Page 2 of 9 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 307
Thread: *** DENSITY LINE MOUNTS - MKIV Platform - 1.8T ***
  1. Member crazyass713's Avatar
    Dec 27th, 2006
    01 Golf mid-enine 2.7T Twincharged, 04 B6 USP 2.0T built
    12-02-2007 06:54 PM #36
    2001 Golf mid-engine RWD Allroad 01E 2.7T TVS1320 BW S374 twincharged (long title, I know)
    2004 A4 Ultrasport 2.0T 3076R built to the hilt all the way around (daily sleeper status)
  2. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-02-2007 08:38 PM #37
    Quote, originally posted by ethorman »
    What durometer does the VF mounts use anyone?? That way I have something to compare to? I daily my TT but if the race are not that bad then I would just as well go with them.
    You mean the track?
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  3. 12-02-2007 10:53 PM #38
    Quote, originally posted by crazyass713 »
    check out this thread http://forums.vwvortex.com/zerothread?id=3567938
    good reading.
    I found it interesting that one person said his VF dogbone inserts cracked. My dogbone is an energy suspension if I remember correctly... or was it Prothane.. been a while. Anyhow, I just didn't realize that the polyurethane was prone to cracking like that. Guess I need to inspect mine for piece of mind.
    Sooo the mounts in this thread are not poly, right? Just a hard rubber? Harder than poly, or from reading about the different densities, perhaps that's all relative.
    As mentioned above, what is the density of each of these mounts?
    EDIT: Nevermind, I will just do the math. If the OEM are 50A as stated in the linked post and your street are 25% stiffer...
    That would make them approx. 62.5A.
    The Track mounts (at 90% stiffer) would then be approx. 95A.
    Is this accurate?
    Modified by 18Tdesign at 10:58 PM 12-2-2007
  4. Banned
    Nov 1st, 2007
    12-03-2007 03:40 AM #39
    Every VF dogbone insert i've seen installed on a big turbo car has puked out the bushings repeatedly. The bushings do not have enough bearing area and they are too soft. Putting harder ones in makes them rattle like hell.
    I prefer the stock mount with an insert. It vibrates less too.
  5. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-04-2007 02:15 AM #40
    Quote, originally posted by 18Tdesign »
    The Street Density are 60A and the Track units are 80A.
    The Track Density units will be stiffer than anything currently available on the market.
    Hope this Helps.
    Email | Facebook
  6. Member 20VT*J4's Avatar
    Aug 28th, 2001
    Selegna Sol, AC
    12-04-2007 11:30 AM #41
    very nice, I think I'm going to need a set soon
    PSN:Jae304
  7. Member Navydub's Avatar
    Sep 29th, 2006
    Pleasant Prairie, WI
    Saab STi and a Land Rover
    12-04-2007 02:57 PM #42
    Ok now youve got me strongly considering these just a quick question .
    Currently I'm running a T3s60 but this spring i'll be stepping it up to a 3071R. I drive the car basically everyday to and from work, and will be tracking it on weekends.
    Now with the exception of rattles which don't bother me at all, is there any reason I should NOT run the track density?
    Turbo Unicorn | HS Tuning | 42DD | Cabin Krew
  8. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-04-2007 03:28 PM #43
    Quote, originally posted by Navydub »
    None that I can think of.
    Email | Facebook
  9. 12-04-2007 04:13 PM #44
    Will the street density mounts be enough to stop wheel hop or should I get the track density? It's not really bad wheel hop, just sometimes when I get on it too hard from a stop it'll hop.
  10. 12-04-2007 05:08 PM #45
    Just ordered all 3 Track Density. Looking forward to trying them out.
  11. Jason@INA
    Guest
    12-04-2007 07:56 PM #46
    Quote, originally posted by WOB-SH573 »
    you're going to love these mounts!
  12. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-07-2007 08:44 PM #47
    Quote, originally posted by Density Mount Install, Mk4 GTI »
    A good friend of the shop Jimmy Loushin, upon hearing about our Mk4 Density Mount release, started snooping around the shop with his hands in his pockets, flashing puppy dog eyes at us...how could we resist. "Alright Jimmy, pull your car in the back, Street Density it is!"
