VWVortex.com - LOW TIRE PRESSURE WARNING
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 31
    Thread: LOW TIRE PRESSURE WARNING
    1. 11-04-2007 02:19 PM #1
      I have a 2007 Passat Wlfsburg Edition with 4,300 miles on it. In the message center it stated "Tire Pressure Too Low!" There is also a tire yellow warning light lit. I checked the tire pressure. They were all at 30 psi. I inflated them to 33 psi as stated on the door jamb. The light and message are still there. I checked the owners manual and it doesn't say how to reset it or anything.
      Help! What should I do?
    2. 11-04-2007 02:28 PM #2
      First try driving around for a while (20-30 miles) and see what happens. I wouldn't worry too much if you're sure the tires are inflated properly.
      Another, less orthodox, way would be to overinflate the tires (but within a prescribed limit, say 38psi). Once the light is gone, slowly deflate the tires to the desired pressure (most people have between 33 and 35 psi).
    3. 11-04-2007 04:50 PM #3
      I don't know much about this as my car hasn't even been delivered yet, but how does the passat system work - sensors in the wheels or ones on the body detecting a difference in rotation speed?
      It's just that for the sensors in the wheels, as they are wireless, I've heard that low pressure in the spare can set the warning off.
      David.
    4. Member x9t's Avatar
      Sep 19th, 2005
      Bay Area-CA
      07 Passat 2.0T 6MT/96 Passat GLX VR6/ 87 Scirocco 16V
      11-04-2007 05:01 PM #4
      I dont know if all spares have them. I have removed my spare from my car and i havent had any lights. I once had one tire low 28PSI after 150 miles of driving.. the car had like 600 miles or something. I refilled it and drove about 20 miles and it cleared itself. As long as your tires are at the correct PSI. I wouldnt worry about it. They can fail though, sometimes the sensore get loose in there.. and they have to be replaced.
      JT
      Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
      Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
    5. 11-04-2007 05:08 PM #5
      Wow! It's weird that you posted this topic.
      My TPMS stated that "Tire pressure too low" as well. My tires are all inflated properly.
    6. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      11-04-2007 05:15 PM #6
      Quote, originally posted by Orangezorki »
      David.
      Yeah I've been wondering this too. On my GTI its ABS sensors that calculate the rotation and TMPS it has a TMPS button on the dash to reset/set the pressure.
      On another note.. I drove an 08 Passat and noticed they dont have a TMPS button near the shifter like some other Passat models do? ? ? I'm assuming this is the wireless system.
      Euro Pic of Wireless model (no button)
      2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8 FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
    7. 11-04-2007 05:24 PM #7
      I wouldn't take that as definite - Here in the UK TPMS is optional on all but the 3.2L V6, which nobody buys anyway. I remember that when I ticked the box for the option, it was fairly cheap, about $120 equivalent. Not shure if that's a clue to the system.
      David.
    8. 11-04-2007 05:38 PM #8
      One other thing I forgot to mention in my original post...with the warning message posted, none of the other features in the message center work, so it's really a pain the a*@!
      I hope this isn't my first problem of many. I'm new to VW and was warned about this type of thing by many people before I bought it.
    9. 11-04-2007 07:04 PM #9
      I had the same thing. Inflate the tires to recommended pressure and give it a couple of days. It resets itself, unless you have a faulty indicator.
    10. Member type17volkswagen's Avatar
      May 2nd, 2004
      Alexandria, VA
      All original 77 Rabbit; 16 Tiguan; 15 Jetta Hybrid
      11-04-2007 07:22 PM #10
      Quote, originally posted by VWDG »
      I'm guessing you have the full MFD display with steering wheel controls. If so, you should be able to press the "ok" button to make the message go away which will enable you to see the other features.
    11. Member
      Jan 18th, 2004
      South
      2004 MKIV R32, 2007 Wolfsburg Passat, 2015 Golf R
      11-04-2007 07:53 PM #11
      Same thing happened to me. Bump the pressure up to about 38PSI and the system should "reset". Then you can set the pressure back to 33
    12. 11-05-2007 12:44 AM #12
      you can also check the sensor reading via the vag-com.
    13. Member Keroppi_2.0T's Avatar
      Feb 25th, 2006
      Coolwater NYC
      13' S5 Coupe 3.0T 6spd APR Stg 2+, 09 VW GTI 2dr, 11 VW Tiguan 2.0T 4Motion SE APR k04, 14 Jetta TDI
      11-05-2007 07:18 AM #13
      Quote, originally posted by NCVOLKSWAGEN »
      Mine just came on 2 days ago...i think cuz it got too cold
    14. Member
      Apr 19th, 2006
      2010 Golf TDI
      11-05-2007 08:59 AM #14
      Quote, originally posted by Keroppi_2.0T »
      This...
