Page 27 of 45 FirstFirst ... 17 23 24 25 26 27 28 29 30 31 37 ... LastLast
Results 911 to 945 of 1575
Thread: Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion
  1. 07-25-2012 01:40 PM #911
    What gauge of wire is best for using for different parts of the bay? And single core/multicore?
  2. Member ascgti89's Avatar
    Jan 30th, 2006
    The Souf
    The Chariot
    07-25-2012 03:55 PM #912
    Quote Originally Posted by Paulbag View Post
    Always use stranded wire. For wire gauge, use the same or one size bigger for whatever your lengthening.
    ES.AD
  3. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    07-25-2012 05:54 PM #913
    Yup. If you have a scrap yard go strip a harness and use OEM. To save the headache I sourced a front-back R32 harness for my project. All wiring is OEM which I really enjoy.
    Quote Originally Posted by ascgti89 View Post
  4. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    07-27-2012 12:08 AM #914
    Slooooowly. Also please excuse the dust, dirt and scratches. The entire bay and all accessories are being repainted... Again haha.
  5. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    07-28-2012 03:41 PM #915
    Could not deal with the gross reservoir.
    Don't mind the alloy lines and blue tee, this was just a test fab. Will do in SS with a black tee. Ordered a remote res that will sit behind the booster.
    Bay is sooooo gross and dirty though
  6. Junior Member
    May 7th, 2012
    France
    1998 golf 4 gti 20v -- 2009 fiat 500c
    08-03-2012 01:37 PM #916
    That s mine in progress, just a half-shaved bay, primer is done, now waiting for a nice day to paint
    ice skater do triple axels without any grip
    my GTi http://forums.vwvortex.com/showthrea...d-with-GT3071r
  7. Member redkid's a4's Avatar
    Mar 3rd, 2009
    socal
    03 gti 1.8t
    08-03-2012 02:33 PM #917
    my bay not the best work but i satisfied for a 1st timer
    candy&cane
  8. Member VentoMKIII's Avatar
    Feb 24th, 2008
    Alburtis, PA
    1995 Jetta
    08-04-2012 12:42 AM #918
    Where would i go about locating the ecu if i wanted to cut out and shave my cal too?
    FIND IT OR GRIND IT
  9. Member DuB fresh's Avatar
    Jun 17th, 2009
    New Hartford CT
    tropic gti
    08-04-2012 01:37 AM #919
    finally some mint shots of my bay.
    Quote Originally Posted by ventoCL View Post
    bags dont counts. never have, never will.
    CORNSTATUS
    My Shaved bay Build
  10. Member mooseinabox's Avatar
    Dec 4th, 2011
    Northeast Ohio
    Rabbit Truck, GS500F, YZF600R
    08-04-2012 03:05 AM #920
    ^ doesn't get any better than that. perfect.
  11. Member namrekcad's Avatar
    Mar 24th, 2011
    mi
    2005 gti
    08-06-2012 07:44 AM #921
    love that last photo
    nice job
    NamrekCad Design LLC
    Custom GTI Parts
    spike antenna, polished strut caps
    3D Cad Design and manufacturing
    Feb 8th, 2011
    New Hampshire
    00 gti
    08-06-2012 08:05 AM #922
    That bay is seriously amazing.
  13. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    08-06-2012 08:13 AM #923
    guess i can leave this in here...
  14. Member Dameon's Avatar
    Oct 5th, 2008
    Michigan
    2001 jetta, 1999 passat
    08-06-2012 09:11 AM #924
    Quote Originally Posted by fouckhest View Post
    You build is simply superb. I liked it as a 1.8t but so much more now with the TDI. I have yet to see interior pics since the rebuild I am curious to what changes happened there.
  15. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    08-06-2012 10:04 AM #925
    Dude... seriously good looking out on the shaved bay TDI
  16. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    08-06-2012 11:13 AM #926
    Quote Originally Posted by nebio_b5 View Post
    thanks man...not a whole lot, it is still very bare....recaro gt3 seats, harnesses, cage and CAE shifter was the biggest update...
    Quote Originally Posted by arethirdytwo View Post
    thanks!
  17. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    08-06-2012 12:16 PM #927
    I'm wires tucking the driver side of my 1.8t. I don't want anymore wires to go through my firewall. Where can I run these wires and make them back into the car without using the firewall?
    FrankenTurbo F21, CTS Frount mount, Genesis 550cc, Bosch 044, Wiseco pistons, IE Rods, all held together with ARP, 3" 42DD TBE, 2 quarts of my blood, Southbend Stage II, Peloquin LSD, taken care of with Eurodyne ME7.
    Contact Mike P. @ Stevebilt for anything you need.
    Quote Originally Posted by joemiller1989 View Post
    I was pooping when I read this I laughed so hard I couldn't stop pooping
  18. Member BoraRJTI's Avatar
    May 13th, 2010
    DYT
    03 Bagd.:R18 JTI
    08-06-2012 02:02 PM #928
    Quote Originally Posted by MrAkalin View Post
    Pull back the carpet and find where the frame rails come into the car, from what ive read on here its pretty distinct where they are, drill through into them and run ur wires there, someone please correct me if im wrong
    YEAH I'M A WHORE, SO WHAT!!!
    v2lab
    Hella 4
    Air Society
  19. Junior Member
    May 7th, 2012
    France
    08-06-2012 03:25 PM #929
    Quote Originally Posted by BoraRJTI View Post
    i did like that for the moment
  20. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    08-06-2012 03:51 PM #930
    Sounds like a lot of work.. This is my first wire tuck and I've got all the harnesses separated but now I'm overwhelmed and stuck here..