    Jimmy's Street Beast Chick Magnet
    A shot of Jimmy's mounts before they were...mounted
    I would highlight the install of the mounts, but our tech Mike took about 30 minutes to install all 3 as per the factory procedure - nothing special. Since 034Motorsport Density Line mounts are built by an OE manufacturer to our specifications, they fit and are finished just like factory products. No slotting of holes, no untested designs, we simply take what the factory did, and make it better suited to performance applications.
    Our Street Density "Dogbone" Mount Installed. Looks like stock, but looks don't tell the whole story
    One grapple with a Density mount will quickly assure you these are not just re-boxed factory mounts, and no poly filling or other tricks of the trade to stiffen up an OE mount. We go right to the source of what makes these mounts resist engine movement - the rubber.
    A definition for rubber durometer is as follows: Hardness as a property of rubber is difficult to define except according to the methods used to determine it. These methods measure the resistance of the stock to indentation by the blunt point of a metal rod, ball, or needle. Thus the hardness of rubber can best be described as resistance to indentation. Various instruments measure indentation. The most common instrument used on rubber is the Durometer.
    A shot of the 034Motorsport Durometer Tester
    A picture of the Durometer being used on a factory mount to determine its "stiffness"
    Before we finalize on a given spec for the Street or Track density, OE sample mounts are tested with sample durometer ratings, generally the bigger the number the stiffer the mount. Most OE mounts fall in a 30-45 durometer range, rarely higher than this.
    Generally, Street Density mounts are developed to provide minimum drivetrain movement (or slop) with minimum NVH (noise, vibration and harshness). Usually the perfect balance results in a 50-60 durometer range, and a slight noticeable hum at idle and the faintest vibration. Most passengers, when entering the car, wouldn't feel it unless you pointed it out. Street Density mounts are perfect for the daily driven car where comfort and performance are both priorities, and a faster transfer of power is desired. Think of Street Density mounts like a "lowered, stiffer" suspension for your drivetrain.
    Track Density mounts are, for all practical purposes, solid mounts, with no concern for comfort or lack-of-vibration - only an unadultered lockdown of the drivetrain. Durometer vary in the 70-90 range, and result in a locked-down, fast reacting, razor sharp drivetrain. You hit the throttle, air rushes into the motor, TQ and HP are produced , transferred to the input shaft of the transmission - and instant power to all driven tires.
    The problem with OE mounts is that there is so much softening of the rubber in the mount to prevent NVH, that power delivery is compromised. The time lag between when you hit the throttle and when power is actually transferred can be greatly delayed. Instead of applying power to the ground, the first few rotations of the tire are spent loading up the squishy, high travel mounts. Also, shifts can get sloppy and even can be missed with such great drivetrain movement. Also, hard launches and drag launches cause the drivetrain to load up hard and bounce causing intercooler plumbing, wire harnesses and other components to be stressed, even causing damage to the motor or other ancillaries. We've even seen motors dent the hood !
    If you've spent time to modify your exhaust, put on a bigger turbo, chip your car or stiffen up your suspension, don't ignore the performance value of a properly controlled drivetrain. Faster power transfer, more precise handling, safety and longevity are to be gained with a drivetrain mounting system suited to the upgraded performance of your car.
    YOU CANT EVEN TELL!
    Hope you guys enjpyed this Tech Article provided by 034 Motorsport
    Email | Facebook
  13. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-09-2007 01:37 PM #48
    Email | Facebook
  14. 12-09-2007 05:46 PM #49
    What about something for a VR6, more namely an R32?
    Also, do you fill the voids or are these just harder mirror images of the stock rubber inserts?
    Anthony
  15. 12-09-2007 09:51 PM #50
    With the replacement of motor mounts new stretch bolts are in order. Do you provide these?
  16. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-09-2007 09:56 PM #51
    Quote, originally posted by 95GLX »
    Anthony
    VR6 is coming soon.These are OEM replacements built to 034 Motorsport specifications.
    We can if the buyer wants.
    Email | Facebook
  17. 12-09-2007 10:52 PM #52
    Quote, originally posted by INA »
    That doesn't answer the question. Are they the same dimensios, ie a copy of OEM rubber inserts just in a different durometer or are they larger/different rubber pieces?
