This looks good. Easy, too. Bump this into my watched topics for a good winter project.
#1
I thought I made this thread before, but I couldn't find it for the life of me. Besideds, I took more pics...This set is for 85Spraybomb. I am no longer making them for people though. Sorry. BTW - there was a $5 surcharge -because Freeland, PA is a NOWHERE rural area!
Tools: Lighter, Box Cutter, hammer crimper, Cutter things for the cables, and the BFH.
Supplies: Battery clamps, those corrosion prevention pads, 6" of 3/4" heatshrink.
And the cable. I used 4 gauge marine grade ANCOR cable I got from some guy on eBay. I actually bought WAY WAY too much, so measure your cables out with string or whatever before you order. Leave a bit of slack to work with.
Strip the wires after you cut them with the box cutters
So now we have about 1/2" stripped off.
Now, put the liug and the wire into the crimper. You want to put the lug in there so that the crimper's silver part will hit the back of the copper terminal - the flatter side. That makes it much nicer than hitting the front.HAMMERTIME!
Here's what the crimp looks like:
Now, get out your heat shrink, and cut it into 1" sections. Mine came in 3" pre-cut sections from the hardware strore.
Put the section of heat shrink on it..
and BURN it on!
Then attach the battery clamps. These are 11mm bolts.
Now, here's what the cables do:
The transmission ground is that hole there near the flywheel inspection port. If you have a bracket there, just get rid of it or whatever.
The other end of that short cable goes to the body ground on a M6 10mm bolt right under the CIS airbox. You'll have to move that out of the way to see it. You can remove your stock ground strap. I bet it looks like hell.
This pic is of my old clamp. As you can see, I replaced one of the bolts with an M6 allen head bolt - it makes it easier. Put all of your stock grounds back on those bolts.
Vintage Watercooled Technotes:
http://www.vintagewatercooleds.com/tech/
#2
#3
Here's a link to an auction to the exact crimper that I own.
http://cgi.ebay.com/Hammer-On-...wItem
#4
I need to do this to my car.
You can also solder those lugs on with a propane torch if you dont feel like crimping. Say, for example, if you have a torch but no crimper. I soldered my lugs on my rally car's cables and havnt had any issues.
#5
Looks good! Easy to do also!The beauty of having MS
"Everything is possible to the man who does not have to do it for himself"
#6
I'm kind of surprised we need a how to for this, but anyways if you don't feel like buying the crimper, you could use a vise, a rubber mallet and some metal hunks (other tools or what ever you have) to crimp the end on the cable.
#7
Nice work dude. Your Scirocco says thank you very much.I have a suggestion. You wold have a more reliable connection if you locked in that bolt. The best solution would be to have under the bolt head: 1.split collar lock washer 2.flat washer 3.the ground lug 4.star washer. That way it will not spin as you tighten, and it will be much less likely to loosen.
This is especially important for preventative maintenance people. For me --a wait until it fails kinda guy-- I can rely on the corrosion to help hold it in
Quote, originally posted by timbo2132 » ::edit:: Timbo Dude, that BFH-activated crimper is the izshnit! Never seen one like that!
Modified by LastMartian at 8:11 PM 10-10-2007
Modified by LastMartian at 8:13 PM 10-10-2007
86 Scirocco, 2.0L CIS, "Jezebel" --- Rebuild Thread
93 Volvo 240 Classic Wagon, "Victoria" --- The Other Car I Love
I fix broken things, and break fixed things.
Fb
#8
Bump for Timbo since he made me a set. I love the work, but now I need to run the positive cable! Tranny weekend only left me with enough time to do the ground.
to Timbo yet again!
#9
Quote, originally posted by scirocco*joe »
to Timbo yet again!
Yes indeed!
I will have yet another project for my car this coming summer
#10
Is there a noticeable difference in the car with these better grounds?
I don't know how credible it is, but I've heard that better grounds can increase your HP![]()
#11
Makes a huge difference. I've also run heavy gauge wire from the battery to the fuse box. I'd gone from 11v on the volt gauge to almost 14 with the alternator, gnd, and main line to fuse box upgrade. Needles don't jump around either when you step on the brakes or turn on the lights. Great write up Timbo.![]()
#12
Quote, originally posted by jr_certs » Is there a noticeable difference in the car with these better grounds?
It fixes drains, and strang electrical problems that cause bad idle, stalling, etc...
Maybe it gives you a SLIGHTLY hotter spark, because there's a tiny bit more voltage to the ignition coil. It would depend on how bad it was to begin with.
