VWVortex.com - Engine revs up and down when in neutral why?
    Results 1 to 12 of 12
    Thread: Engine revs up and down when in neutral why?
    1. 11-04-2007 11:01 AM #1
      Hi there here is my problem. I've noticed lately that when i start my car and its in neutral the engine revs up and down and so does the rpm. It'll go up till 2500 then down. I also noticed that when i put the key in and turn all the way without pushing down on the clutch i hear a ticking sound.
      anyone have any idea if something is about to go wrong on my car. it's a 1997 jetta gt manual trans.
    2. 11-04-2007 11:34 AM #2
      Quote, originally posted by guru97 »
      Well that ones normal there, just a safety feature to make sure you dont try and start the car with it in gear
    3. Member Jetta 2.0's Avatar
      Oct 20th, 2007
      Oakville, Canada
      11-04-2007 11:36 AM #3
      Lol, ya, My 95 doesn't have that, good thing I keep the brake on everytime
    4. Member MaSeDoGG's Avatar
      Jan 22nd, 2004
      Minneapolis
      2000 Cabrio. Previously mk3s and mk4s
      11-04-2007 11:44 AM #4
      i dont know if they 2.0 has it, but it sounds like a secondary air injection problem. my vr does it and it's annoying
      and yes, in 97 they started making it so you had to have the clutch in to start the car.
      they should just put a picture of me in the dope shizz thread and lock it.
    5. 11-04-2007 12:23 PM #5
      ok, but why does my engine rev up and down without me applying any pressure to the gas pedal?
    6. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      11-04-2007 12:26 PM #6
      Vacuum leak or misdjusted/dirty TB.
    7. 11-04-2007 12:36 PM #7
      Quote, originally posted by Dan J Reed »
      I was thinking the same thing at first but haven't seen a dirty TB make the car rev as high as 2500rpm, at least not yet.
    8. 11-04-2007 12:39 PM #8
      ok thx
    9. Member whitseml's Avatar
      Apr 16th, 2007
      SoMD
      '68 Coronet, 88' Toyota MR2, & '13 Passat TDI SE
      11-04-2007 12:41 PM #9
      My VR does the same thing. I took it to the dealership because the check engine light was on and they told me that the air pump was falling apart. Since that creates a vacuum leak, could that be whats causing my engine to rev?
      Volkswagens are like strippers, they only work when you throw money at them.
    10. 11-04-2007 12:56 PM #10
      could be the idle control sensor just fixed it on some honda that was in my shop at school might wanna check that out or also maybe a vacuum leak like said before lean to rich air fuel mixture could do it
    11. Member
      Jan 30th, 2006
      03 Lexus IS300
      11-04-2007 01:12 PM #11
      mine did that for a while when it was cold out. i replaced a bad mass air flow sensor and i havent seen the problem in almost a year.
    12. 11-04-2007 01:26 PM #12
      o2 sensor on my other car caused a problem like this. Worth checking out. But I would lean towards a vacuum leak. My 300zx had some BIG leaks and it threw the idle all over the place.
