VWVortex.com - 00513 00515 Trouble Codes.
    Results 1 to 20 of 20
    Thread: 00513 00515 Trouble Codes.
    1. 11-12-2007 11:13 AM #1
      I have read some similar post with these same trouble codes but no resolution. I know it's impossible to diagnose online but I would just like some suggestions on where to start.
      Car is a 1995 VW golf 2.0L
      It's bogging/missing a little not much though but I do have the engine light and those are the trouble codes.
      Thanks in advanced.
    2. Member 2pt. slo's Avatar
      Jan 4th, 2004
      Creedmoor, NC
      98' GTI 2.0T, 12' TDI SportWagen
      11-12-2007 02:44 PM #2
      do a nice tuneup, plugs, wires, cap, rotor, ign. coil, clean your throttle body and maf.....only use this stuff to clean your maf....if none of the above work then come back to us... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 11-15-2007 06:52 PM #3
      Ok I tried the MAF once and it didn't work. I'm going to order all that stuff I was meaning to anways. Any suggestion on which plugs to buy? Engine is stock BTW
    4. 11-17-2007 01:28 PM #4
    5. Member SLVR SLUG's Avatar
      Dec 9th, 2006
      2004 Golf 2.0T 1989 Chevy S10 Blazer 4x4
      11-17-2007 03:33 PM #5
      http://i200.photobucket.com/al...2.jpg
      good stuff! i use it to clean off my injector tips also when i do tune ups
      the new vortex sucks!
      R.I.P. #2688... you will be missed.
    6. 12-13-2007 05:52 PM #6
      Ok update:
      Did a full tune up on it including all of the above. I had the engine code cleared by the scanner but it came back on in less then a day. What are your suggestions now?
    7. Member VWJettaCarat's Avatar
      Apr 8th, 2004
      Orangeville, Ontario
      02 Jetta TDI, 03 Jetta Wagon TDI, 05 Audi B6 1.8T
      12-13-2007 10:29 PM #7
      hall sensor
      F.S: Original VolksWagenMotorSports Shift Knob with Leather Boot VWMS Knob+Boot
    8. 12-15-2007 12:45 PM #8
      What's a Hall sensor?
    9. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      12-15-2007 02:05 PM #9
      check this thread... http://forums.vwvortex.com/zerothread?id=3570296 [IMG]http://*****************.com/smile/emthup.gif[/IMG] and this one if you haven't already. http://wiki.ross-tech.com/index.php/Main_Page
      Modified by ps2375 at 12:09 PM 12-15-2007
    10. Member
      Jul 31st, 2002
      '74 Bug (yard), '96 Jetta 255K (yard), '02 Cabrio 104K (sold), '06 Rabbit 127K BGP, '08 Jetta 55K
      12-15-2007 02:56 PM #10
      Was the car scanned with it running or off?
      Are you due for a timing belt change or has it been done recently?
    11. 12-15-2007 06:07 PM #11
      I don't know if it has been done. Or if it needs to be done. It was scanned both on and off and still receive the same codes.
    12. 12-16-2007 09:33 PM #12
      Could the timing be off? Is changing the timing back an easy task?
    13. Member
      Jul 31st, 2002
      12-16-2007 09:36 PM #13
      Could be. Check the marks.
    14. 12-17-2007 11:36 AM #14
      I'm gonna read some DIY
    15. 12-18-2007 05:49 PM #15
      Okay. So now I believe my timing on my cams are off. How would I realign the timing. I read the whole DIY on replacing the timing belt but I still don't' know what to do to recheck the timing and adjust. If someone could please clarify
    16. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      12-18-2007 07:16 PM #16
      you have to remove the belt, realign the marks and reinstall the belt. the dizzy(driven by the IM shaft) is not correctly aligned to the crank. Its looking at the window in the dizzy compared to the teeth on the crank. The dizzy tells the ECU where the cam is at (for TDC). The mkIV's have a sensor on the cam sprocket, which you do not. So, line up the crank, cam and IM shaft marks to their respective reference marks and put the belt on. Then check the alignment to see if it is correct. It might take a couple of tries, but it is very doable. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by ps2375 at 5:23 PM 12-18-2007
    17. 12-18-2007 07:22 PM #17
      As easy as that?
    18. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      12-18-2007 07:30 PM #18
      yup. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member
      Jul 31st, 2002
      12-18-2007 07:44 PM #19
      There has to be a reason your timing is suddenly off. Is the belt OK? Missing any teeth? If the belt looks good, consider a problem on the back side of the crank gear.
    20. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      12-18-2007 07:55 PM #20
      YES!! If once you get the v-belt and serp belt off, and you can wiggle or rotate the pulley w/o moving the crank, the crank sprocket is damaged. And will need to be replaced. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
