Page 2 of 44 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 1536
Thread: Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion
    Feb 11th, 2003
    Winchester, VA
    10-07-2007 08:14 AM #36
    Some of the things I've done to clean up the bay:
    Relocate battery to rear
    remove N249 mess, relocating some hoses to fender well
    re-routing hoses along firewall to inside rain tray
    relocate overflow tank to driver's side to shorten hoses
    remove vacuum reservoir
    remove and block-off combi valve
    remove air pump
    remove all plastic covers and unused metal brackets
    remove washer bottle
    remove A/C compressor and hoses
    re-route brake booster hose
    Despite all that work, no one even notices when I pop the hood. The trouble is, there is still a lot of extra stuff under there. Word to the wise, if you're gonna do it, go ALL THE WAY.
    Nov 22nd, 2006
    Norfolk va
    24v vrt
    10-07-2007 11:16 AM #37
    question to those who have not retained the stock ecu and shaved everything. what are you doing for an alarm system?
  3. 10-07-2007 01:38 PM #38
    Quote, originally posted by RabbitsKin »
    remove air pump
    Do you have any pictures of your bay? Your list is exactly what I am planning to do this winter.
  4. Member
    Feb 11th, 2003
    Winchester, VA
    10-07-2007 02:20 PM #39
    Never been much of a picture taker on my own rides, unfortunately.
  5. Moderator j. Kush's Avatar
    Apr 3rd, 2002
    NoVA
    V8Kompressor, 1.8T
    10-07-2007 04:47 PM #40
    Well it doesn't have to be a fantastic, bordered and watermarked pic. Just point and shoot so we can get the idea.
    Modified by j. Kush at 4:45 PM 10-7-2007
    -jarredK
    FunKtion Auto - European Tuning & Service in Northern VA
    034 Motorsport | AWE-Tuning | Eurojet | Forge | HRE | KW | Motul | Quaife | Revo | Rotiform | STaSIS | SPM
  6. Member ex-vtak's Avatar
    May 11th, 2007
    AZ
    04.5 Jetta GLI
    10-07-2007 07:16 PM #41
    to OP: thanks for starting this thread. we honda people love this stuff, sometimes my buddies ditch AC/PS, and remove ABS in pursuit of this look.
  7. Moderator j. Kush's Avatar
    Apr 3rd, 2002
    NoVA
    V8Kompressor, 1.8T
    10-07-2007 07:44 PM #42
    Quote, originally posted by ex-vtak »
    haha. i'm not sure if you are being sarcastic, but on a daily driver it is a pretty pointless mod to do. and i think most people realize this which is why its a relatively rare mod, not because it is so hard to pull off.
    i can maybe see rerouting the battery to the trunk, removing some of the unncessary vac. hosing, and relocating some other stuff to clean things up a bit, but people should be cautious not to go over the top with it on a daily driver...
    i do think it looks good though, and i'd personally like to see somebody do it on a Jetta.
    ventodan's VRT:
    Modified by j. Kush at 4:49 PM 10-7-2007
    -jarredK
    Nov 7th, 2002
    Oakland CA
    1965 Lincoln Continental
    10-08-2007 07:51 PM #43
    HEY this is a TON of work. It shouldnt be alowed for there to be a walk through on how to do it! then all us that did the research and fingered out how to do it on our own are all for naught.
  9. Member dragon813gt's Avatar
    Feb 18th, 2003
    Ruining VWs one car at a time
    '04 GTI that has rolled maybe 60' since September of '06
    10-08-2007 08:05 PM #44
    Quote, originally posted by The Prime Ministah »
    You fingered it out
    I udnerstand where you're coming from Drew. But did you figure out everything by yourself? Or did you have some help along the way. If you did everythng by yourself then you can say whatever you want. But if just one thing that you did was suggested by someone else then you have no case to want to keep it private.
    This isn't something that's going to be done by everyone. It's beyond the capability of most people. Both mechanically and financially. It's a lot easier on VR6s. This has been proven time and time again. There is just less to remove.
    And IMO, the slew of MKIIs that redid their firewalls did it the correct way. Make the bay as simple as possible. I don't even know if this is possible on a MKIV. But the rain tray should definelty be removed like Lag did. When you do this you should extend your hood up so you don't have a huge gap where the tray used to be. I added something to this thread that I shouldn't have done. I'm wondering how many people had even though of doing this to make it look correct. This is the only idea I'm sharing
  10. 10-08-2007 08:07 PM #45
    after looking at those i was wondering what people did about the huge gap that would be left once the rain gutter is removed.
  11. Member dragon813gt's Avatar
    Feb 18th, 2003
    10-08-2007 08:12 PM #46
    Gap
    Easily fixed and it's one of those details that is overlooked.
  12. 10-08-2007 08:16 PM #47
    wat do they do just move up the hood a little bit? and doing that is one of those that just shouldnt be done to a car thats daily driven, i personally would only do that to my car if i knew that i would no longer be my only source of transportation. but thats just me i guess. lol
  13. 10-08-2007 10:15 PM #48
    Quote, originally posted by dragon813gt »
    You fingered it out
    Nuff said, A DIY or Even a walk through will not hurt anything... It’s not like everyone is going to run out and attempt this...