#13
Hey timbo.. I have heard that its a good idea to put a ground strap from your alternator housing to the engine block..I have it on both of my roccos.. Just thought id throw that in.
I also heard its a good idea to run one from your intake manifold to your coil housing bolt on the firewall..
#14
I know I'm invading this thread.But can this be done for maitanence for other vw's also, i.e. my rado??(currently dealing with electrical drain)
#15
Quote, originally posted by CTCORRADOKID » I know I'm invading this thread. But can this be done for maitanence for other vw's also, i.e. my rado??(currently dealing with electrical drain)
Yep. You'll have to adjust the legnths of the cables a bit, but it's the same idea.
#16
Of course what Timbo says works for really any car....but some VWs suffer from poor grounding right from the factory.This is exactly what I need to do with my 81' that I found rotting away in the forest !
Jim
1986.5 16V Scirocco (original owner !)
2003 Audi RS6 (MTM)
2001 Audi allroad (O.CT)
1992 Mercedes 500E...and a few other rides
#17
Yep, those two are good ideas as well... I use an ABF alternator - the case is attached to the bracket with no rubber bushings at all - so it's a pretty good ground there. I still have the stock valve cover to coil strap.
I'd suggest an 8 gauge strap for these things though - easier to work with.
#18
Timbo.. I just have one thing to say ...YOUR THE MAN!! I wish i lived closer to PA..
#19
Timbo,The clamp on my stock ground cable ('81 Scirocco S) is busted, so while I was in the junkyard today I plucked a ground cable from a Mk 1 Golf. It had a single ground going from the battery to the chassis. I never thought to look at my existing setup to see if it was the same.
What is the purpose of having two ground straps running in series? Is it really worthwhile to install a larger-than-standard ground cable vice the stock one?
Also, would you mind pointing me to your thread about rewiring the car for heavy-duty headlights? I've already installed two relays and a fuse panel, but haven't wired anything up yet. Rumor has it there's a wiring diagram somewhere that can be followed by electrically-challenged folks like me?
THANKS!
#20
Quote, originally posted by Mike Drew » Timbo,
THANKS!The series straps assures good connection from the battery to the chassis and motor.
Going to a larger than "standard" will always be a win win. Over time as the copper wire ages and you get buildup of oxidation at connection points, resistance goes up. D/C current is especially sensitive to IR unlike A/C.
No disrespect towards Timbo by ANY means, but if you wanna get wild, forget about crimping, and solder ALL connectors. Not only is it a much better connection, the mechanical strength is far superior.
#21
Quote, originally posted by GLi_Luva » No disrespect towards Timbo by ANY means, but if you wanna get wild, forget about crimping, and solder ALL connectors. Not only is it a much better connection, the mechanical strength is far superior. ![]()
Uhh... NO, in every respect. You do not want to solder high-current connections like these. The resistance of solder is higher than that of bare copper, and aside from all the other issues you have to worry about with solder (cold joints, mechanical fatigue due to vibration, etc.), it may actually melt under load or even start a fire. Silver solder would help but is harder to work with/$$$/higher melting temp. Either one, the amount of heat you'd need to apply to such big conductors to tin/flow the solder is going to burn your insulation and begin to anneal the copper, making it hard & brittle. Solder is acceptable for low-current/signal applications only (e.g., printed circuit boards).
You won't find such solder connections in your cars (or most any other application for that matter), and THIS is why. Good crimp connections are superior in every way. If you've ever dissected a connection that was properly crimped, you wont find oxidation in the crimped section, only what's exposed. If you want to help keep contaminants out of the connection you can use dielectric grease and/or heat shrink tubing.
Naturally you can do what you want, but on behalf of the unsuspecting who might take bad advice I had to say something.
Modified by DiezNutz at 2:06 AM 10-12-2007
no one cares what you think in real life...
how do you figure the internet makes it any better.
#22
Quote, originally posted by DiezNutz » Uhh... NO, in every respect. You do not want to solder high-current connections like these. The resistance of solder is higher than that of bare copper, and aside from all the other issues you have to worry about with solder (cold joints, mechanical fatigue due to vibration, etc.),
Sweet! I take it you are a EE as well.
You are correct, Before shooting off I should be far more in-depth, lest the non-experienced try taking a 15 watt solder Iron to 00 gauge wire. 63/43 eutectic you would want to use, and if you have no experience pumping 100 amps through a soldered connection, you have no business trying to do what I do for a living.
As far as mechaincal fatigue though, I've been doing this for 15 years, never had a solder joint fail to vibration. Even the satellites circling the planet now I've helped put there through Boeing are doing just fine. mil spec is a beeyotch.
