VWVortex.com - Whistling Side Vents / Cold air blowing on your hands when vent closed?
    Results 1 to 11 of 11
    Thread: Whistling Side Vents / Cold air blowing on your hands when vent closed?
    1. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      10-18-2007 07:08 AM #1
      Its about that time of year. The frost is soon on the pumpkin
      Are you hearing a whistling when your side vents are closed? Do your hands get that little bit of cold air blowing on them as they are on the steering wheel? Well I have the answer for you.
      Gently remove your side vents from the dash.
      For the center vent, I took a wire coat hanger and cut the bottom of it and divided that.
      I bent a hook at 45 degrees on one end and the other I made a finger pull.
      Insert that in the vent slots and hook the back of the vent on both sides and pull out.
      To remove the side vents.....
      Use a flat blade screw driver and pry it out at the top against the hard plastic shell (not the edge) and the dash
      I have had good luck in gluing the middle edges with thin coats of jb weld quick If there are holes then you can use a piece of tape on the front to keep it from coming through.
      Then carefully disconnect the movement cam link.
      Gently pry out the opposite pivot.
      Then twisting sideways you can remove the vent stop.
      Carefully remove the dead foam, you will need to make a template so you can tear it on one side only.
      Now using a piece of foam thin ( I use old mother board foam I have a ton of it )
      Place the dead foam on it and trace the outline be wide on the outside.
      Cut it outside of the lines a bit
      Now you have a new donut gasket.
      Work the foam around the Stop into the groove.
      Now trim it evenly around about ¼ of an inch
      Insert the stop with the cam side first, and be careful… then pop the other side in to place.
      Re-attach the cam arm…
      Now admire your finished work.
      Your side vents won’t whistle any more and the cold air will be totally cut off of your hands and won’t interfere with the side defrosters any more.
      PS. You can do the center vents the same way....
      Are your vents are so floppy they don't stay up...Do they need viagra?
      Carefully remove the vent from the dash.
      Pull the vent all the way pointing up.
      Using a small screw driver carefully pry the vent out of the
      assembly.
      Looking at your vent front back sideways.
      Take a piece of thin closed cell foam or self sticky smooth velcro cut some small strips.
      Stick a large piece to the side of the vent frame.
      Pry out the "top" vent bar.
      Attach small pieces of foam to the leading edge of the bar, and re-insert
      being sure that you get the foam under the fingers...
      Place back in to the assembly.
      Grounds, Grounds, Grounds Replace them things.
      Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
    2. Member automk2slowness's Avatar
      Apr 16th, 2006
      Dirty 973
      1998 jetta W.E.
      10-18-2007 07:53 AM #2
      ooooh. thats nice, thanks alot
    3. 10-18-2007 01:22 PM #3
      Very nice DIY write up!
    4. Member 2low2go's Avatar
      Apr 18th, 2003
      Camarillo
      mk2 voomeran gli, w202 brabus, b7 passat
      10-18-2007 04:22 PM #4
      bookmarked [IMG]http://*****************.com/smile/emthup.gif[/IMG] will definitely do it once i stumble across some foam
    5. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      10-18-2007 04:59 PM #5
      FAQ'd! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    6. Member waterboy86's Avatar
      Jul 31st, 2004
      Los Angeles,Ca
      10-19-2007 07:12 AM #6
      nice
    7. Member montmil's Avatar
      Jul 8th, 2006
      Denton, TEXAS
      1986 Cabriolet WE
      10-21-2007 10:40 AM #7
      Did this on my '86 and it works. Be very cautious in removing the vent housing... old plastic can be muy brittle. Couple add'l ideas: While you have the vent housing on the bench... clean it! I used some diluted Simple Green to rinse the small felt pads on each side of the louvered part. These pads are a friction drag and help the vent stay where you aim it. Mine were so dusty-dirty that they slipped around. Now clean, they stay where I aim 'em. Mother board foam? Us #2 pencil guys don't know and don't gots. I utilized scraps of a closed-cell foam usually sold as tool box drawer liner. Think Sears. Denser than the original VW foam, it resists wear better than the original open-cell materials. And btw, the foam donuts are actually oval in shape as is the plastic flapper valve. Trim your replacement material - both i.d. and o.d. - to match the oval shape, plus the overhanging bit, and they'll seal up super tight. Bye bye, whistling drafts. Good call, Briano [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by montmil at 7:41 AM 10-21-2007
      Monte Miller
      1986 WE Cabriolet
      1981 BMW R65
      1978 BMW R100S
      1995 Triumph Trophy 900
    8. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      10-05-2013 02:41 PM #8
      It's that time of year again, updated to show safe removal of vents.
    9. Member flipty's Avatar
      Mar 5th, 2012
      St. Paul, MN
      88 Cabby daily driver
      10-07-2013 01:40 PM #9
      Great writeup, I'm looking forward to doing my center vent, which is clearly closed and no longer attached to the machinery that makes it open. It never has. LOVE those coat hanger dealies!
    10. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      10-13-2015 05:20 PM #10
      Well I figured that it was that time of the year again for Newbies to learn how to fix their vents....
      I didn't realize that this thread was originally started in 2007 or 8.....
      So heads up.
    11. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      10-17-2016 04:34 PM #11
      That time of year again to Bump the thread.