    I can't figure out where to run anything.
  21. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    08-08-2012 11:02 AM #931
    Alright, let me get this right.
    This harness gets pulled through so it's inside the car, then there is a whole drilled and I put them through along the frame rail. Are they along the frame rail or actually inside?
    Then this harness stays in the rain tray and runs in the fender
    Then lastly the engine harness (with the injector sensors, coil pack sensors, ect) goes along the rain tray and through the fender?
    Also, where is a good place online to order heat shrink from? And how much should I buy? Yes I know I can get it at auto stores and such, I'd just rather order bulk amount online.
    Thanks!
  22. Member
    Feb 8th, 2011
    New Hampshire
    00 gti
    08-09-2012 06:28 AM #932
    Their actually inside, it sucks. Idk why it was so hard for me, but others seem to have better luck.
  23. Member Dub'dRite's Avatar
    Jul 16th, 2007
    Central Fl
    RIP 02 VR6 Jetta, 05 Lagoon Blue GLI, 99.5 2.0 "Super White" Jetta Shaved Bay...Votex Kit'eddd
    08-09-2012 12:48 PM #933
    Thanks!
    alot of patience and a coat hanger help to get it through the frame rail..
    also remove as much of the harness that is not going to be used so you dont have to pull that through too...less wire easier pulling.
    and seperate your main harness and your engine harness and run them seperate. I even made two seperate holes for them. One for the main so that it drops down behind the abs and one for the engine harness and it drops down above the brake fluid reservoir, then you can tuck it behind booster and up the coolant hoses
    ...ohh and it might help you if you pull your wiper motor just so it's not in your way.
  24. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    08-09-2012 04:22 PM #934
    Quote Originally Posted by Dub'dRite View Post
    That post actually helped me a good amount. I have the engine harness totally out of the car, like its sitting on a bench. I haven't even looked at that yet. What do I do with this? Like unplug it or what, I don't wanna screw with it if I don't know what it is or how to take it apart. It's in the rain tray on the driver side.
  25. Member ascgti89's Avatar
    Jan 30th, 2006
    The Souf
    The Chariot
    08-09-2012 04:32 PM #935
    Under that cover is a bunch of multicolored plugs, these plug into the dash and chassis harness. you run the abs harness wires and such thru that cover. You can drill a hole in the cover and run the wires thru and then connect them back together to the abs harness and such in which you ran into the frame rail and came out by your feet under the dash.
    ES.AD
  26. Member Dub'dRite's Avatar
    Jul 16th, 2007
    Central Fl
    08-10-2012 11:00 AM #936
    ^^this
    and like I said before remove that wiper motor assembly and then you can pull that plastic cover off and see what your getting into...depending on the model and features there's only a few multicolored plugs in there that you can disconnect if need be to help move things around
  27. Member Elvir2's Avatar
    Nov 19th, 2007
    HOTLANTA-thats right i said it.
    08-10-2012 11:28 AM #937
    Who is interested in starting a new project. Complete Master brake cylinder/booster tuck. Nothing in the bay..
    Would like to gather some ideas. Ive seen it done on mk1s but they have plenty of room under dash.
    Elvir
    '81 Simple-Build-PIKMEUP-VR6
    '01 Simple-Build-SpeedyVW-V1.8
    '04: .:R32 Daily Driver...Raw Fun?
  28. Member Dub'dRite's Avatar
    Jul 16th, 2007
    Central Fl
    08-10-2012 12:13 PM #938
    Quote Originally Posted by Elvir2 View Post
    Elvir
    Sounds legit...
  29. Member
    Feb 8th, 2011
    New Hampshire
    00 gti
    08-11-2012 06:06 PM #939
    I'm still trying to work on deleting the abs. Does anyone know what I need from a mk3? And which mk3 I need them from. My abs is already messed up. I'd love to just get rid of it completely.
  30. Member BoraRJTI's Avatar
    May 13th, 2010
    DYT
    03 Bagd.:R18 JTI
    08-11-2012 06:27 PM #940
    Elvir
    I would be interested but how exactly u plan to do this? The problem wouldn't be relocating it, it would be checking and filling the fluid, I think
    v2lab
    Hella 4
    Air Society
  31. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    08-11-2012 06:41 PM #941
    They already exist. Hot rod guys have used them for years. Just need to make room behind the dash.
  32. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    08-14-2012 11:08 PM #942
    Ok, so this harness is the last harness that's left in the, so my is my next step to cut the harness and pull it through? Btw, my dash and seats are out.
  33. Member
    Feb 8th, 2011
    New Hampshire
    00 gti
    08-15-2012 06:06 AM #943
    Yikes! That scares me, what do u mean cut the harness? Which way r u going about relocating them?
  34. Member Elvir2's Avatar
    Nov 19th, 2007
    08-15-2012 07:26 AM #944
    Quote Originally Posted by yeabmx View Post
    Wire tucking and ABS deleting is not a job for the weak hearted. You have to have some basic knowledge before you move forward. If you did not know that you have to cut harness, i dont think you want to proceed with this. There is so much involved that if you make a mistake and dont know what youre doing, you may never get your car up and running again.
    Elvir
  35. Member
    Feb 8th, 2011
    New Hampshire
    00 gti
    08-15-2012 08:51 AM #945
    Oh I know, I've already done it. I extended one of them and re-ran the other two. But him looking at all those wires n just saying "I need to cut this" made me worry for him haha.
