Results 1 to 23 of 23
Thread: 2002 VR6 24V... Check engine, EPC, and Traction Control Light all on
  1. 10-14-2007 10:32 AM #1
    Hello Everbody,
    Im new here and came to this forum before giving up all hope. Maybe you guys can help. I've had my Vr6 for a while and I've had the same re-occuring issue my Check engine, EPC, and Traction Control Light all turn on and my car turns to crap. I took it to the dealer under warranty multiple times and they told me it was a bad ground, then a bad sensor, and then a bad wire, ect ect. They reset the codes and then a few day or weeks later they all come back on. I'm not sure what to do... What do you guys suggest?
    Thanks,
    Luis
    Modified by qml91911 at 7:33 AM 10/14/2007
  2. 10-14-2007 11:13 AM #2
    Generally when those three come on it's the MAF Sensor. I've also had the EPC light come on for a bad brake light sensor also. If it is a bad ground, it's possibly the one hiding under the battery box. Getting it scanned with a VAGCOM would give a lot of insight and posting those codes would help to track down the problem.
  3. 10-14-2007 11:46 AM #3
    Would a bad MAF trigger other codes to come up?
  4. Member vdubb24v's Avatar
    Dec 21st, 2006
    Orlando, Florida
    24v gti
    10-14-2007 12:31 PM #4
    Quote, originally posted by qml91911 »
    Yep, when my MAF went, all three came up as well. ITs not a big deal, just drive it nice and take it to the dealer asap
    Jul 24th, 2006
    Austin
    10-14-2007 06:21 PM #5
    I had all three on 2 weeks ago and it was the brake light switch that caused the EPC and traction control. The check engine was the coolant temp sensor.
    Hook'em Horns
  6. Member gf2020's Avatar
    Nov 28th, 2004
    North of Boston
    2009 Jetta Wagon | 2010 Toyota Tundra
    10-17-2007 11:31 AM #6
    Quote »
    Replace the brake light switch, there is a recall for it.
  7. Member Bdfrd 24v's Avatar
    Nov 23rd, 2004
    2003 24vT, 2010 TDI, 2011 C300
    10-17-2007 12:43 PM #7
    I can't remember a time when I didn't have check engine lights...
    2003 24vT - 2.9L JE, Eagle, C2 Motorsports, Precision Turbo, Jeff Atwood, Fully Polished Aluminum and Stainless components, Peloquin Diff, Clutchnet state 3+ clutch, 11lb Flywheel, 3.5" DP, Custom 3" magnaflow, Catch can,Weitec, OZ Canyon II 19x8 & 19x9.5, 17x9 w/ Hoosiers for track, Greddy Profec BII, Memphis 4-10" M Class, Memphis Components, Memphis Belle 1000 5 Channel, Pioneer w/ Nav, Updated Dyno results to come.
  8. 10-18-2007 03:34 PM #8
    i had the same problem. First they said it was a bad O2 sensor off the cat.. ...suuure replace under warranty. F**ked the threads on my cat so they had to replace that free. 2 days later same crap.. EPC, Traction, ABS still fluttering and car shutting off at lights, turning off car.. etc. and resetting everything.
    After many, many trips to the stealership, they replaced my ground wire as it had started to change to that green colour and the connectors were beginning to corrode which they also replaced under warranty for me.
    so its been fine for the last 2 weeks.
    Oh yeah, I also had my MAF replaced too.
    Still monitoring it, hope this helps.
  9. 10-18-2007 03:35 PM #9
    oh yeah, forgot to mention that I've scanned it with my VAGcom and no codes were ever tripped once I changed the MAF and O2 sensor.
    So it is quite a PIA!
  10. 10-21-2007 08:56 AM #10
    Thank you everyone....
  11. Member rajvosa71000's Avatar
    Jun 8th, 2004
    '04 VF Stg.2 24v GTI VR6, '98 GTI 12V VR6, '06 VW Touareg VR6
    10-21-2007 02:15 PM #11
    Quote, originally posted by Bdfrd 24v »
    That's because you probably never took that black MAF clamp that they send you with the kit, it was only needed for stage 1, not 2.
