VWVortex.com - golf 5 dsg.no gears
    Results 1 to 10 of 10
    Thread: golf 5 dsg.no gears
    1. 10-13-2007 04:43 AM #1
      hi guys. i have a 2006 20l.t dsg.vehicle fell off truck whilst being transported to dealership.when i got it,it was still in transport mode so i deactivated it and everything came to life but it wouldnt start.there was no signal from p/n switch from gearbox so i turn key on and i bridged starter solenoid.it started up but wont select any gears.is there any other settings that have to be made?is s/coding for tcm correct?will abs stop it from selecting totally?any other suggestions.heres the shopping list.dont now where to start.thanks in advance.
    2. 10-13-2007 04:48 AM #2
      sorry.i forgot autoscan.
      Friday,12,October,2007,17:22:01:36629
      VAG-COM Version: Release 704.1
      Data version: 20070422
      Chassis Type: 1K0
      Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
      VIN: AAVZZZ1KZ7U030996 Mileage: 10km/6miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: Malfunction 0010
      02-Auto Trans -- Status: Malfunction 0010
      03-ABS Brakes -- Status: Malfunction 0010
      08-Auto HVAC -- Status: Malfunction 0010
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: Malfunction 0010
      19-CAN Gateway -- Status: Malfunction 0010
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: Malfunction 0010
      46-Central Conv. -- Status: Malfunction 0010
      52-Door Elect, Pass. -- Status: Cannot be reached 1100
      56-Radio -- Status: OK 0000
      62-Door,Rear Left -- Status: Cannot be reached 1100
      Address 01: Engine Labels: 06F-907-115-AXX.LBL
      Part No SW: 1K0 907 115 K HW: 8P0 907 115 B
      Component: 2.0l R4/4V TFSI 0040
      Coding: 040300101C070160
      Shop #: WSC 00046
      4 Faults Found:
      012423 - Voltage Supply Relay for Engine Components: Electrical Malfunction
      P3087 - 004 - No Signal/Communication
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:22:40
      Freeze Frame:
      RPM: 803 /min
      Load: 23.9 %
      Speed: 0.0 km/h
      Temperature: 90.0°C
      Temperature: 35.0°C
      Absolute Pres.: 990.0 mbar
      Voltage: 13.970 V
      005668 - MIL Request Signal Active (Check TCM for errors too!)
      P1624 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Status: 00101000
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:22:41
      Freeze Frame:
      RPM: 786 /min
      Load: 24.3 %
      Speed: 0.0 km/h
      Temperature: 90.0°C
      Temperature: 35.0°C
      Voltage: 13.970 V
      000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Malfunction / Open Circuit
      P0036 - 004 - No Signal/Communication
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:22:50
      Freeze Frame:
      RPM: 775 /min
      Load: 23.9 %
      Speed: 0.0 km/h
      Temperature: 90.0°C
      Temperature: 35.0°C
      Voltage: 13.970 V
      000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction / Open Circuit
      P0030 - 004 - No Signal/Communication
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:22:50
      Freeze Frame:
      RPM: 775 /min
      Load: 23.9 %
      Speed: 0.0 km/h
      Temperature: 90.0°C
      Temperature: 35.0°C
      Voltage: 13.970 V
      Readiness: 0110 0101
      Address 02: Auto Trans Labels: 02E-300-0xx.LBL
      Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
      Component: GSG DSG 070 1305
      Coding: 0000020
      Shop #: WSC 44551
      3 Faults Found:
      18255 - Please check DTC Memory of ABS Controller
      P1847 - 000 - - - Intermittent
      Freeze Frame:
      Fault Status: 00100000
      Fault Priority: 0
      Reset counter: 1
      Mileage: 13 km
      Time Indication: 0
      19143 - Unexpected / Implausible Mechanical Gear Disengagement
      P2711 - 005 - No or Incorrect Basic Setting / Adaptation - Intermittent
      Freeze Frame:
      Fault Status: 00100101
      Fault Priority: 0
      Reset counter: 40
      Mileage: 13 km
      Time Indication: 0
      18115 - Interference in Mechatronic Module
      P1707 - 004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 0
      Reset counter: 40
      Mileage: 13 km
      Time Indication: 0
      Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
      Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
      Component: ESP FRONT MK60 0101
      Coding: 0021122
      Shop #: WSC 00046
      1 Fault Found:
      00283 - Front Left ABS Wheel Speed Sensor (G47)
      012 - Electrical Fault in Circuit
      Address 08: Auto HVAC Labels: 1K0-907-044.LBL
      Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
      Component: ClimatronicPQ35 090 0909
      1 Fault Found:
      00229 - Refrigerant Pressure
      002 - Lower Limit Exceeded
      Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
      Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
      Component: Bordnetz-SG H52 2002
      Coding: E58D8F2700041500471400001400000000097F075C0001
      Shop #: WSC 00046
      Part No: 1K2 955 119 E
      Component: Wischer 110407 020 0501
      Coding: 00049109
      Shop #: WSC 00046
      Part No: 1K0 955 559 AB
      Component: RLS 291106 020 0105
      Coding: 00208933
      Shop #: WSC 00046
      6 Faults Found:
      00061 - Footwell Lights
      Freeze Frame:
      Fault Status: 01101100
      Fault Priority: 5
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      ON
      Voltage: 12.35 V
      OFF
      ON
      OFF
      OFF
      OFF
      00156 - Control Circuit for Windshield Washer Pump
      009 - Open or Short to Ground
      Freeze Frame:
      Fault Status: 01101001
      Fault Priority: 3