  18. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-09-2007 10:58 PM #53
    Quote, originally posted by Adam@Unitronic.ca »
    There is no rubber inserts.....its 1 complete unit and yes they are different durometer to stock.
    Email | Facebook
  19. 12-10-2007 01:14 AM #54
    still curious how you get the engine mount in there.
  20. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-10-2007 01:26 AM #55
    Quote, originally posted by Sketchykid »
    Majic
    Email | Facebook
  21. Jason@INA
    Guest
    12-10-2007 03:55 PM #56
    Majic
    houdini?
  22. 12-12-2007 11:38 AM #57
    Any way to get just the engine mount? I already have the Dogbone and Tranny mounts from BFI.
  23. Jason@INA
    Guest
    12-12-2007 12:17 PM #58
    Quote, originally posted by Rogue Status »
    check your im.
  24. 12-12-2007 07:35 PM #59
    Mine showed up today! Looking forward to trying them out.
  25. 12-12-2007 11:58 PM #60
    My StreetDensities are installed since Monday.
    The mounts really changed the way the car handles; its not subtle, I can really feel an improvement in the way the engine's torque is delivered to the wheels. Its hard to explain but when I step on the accelerator the power transfer is simply BETTER. Shifting through gears feels solid too. I've spent (IMO, a lot of) $$$ on improving power alone, but these mounts help in making the most out of it.
    There was, however, an as-equally-noticeable increase in NVH. I did some highway driving and at 90-100mph in 6th gear the exhaust was droning quite a bit. Some trim bits have started to rattle, I'll have to isolate them better but it should be a piece of cake. My car is a DD so I guess if I had the Tracks in I could be really annoyed, but with the Streets its all in the margins of reasonable (and that is subjective I know).
    to 034 and INA for these mounts!
  26. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-13-2007 01:06 AM #61
    Quote, originally posted by kust0m337 »
    Thanks for the honest review....much appreciated. for you for taking the time to do this for me
    Email | Facebook
  27. 12-13-2007 08:51 PM #62
    NP!!! I really my new mounts!!!!
  28. 12-17-2007 06:29 PM #63
    thats good to hear got mine 2 cant wait to see what there like but unfortunately my car will be offroad for a little longer
    made a little vid of my stock 1s compared to the street density 1s!
    http://forums.vwvortex.com/zerothread?id=3594353
    top stuff ina / 034 just wish you would advertise your stuff alltogether and not release stuff every week
    please no more till after the holidays ye?
    “Even smart kids stick their fingers in the electrical sockets sometimes.”
  29. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-17-2007 06:30 PM #64
    Quote, originally posted by greek 1.8t »
    I got some hot stuff coming out in around christmas day....
    Email | Facebook
  30. 12-17-2007 06:38 PM #65
    note to self: stay away from the tex
  31. Member G-Shock's Avatar
    Jun 14th, 2002
    Chandler, Arizona
    2002 Relex Silver 1.8T VW GTI
    12-19-2007 01:30 AM #66
    I think I might need to buy these.
  32. 12-19-2007 04:24 PM #67
    I want a dogbone mount, sweet deal!!
  33. Jason@INA
    Guest
    12-22-2007 01:45 PM #68
  34. Member
    Dec 22nd, 2002
    CT
    12-22-2007 04:02 PM #69
    how much for just the Engine Mount (track) already have bfi trans and dogbone stg2 mounts
    thanks
    2010 MB GLK350 4matic
    2009 Gti 2.0t powered by APR (Sold! last VW purchase!)
    2001 Gti 1.8t powered by Dalhback (sold and will be missed :') )
    1988 Jetta Carat Vr6 powered by www.LugTronic.com (99.9% done!!! )
    1987 Scirocco 16v w/t3t4 57trim powered by SDS (sold but never forgotten)
  35. Member UmbroVR6's Avatar
    May 23rd, 2000
    Miami, FL.
    98 GTI VR6, 01 Jetta 1.8T
    12-23-2007 01:44 PM #70
    i know the vr6 was mentioned as coming soon. that does include the R32 correct?
    LEASE THIS SPACE