You have no clue the amount of stresses they endure just getting there, much less maintain full functionality without regular service.
Modified by DiezNutz at 2:06 AM 10-12-2007Very true, I you have bypassed your fan switch and have it running 24/7, drive around with 130 watt H4's, 100 watt H1's burning full time, and stall your car every 5 seconds due to tuning issues and have to crank it over for 30 seconds at a time before she re-lights, this could be a very REAL issue, ESPECIALLY if you have a boomin system and play nothing but bass test CD's. Even more so if you can't solder and get cold joints up the wang. Personally though, I highly doubt you'd ever pull enough amps through a proper solder connection in a auto application for long enough to ever melt and start fire. Hey, maybe I'll eat my words though and somehow try to draw a consistant 120 amps from my alternator just to prove your theory.
Quote, originally posted by DiezNutz » Either one, the amount of heat you'd need to apply to such big conductors to tin/flow the solder is going to burn your insulation and begin to anneal the copper, making it hard & brittle. Solder is acceptable for low-current/signal applications only (e.g., printed circuit boards).
Again you are correct, for the inexperienced, trying to heat such large gauge wire without sufficient heat sinking to keep from destroying your insulation, and the proper equipment to apply the amount of heat required will result in tears.
Quote, originally posted by DiezNutz » You won't find such solder connections in your cars (or most any other application for that matter), and THIS is why. Good crimp connections are superior in every way. If you've ever dissected a connection that was properly crimped, you wont find oxidation in the crimped section, only what's exposed. If you want to help keep contaminants out of the connection you can use dielectric grease and/or heat shrink tubing.
I disagree with the first sentence, the auto industry is about saving pennies, and a couple pennies saved could equal tens of thousands of dollars, far cheaper and easier to crimp than have to have every single connection properly soldered.
And yes, with a proper crimp as long as its tight enough to keep the O2 out, you will find it nice and clean. Sadly though, with all the 25 year old dubs I've owned this has not been the case. Now, my old Mopars on the other hand, support your claim.
Heat shrink or dielectric grease I would definitely reccomend considering the enviroment these wires have to live in under the hood.
Quote, originally posted by DiezNutz » Naturally you can do what you want, but on behalf of the unsuspecting who might take bad advice I had to say something.
Modified by DiezNutz at 2:06 AM 10-12-2007I definitely retract my statement, its not something just anyone is capable of.
Modified by GLi_Luva at 12:40 AM 10-12-2007
Modified by GLi_Luva at 12:42 AM 10-12-2007
#23
installed them last night,the alternator to starter cable was a bit long,but that wasnt a problem,found a nut/bolt to use for the new grounds,attached the grounds,car seems to run steady at about 14.4v's.
seems to turn over much easier as well,thanks again timbo,next on my list is headlight relays.
#24
Quote, originally posted by 85spraybomb » installed them last night,the alternator to starter cable was a bit long,but that wasnt a problem,found a nut/bolt to use for the new grounds,attached the grounds,car seems to run steady at about 14.4v's.
seems to turn over much easier as well,thanks again timbo,next on my list is headlight relays.Cool dude!! I figure too long is better than too short, right?
Trouble is I have to figure for A/C, non-A/C and 16v - that the cable has to be a bit longer to get around all that crap in a 16v.
As far as crimp-vs-solder - I think they both work just fine in the real world. In fact, I'll post a quick how-to on how to solder the copper on with a torch. However, I am of the crimping camp. OEMs crimp, Toyota crimps. That's good enough for me.is 4 gauge really necessary? no. But this cable is going to last a LOT longer than the stock 8 gauge bare copper braided straps. The marine grade insulation will keep out water, corrosion, and keep the resistance in the strands very low.
Also: please don't use welding cable for your battery cables - there's too few strands, and the cable isn't very flexible at all. The strands will break due to vibration.
#25
Quote, originally posted by timbo2132 » Yep. You'll have to adjust the legnths of the cables a bit, but it's the same idea.
#26
Quote, originally posted by GLi_Luva » Sweet! I take it you are a EE as well. Guilty as charged. Same industry as you, even. I'm glad we could (mostly) agree on these various points
I wanna say it's been 10 maybe even 15 years ago, VW even published a technical bulletin about the risks of solder connections and in summary said it was a no-no. My buddy that's a VW Master Tech showed it to me. Anybody know the one I'm talking about?
Modified by DiezNutz at 10:15 AM 10-12-2007
#27
Hey timbo.. im curious about how much normally does it cost to make a 4 headlight harness? Im talking with tim chunks about headlights, and im curious how much its going to cost me...