  12. 10-22-2007 12:40 AM #12
    I had the exact same codes come up all at the same time---turned out it was the maf sensor and nothing else.
    I replaced the maf sensor and have never had that problem again.
    [B]Patience Is The Key[B]
  13. Senior Member ClockworkChad's Avatar
    Mar 21st, 2003
    CT
    Is300
    10-22-2007 04:25 PM #13
    do the brake light switch recall and see if that does anything. also, go to autozone, get the check engine light code scanned and report back to us, we should be able to give you an idea of where to look to troubleshoot.
    Ferrari Scuderia 2012 - "The people who speak badly about me then tremble and cry when they want to have their picture taken with me” - F. Alonso
    Now recruiting for IT/financial/accounting/creative services in fairfield county and metro nyc, pm if interested
  14. 10-23-2007 09:29 PM #14
    i also just recently had the same problem
    all three lights came on and the car was bogging.
    i was rainning a lot and i got water sucked in my cold air intake my dash lit up like a christmas tree. the dealer checked my codes it was the maf to much water. anyway hope that helps
    the car runs great now
  15. 10-24-2007 01:11 PM #15
    i had the same problem a while ago my battery **** the bed and also the fuse box on top of the battery.
  16. Junior Member EcuaDUBinFL's Avatar
    Feb 12th, 2008
    Tampa
    02-13-2008 01:40 AM #16
    I was taking a look at my engine, and I realized that the stock intake was not connected to the throttle body.
    Could that of triggered all 3 lights? And where is the MAF sensor located???
  17. Member rajvosa71000's Avatar
    Jun 8th, 2004
    02-13-2008 03:45 AM #17
    Quote, originally posted by EcuaDUBinFL »
    It would trigger all those lights....your MAF Sensor is located inside the plastik intake pipe...it's where you connect your MAF sensor plug
  18. Junior Member EcuaDUBinFL's Avatar
    Feb 12th, 2008
    Tampa
    02-13-2008 02:41 PM #18
    On my way to the dealership, The EPC light turns off, only the CEL and traction lights are on.
    Dealer stated that its the MAF sensor $350.
    but since my warranty hasn't kicked in. i have to wait a couple days.
    MAF sensor wouldnt affect daily driving would it?
  19. Member VReihen6's Avatar
    Aug 7th, 2006
    Bossier City, LA
    2003 GLI 24v
    02-13-2008 03:14 PM #19
    pffsh check engine light? what is that?
    - Beagley
    The Elite 24v VR6 Club: Member #8
  20. 02-14-2008 07:44 PM #20
    You can still drive with a bad MAF...the car will bog down when you try to accelerate though. I just had mine go south on me this morning. Bought a new one from Performance-Cafe for $99
    CLICK HERE --> http://www.performance-cafe.co...=1791
  21. Member rajvosa71000's Avatar
    Jun 8th, 2004
    02-15-2008 02:19 AM #21
    You can unplug your MAF sensor and drive it...my MAF sensor went bad on my MK3 VR and it was idling crappy and would sputter on acceleration....once the sensor was unplugged everything was perfect....you'll get little hick ups when you try to accelerate first thing in the morning while the car is cold, once warmed up for a few minutes it works fine
  22. 04-08-2008 07:48 PM #22
    i know what you mean i have had my 04 gti for about a month and i have had a light on at least once a week, this time its the maf, thank God for this vortex
  23. 04-08-2008 10:17 PM #23
    Have you taken it to get the computer actually read? I had that happen to me too. It started out as all those and then eventually it just turned into a misfire. When i took mine into the shop i had to replace all the timing chains, MAF sensor and coil pack. Maybe its one of them. Has it lost a lot of power? sluggish going up hills? DO the RPM's go so low that you stall out? The first thing i would do is check o2 and MAF snesors, air filter, plugs and wires. and then move onto maybe bringing it back into the shop.
