VWVortex.com - How to reset the ECU
    Results 1 to 16 of 16
    Thread: How to reset the ECU
      Sep 5th, 2000
      Starkville, MS
      2006 CW GTI, 2012 CW Tiguan APR stg I, 1982 Rabbit Convertible
      11-26-2007 11:14 PM #1
      There's currently a discussion on the B6 forum about how the cars drive better after the OY update, but it appears that the imporovement is really just due to the tech resetting the ECU to defaults as part of the update process. Obviously, disconnecting the battery will reset the ECU, but is there another way?
      For example, when I replaced the battery in my son's 2001 Audi A4, there was some procedure I read about on the web where I switched on the ignition (but didn't crank the engine) and then floored the accelerator for 30 seconds or something to reset the ECU. Is there a similar trick for the MKVs?
    2. Member User_In_Hiding's Avatar
      Dec 26th, 2003
      Philadelphia, PA
      '91 Ecodiesel, 2009 BMW 328i
      11-26-2007 11:47 PM #2
      Your confusing a throttle body alignment and resetting the ECU.
      To reset the ECU you can unhook the battery and touch the + and - (not on the battery obviously), the ECU will also reset if you clear your DTC's with a VAG-COM.
      For a TBA you can do it without a VAG-COM but some will argue it's not as effective. To do it without a VAG turn the key on but don't start the car, dont touch the throttle let it sit for around 60 seconds. To do it with a VAG-COM read here.
      http://www.ross-tech.com/vag-c....html
      Nick @ BlownEuros
    3. Member User_In_Hiding's Avatar
      Dec 26th, 2003
      Philadelphia, PA
      11-26-2007 11:48 PM #3
      Forgot to add any time you unhook the battery you should do a TBA [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Nick @ BlownEuros
    4. Member Idleone's Avatar
      Jan 2nd, 2006
      SudLager, Vilseck, Germany
      11-27-2007 12:12 AM #4
      Got a question for you:
      If you reset the ECU or unhook your battery, will the changes you made via VAG com disappear? Such as no seatbelt warnig, disable DRL, windows open / close via fobs, etc...
    5. 11-27-2007 12:57 AM #5
      just perform a basic settings on the ecu..
    6. Member rysskii3's Avatar
      Apr 18th, 2006
      SoCal
      MKII Race Car
      11-27-2007 01:59 AM #6
      Quote, originally posted by Idleone »
      NO. to reset ecu all u do is unplug the batter for few min and thats it. all ur vag com setting will stay there
      Missouri School of Dentistry and Oral Health.
      OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
      FS: 16v performance/oem parts and tools
      Project Гольф Мк2 (R1 Carbed)
    7. 11-27-2007 03:42 AM #7
      edit.....
      Modified by oakley75 at 8:24 PM 11-29-2007
    8. Member User_In_Hiding's Avatar
      Dec 26th, 2003
      Philadelphia, PA
      11-27-2007 09:16 AM #8
      Quote, originally posted by oakley75 »
      I guess I should to a TBA via vag-com. I followed the link but I'm not sure which procedure to follow. Anyone have any ideas? I have a 2006 Jetta TDI.
      Thanks
      It should be the last one.
      "Turn the key on but do not start the car.
      [Select]
      [01 - Engine]
      [Basic Settings - 04]
      Group 060
      [Go!]
      It should say "Basic Settings: OFF" on the top of your screen.
      Click [ON/OFF/Next] to turn on Basic Settings.
      It should now say "Basic Settings: ON" on the top of your screen.
      Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
      Click [ON/OFF/Next] to turn off Basic Settings.
      It should now say "Basic Settings: OFF" on the top of your screen
      Click the [Done, Go Back] button and you're all set.
      Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!"
      Nick @ BlownEuros
    9. 11-27-2007 10:59 AM #9
      from the same link you posted:
      "This should be obvious but TDI's do not have throttle bodies."
      and below is where the person you replied to clearly states he has a TDI.
      Thanks
      Modified by MostWanted at 11:07 AM 11-27-2007
    10. Member User_In_Hiding's Avatar
      Dec 26th, 2003
      Philadelphia, PA
      11-27-2007 11:23 AM #10
      Ha I guess thats what I get for not ready his entire post Didnt see he had a TDI [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Nick @ BlownEuros
    11. Member
      Sep 5th, 2000
      Starkville, MS
      11-28-2007 12:06 AM #11
      Quote, originally posted by User_In_Hiding »
      Your confusing a throttle body alignment and resetting the ECU....snip...
      You are correct. Actually, it occurred to me this morning that I didn't really mean the ECU, I was really thinking about just resetting the adaptive transmission to defaults. I could swear I had read (years ago) that there was a procedure to reset the adaptive trans in MKIVs that didn't involve unhooking the battery. If I find out for sure one way or the other, I will repost. Thanks
    12. 11-28-2007 01:00 AM #12
      you need vag-com to reset the ecu, or tcm.
    13. 11-28-2007 12:12 PM #13
      i think you are referring to this:
      http://wiki.ross-tech.com/inde...ation
      kick down section specifically.
    14. Member
      Aug 23rd, 2007
      Bronx NY
      MK7 GTI
      11-28-2007 12:38 PM #14
      wat purpose does a TBA serve?
      IG: patrickvas
    15. 11-28-2007 12:51 PM #15
      if you look over the following link originally posted by user_in_hiding it gives you a quick run down on why its useful/needed.
    16. 03-11-2017 07:36 AM #16
      Hi, I have a VW Jetta MK5 2.5l.
      I need know How to reset The BCM, because i have installed The xénon canceller and my left lowbeam no turn off.
      I'm Sorry for my english.
      Thanks.