  14. Member dragon813gt's Avatar
    Feb 18th, 2003
    10-08-2007 10:41 PM #49
    Quote, originally posted by vdubtornado »
    The hood has just been left the same. That's why there is the large gap. You need to weld on an extension at the top of the hood. It's no exactly easy but it's not the end of the world. Especially if you just removed the firewall
    Quote, originally posted by ftratrny »
    You won't ever have either. A DIY is out of the question. And a walkthrough is just to much. There are to many steps and custom bit of fabrication that need to be done. Every car is going to be done diffrently. This is definetly the case w/ a 1.8T where there are so many diffrent levels of tune due to turbos and the such.
  15. 10-08-2007 10:56 PM #50
    Let me rephrase, tips will not hurt anything as this is not something that everyone can or will attempt. :
  16. 10-08-2007 11:20 PM #51
    Quote, originally posted by Elvir »
    i love this engine bay
  17. Member
    Nov 7th, 2002
    Oakland CA
    10-09-2007 05:07 PM #52
    why not just remove the Vac Res?
    And is appears like Joosey kept his Evap system.... so I dono to what extent he went with is...
  18. Member dub-Nation's Avatar
    Jan 31st, 2001
    Moorpark, CA USA
    MK6 Golf TDI, T4 Eurovan V6, MK4 JTi 1.8T, MK6 Jetta S (FOR SALE)
    10-09-2007 05:39 PM #53
    Great Idea!
    Bernie M Chacon III
    dub-Nation.com ~ for the love of the veedub.
    Follow Me on Facebook | My Projekt MK6 Build | Oktoberfest Show
  19. Member dragon813gt's Avatar
    Feb 18th, 2003
    10-09-2007 08:28 PM #54
    Quote, originally posted by dub-Nation »
    Great Idea!
    So that's what's taking so long
  20. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    10-09-2007 08:36 PM #55
    what is a tucked engine bay?
    wanted: early MK2 Golf or Jetta GTD rear badge -- any reasonable condition
    click
  21. Member dub-Nation's Avatar
    Jan 31st, 2001
    Moorpark, CA USA
    10-09-2007 09:51 PM #56
    I wish.
    Quote, originally posted by ducatipaso »
    The wires are tucked/hidden.
    Bernie M Chacon III
  22. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    10-09-2007 09:52 PM #57
    wow talk about random use of a term thats thrown all over the place
    click
  23. Member Raek's Avatar
    Aug 1st, 2003
    2001 TT225 / 2002 BMW 330ci / 2000 XJ
    10-09-2007 10:03 PM #58
    i'd like to see pictures of where things are relocated to.
    i mean...we always get to see the bays and such...but, never any pics of "behind the scenes"
  24. 10-09-2007 10:21 PM #59
    i agree, no one is going to be trying this that isn't prepared for what they are starting, this is one of the hardest things you can do on new cars, and a few tips to someone doing it would be great. it think its ridiculous that people who have done this hide there information like its a secret.
  25. Moderator j. Kush's Avatar
    Apr 3rd, 2002
    NoVA
    V8Kompressor, 1.8T
    10-09-2007 10:43 PM #60
    Quote, originally posted by Raek »
    x2, but I think the majority of the things aren't relocated, but completely removed...
    -jarredK
  26. Member dragon813gt's Avatar
    Feb 18th, 2003
    10-10-2007 05:56 AM #61
    Quote, originally posted by j. Kush »
    On a 1.8t this is definely the case. The few things your relocate are behind the dash or in the trunk(battery). Pictres of the wires tucked up in the frame rail won't show you much. It's esy to understand when you physically see the bay w/ nothing in it.
  27. 10-10-2007 06:19 AM #62
    This looks like it should be a real useful thread.. nice going Elvir
    This bay is one of my favourite out there:
  28. Member Raek's Avatar
    Aug 1st, 2003
    10-10-2007 07:26 AM #63
    yeah, i noticed that with savwko's SAI removal thread...i was just wondering like...on these COMPLETELY shaved bays, things such as washer fluid, go.
    but, i'm guessing since these aren't daily drivers, most of this stuff is totally unused...
  29. Senior Member tchristemac's Avatar
    Feb 4th, 2005
    East Islip, NY
    Tooo Many to list
    10-10-2007 08:15 AM #64
    I am really thinking of undertaking this, I am really looking for a LONG winter project and take my time doing it!
  30. Member thelmuffinman's Avatar
    Jun 5th, 2007
    Orlando, Fl
    2003 Vw Gti, 2001 Vw Jetta Vr, 2005 V8 Touareg
    10-10-2007 09:51 AM #65
    Weird that this thread just showed up after this topic being the only thing that wouldn't leave my head for about the past two weeks.
  31. Banned FAIL's Avatar
    Dec 8th, 2005
    10-10-2007 10:10 AM #66
    Sav,
    Paint the caps of the coolant and washer fluid resoviors gloss black.
    KTHX!
    but seriously, very small detail, but I think it would look much better
  32. 10-10-2007 11:41 AM #67
    Quote, originally posted by gENERIX_ »
    It's posted earlier too, post turbo build.
  33. 10-10-2007 12:05 PM #68
    [/QUOTE]
    How much Hp does this have????
  34. 10-10-2007 01:53 PM #69
    Quote, originally posted by movement »
    Enough to put a smile on your face. How much more do you need?
    I haven't seen it since CVO Treffen 2006. Amazing car.
  35. 10-10-2007 04:47 PM #70
    Quote, originally posted by skatingzooyork »
    i have a similar bay... battery is still in stock location and ac still intact..
    not a smooth bay at all. i would say clean up a bit. im gonna take it into the "smooth" realm this winter hopefully
    Modified by rice X eater at 1:51 PM 10-10-2007