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      ON
      Voltage: 12.35 V
      OFF
      ON
      OFF
      OFF
      OFF
      02398 - Control Circuit for Rear Windshield Washer Pump
      Freeze Frame:
      Fault Priority: 3
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      ON
      Voltage: 12.35 V
      OFF
      ON
      OFF
      OFF
      OFF
      01500 - Bulb for Fog-Lamps; Right (L23)
      010 - Open or Short to Plus
      Freeze Frame:
      Fault Status: 01101010
      Fault Priority: 4
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      ON
      Voltage: 12.60 V
      OFF
      ON
      OFF
      OFF
      OFF
      01333 - Door Control Module; Rear Left (J388)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      ON
      Voltage: 12.35 V
      OFF
      ON
      OFF
      OFF
      OFF
      01332 - Door Control Module; Passenger Side (J387)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      ON
      Voltage: 12.35 V
      OFF
      ON
      OFF
      OFF
      OFF
      Address 15: Airbags Labels: 1K0-909-605.LBL
      Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
      Component: 3A AIRBAG VW8 020 2300
      Coding: 0013121
      Shop #: WSC 00046
      8 Faults Found:
      01222 - Crash Sensor Side Airbag; Passenger Side (G180)
      010 - Open or Short to Plus - MIL ON
      01218 - Side Airbag Igniter; Passenger Side (N200)
      001 - Upper Limit Exceeded - MIL ON
      00588 - Airbag Igniter; Driver Side (N95)
      01228 - Airbag Cut-Off Switch for Passenger Side (E224)
      02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
      00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
      00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
      01589 - Igniter for Head-Airbag; Passenger Side (N252)
      Address 16: Steering wheel Labels: 1K0-953-549.LBL
      Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
      Component: J0527 636 0070
      Coding: 0012142
      Shop #: WSC 00000
      Part No: XXXXXXXXXXX
      Component: E0221 002 0010
      No fault code found.
      Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
      Part No SW: 1K6 920 873 HW: 1K6 920 873
      Component: KOMBIINSTRUMENT VDD 1610
      Coding: 0000103
      Shop #: WSC 00046
      Address 19: CAN Gateway Labels: 1K0-907-530.LBL
      Part No SW: 1K0 907 530 K HW: 1K0 907 951
      Component: J533__Gateway H04 0021
      Coding: 3F3F034007000003
      Shop #: WSC 00046
      3 Faults Found:
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:35:05
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:35:05
      01305 - Databus for Infotainment
      Freeze Frame:
      Fault Priority: 1
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:35:05
      Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
      Component: IMMO VDD 1610
      Address 42: Door Elect, Driver Labels: None
      Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
      Component: Tuer-SG 005 0986
      Coding: 0000692
      Shop #: WSC 00046
      Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
      Part No: 1K2 909 144 L
      Component: EPS_ZFLS Kl.069 H07 1806
      1 Fault Found:
      00778 - Steering Angle Sensor (G85)
      000 - -
      Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
      Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
      Component: KSG PQ35 G2 020 0203
      Coding: 199002005103087F2D040F0F70085FC690F800
      Shop #: WSC 00046
      Part No: 1K0 951 605 D
      Component: LIN BACKUP HORN H07 8003
      Part No: 1K0 951 178
      Component: Neigungssensor 001 0101
      Component: Innenraumueberw.001 0101
      2 Faults Found:
      Freeze Frame:
      Fault Priority: 4
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:34:37
      Freeze Frame:
      Fault Priority: 4
      Fault Frequency: 1
      Reset counter: 9
      Mileage: 13 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:34:37
      Address 52: Door Elect, Pass.
      Cannot be reached
      Address 56: Radio
      Cannot be reached
      Address 62: Door,Rear Left
      Cannot be reached
      Address 72: Door, Rear Right Labels: None
      Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
      Component: Tuer-SG 005 0912
      Coding: 0000144
      Shop #: WSC 00046
      End --------------------------------------------------------------------------------------------------
    3. 10-14-2007 03:25 PM #3
      anybody?
    4. 10-15-2007 03:45 PM #4
      Did you actually buy the car or did it fall off a truck and then you found it?
    5. 10-15-2007 03:46 PM #5
      But this should be a hint
      Quote »
    6. Former Advertiser
      May 27th, 2002
      10-15-2007 07:27 PM #6
      Hello
      Start over.
      Clear all the DTCs' with Vag-Com.
      Re adapt everything.
      Dont rig items by bypassing, use the repair manual, and trace the problems.
      Then post a complete scan with nothing rigged.
      Best,
      Jack
    7. 10-16-2007 01:42 PM #7
      Quote, originally posted by vwemporium »
      Hello
      Start over.
      Best,
      Jack
      couldn't have said it better
    8. 10-22-2007 12:53 AM #8
      i bought this vehicle from a reputable salvage dealer.how do i do adaptation or basic setting .dont have a complete manual for this car.only have wiring diagrams.(wiring seems to be ok)
    9. 10-22-2007 01:37 AM #9
      http://wiki.ross-tech.com/inde...5M%29
      But what you really want is from the repair manual the "PDI procedure"
    10. Former Advertiser
      May 27th, 2002
      10-22-2007 01:09 PM #10
      Hello
      Buy the repair manual you need it.
      Best,
      Jack
    Back
