2005
      San Diego, California
      11-07-2007 09:14 PM #25
      Quote, originally posted by _Absorb_ »
      Many years ago in high school German, "baby" auf Deutsch was Sauegling. Today, the Germans I know just use "baby" whether speaking English or German. Blue is "blau", BTW.
