VWVortex.com - '83 rabbit fusebox help
    Results 1 to 15 of 15
    Thread: '83 rabbit fusebox help
    1. Member eojthekid's Avatar
      Jul 17th, 2006
      Stouffville
      83/84 Rabbit
      11-20-2007 08:13 PM #1
      1983 RABBIT FUSE BOX HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
      I JUST PICK UP A 1983 RABBIT GTI, IT TURNS OVER BUT DOES’T START. [IMG][/IMG] [IMG][/IMG]
    2. Senior Member Big Dac With Fries's Avatar
      Feb 1st, 2002
      Spatula City
      6000 SUX
      11-20-2007 08:33 PM #2
      Looks like you're missing a fuel pump relay.
      "I was thinking about what a friend had said, I was hoping it was a lie."
    3. Member eojthekid's Avatar
      Jul 17th, 2006
      Stouffville
      83/84 Rabbit
      11-20-2007 08:43 PM #3
      fuel pump relay is there in socket #2 [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member Drehkraft's Avatar
      Mar 22nd, 2001
      Southern, Ontairo.
      11-20-2007 09:28 PM #4
      Sounds like you need something from this website:
      http://www.bentleypublishers.com/
      Cheap, fast, reliable - Pick your two!
    5. 11-20-2007 10:01 PM #5
      try this one its more detailed if that doesnt work i ve got one more detailed than that http://www.bentleypublishers.c...7.htm
    6. Member eojthekid's Avatar
      Jul 17th, 2006
      Stouffville
      83/84 Rabbit
      11-20-2007 10:04 PM #6
      it's for a 1983 RABBIT gti
    7. 11-20-2007 10:05 PM #7
      best ive got 1985 and up http://mysite.verizon.net/macm...I.htm
    8. Member eojthekid's Avatar
      Jul 17th, 2006
      Stouffville
      83/84 Rabbit
      11-20-2007 10:34 PM #8
      let's just say forget about the relays for now. why am i not getting any power to fuses 5 through 10?
    9. Member eojthekid's Avatar
      Jul 17th, 2006
      Stouffville
      83/84 Rabbit
      11-20-2007 10:47 PM #9
    10. Banned
      Apr 10th, 2007
      11-21-2007 12:23 AM #10
      is this my old rabbit??
      edit n/m i just saw 83 gti
    11. 11-21-2007 01:39 AM #11
      This should help.
      http://www.cabby-info.com/electrical_system.htm
      Those fuses seem to be nothing critical.
      As for the fuel pump relay, don't they usually have a fuse built in to them?
      As for it not starting, there are tons of things that could be wrong.
      Does it have spark?
      Does it have fuel?
      Is the timing on?
      A bad hall sender (distributor) can make this thing not move an inch but turn over all day long.
      Start with a few of the basics, but for now, forget the fuse panel, and find out what is missing from the equation.
      Cheers. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Junior Member
      Oct 23rd, 2005
      Toronto, ON
      84 Jettas
      11-21-2007 01:53 AM #12
      Try this site
      http://www.vintagewatercooleds...s.htm
      Hope it helps.
    13. Member chuque's Avatar
      Aug 25th, 2006
      The Junction - Toronto
      2010 Passat Wagoneer
      11-21-2007 07:32 AM #13
      TRY THE TECHNICAL FORUMS!!!!!!!!!!!!!!!!!!!!!!!!!@!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
      ::::::: I am not living, I am just killing time. ::::::
    14. Member Crazy Hungarian's Avatar
      Feb 10th, 2002
      East York, Toronto
      78 Rabbit 4dr VR6, 84 Jetta Coupe 1.8t, 91 Passat Wagon 1.8t
      11-21-2007 11:41 AM #14
      someone swapped your 83 GTI to ce2 then.
      Because no 83 GTI ever came with that fuse panel.
      Is this by any chance the White GTI that Movement was selling?
    15. Member eojthekid's Avatar
      Jul 17th, 2006
      Stouffville
      83/84 Rabbit
      11-21-2007 09:57 PM #15
      it's not the stock fuse panel for the 83 [IMG][/IMG]
      85-89 fuse panel
      Modified by eojthekid at 7:01 PM 11-21-2007