      The same thing happened last fall/winter when the weather changed; lots of posts about the TPMS alerts going off.
      A little physics lesson... < temp = < gas pressure given a fixed volume. (Or something like that! )
      2010 Golf TDI 4 Door Shark Blue. DSG, Sunroof, Dynaudio, Nav, Rear airbags
      Quote Originally Posted by Outie5000 View Post
      And lets be honest, owning a diesel car is nifty.
    15. Member coomoob1's Avatar
      Dec 10th, 2001
      Tampa area, FL
      2015 GTI MKVII Autobahn
      11-05-2007 10:15 AM #15
      I actually had this happen to me on Saturday....while I was on a little road trip in Fort Myers. It was a BRISK 60 degrees outside (at 10am) and my FL tires were just to cold I guess. The message went away after driving to the beach. Hehe.
      Current: 2015 VW Golf GTI MKVII Autobahn
      Prior: 2013 VW CC 2.0 Sport Plus, 2010 CC 2.0T R-Line, 2007 Passat 2.0T Lux, 2004 Explorer Eddie Bauer (What was I thinking!?), 2001 GTI IV 1.8T, 1999.5 Golf IV, 1992 Geo Metro LS
    16. Member sebasEuRo's Avatar
      Feb 26th, 2006
      Seattle/Europe
      '15 GLI, '16 Jetta Sport, '17 Sportwagen 4motion
      11-05-2007 01:08 PM #16
      Quote, originally posted by quailallstar &raquo;
      RICH (OEMPL.us) I want this shifter!
      *****AMBER CluB*****
      Volkswagen AktienGesellschaft In North America
    17. 11-05-2007 02:48 PM #17
      When my tire had lost air, the warning light went off pretty immediately after I filled it up. Give it a few miles and see what happens...
    18. Member veedubmac's Avatar
      Sep 24th, 2007
      NY & CT
      2016 BMW 340xi
      11-05-2007 03:03 PM #18
      Sometimes when the tires are cold (first thing in the morning) the tire pressure light comes on- I dont know why though...
      2016 BMW 340i xDrive | Glacier Silver | Saddle | Ash Grain Wood | M-Sport w/ 398 18s | Track Handling | Premium | Driver Assistance & Plus | Cold Weather | Technology | Lighting
      Past: 2013 BMW 335xi, 2014 428xi 'vert, 2010 VW CC 2.0T, 2008 Audi Q7 4.2 Premium
    19. Member
      Apr 19th, 2006
      2010 Golf TDI
      11-05-2007 03:58 PM #19
      Quote, originally posted by veedubmac &raquo;
      Because your tires are very close to the lower limit of the settings for the light.
      Check you air pressure in the morning when the tires are cold. Fill to the recommended pressure then.
    20. 11-06-2007 05:19 AM #20
      My warning light has only come on twice and both times the tire pressure was low. As soon as I added air per specs the light went off.
    21. Member Dave Woss's Avatar
      Oct 31st, 2006
      Tallinn, Estonia
      11-06-2007 06:53 AM #21
      In my manual it says, that after re-filling your tires you should reset the TPM. Just hold down the button near the shiftter aslong as you hear a "dong" sound. After that the new pressure is saved.
      07 VW Passat 2,0 Tfsi Tiptronic Highline, SpiceyRed, beige alcantara/leather, -15mm OEM sport suspension
    22. Member
      Apr 19th, 2006
      2010 Golf TDI
      11-06-2007 09:37 AM #22
      Quote, originally posted by Dave Woss &raquo;
      That's the procedure for the ROW (aren't we Americans egocentric!). The US cars don't have the TMPS button, as it is standard on all cars sold here.
      I would rather have the button than the "blank"! Looks like I am missing something!
    23. Member Tekniec's Avatar
      Aug 13th, 2005
      Current: 2010 CC Lux and 2009 Jetta SE
      11-06-2007 11:05 AM #23
      Have you checked the spare in the trunk? had the same problem, no idea why, but my spare deflated...
      Previous cars:
      2008 R32 w/nav
      2006 Passat 2.0t
    24. 11-08-2007 04:03 PM #24
      I've experienced the same thing on my 06 Passat 3.6 L Pumped up to 36 psi - what it should be according to the sticker on the door pillar. Light was still on. Brought it to the dealer - he pumped it to 40psi and light dissapears. Hm....Dealer sais it's fine and no big deal...Hm...
      Modified by dietz at 4:06 PM 11-8-2007
    25. 11-08-2007 04:16 PM #25
      Thank you for all the replies. The light is now off. I went to another dealer and they said they all have to be exactly the same and he suggested I buy a new gauge. I was using one of those that look like a pen and the white "ruler" comes out. I bought a digital gauge at Target for $10 and it turns out my gauge was off by nearly 4 pounds. I inflated all the tires to 33 psi and the light went off immediately even before I drove it.
