VWVortex.com - One of the WIPERS doesn't WORK! HELP!
    Results 1 to 14 of 14
    Thread: One of the WIPERS doesn't WORK! HELP!
    1. Member supavr6lover's Avatar
      May 7th, 2004
      St Paul, MN
      2015 GTI
      12-01-2007 04:51 PM #1
      So it was snowing today and i was driving and about 20 minutes into the drive my driver side windshield wiper stops working.. ?? it's all flimsy and crap.. i think the bolt thngy got loose.. my passenger side works fine but my driver side is loose like a goose.. any diagrams to help me fix it? or is my problem guessing totally off?
      Hi Signature
    2. Member DUTCHMANia's Avatar
      Apr 7th, 2003
      the Netherlands
      Jetta Coupe (1989) GTI (1988) Audi Cabrio (1992)
      12-01-2007 04:54 PM #2
      just open the hood and remove the plastic raintray cover.
      under that you'll see the mechanism and motor for the wipers.
      look at the axle on the motor. the bolt probabl has come loose and one stalk has come off.. 5 mins work no diagrams needed.. not much that can go wrong there. esspecially since the other one's still working
      Welcome to the internet:
      Where men are men, women are men, and little girls are FBI agents.
      Member of VOLKSFORUM.COM
      "I like my women like i like my coffee,.... plastic cup"-Eddie Izzard.
    3. Member supavr6lover's Avatar
      May 7th, 2004
      St Paul, MN
      2015 GTI
      12-01-2007 04:56 PM #3
      Quote, originally posted by DUTCHMANia »
      swweet thanks man. .. if anyone else has any info, please let me know!
      Hi Signature
    4. Member Deaner's Avatar
      Dec 28th, 2004
      Alberta
      mk2 vr6 , scirocco, landcruiser
      12-01-2007 04:58 PM #4
      either that or the splines inside of the wiper arm are stripped
      Feb 4th, 2007
      Pennsylvania, U.S.
      1991 Golf GL
      12-01-2007 05:57 PM #5
      Or they're just filled up with crud. See: http://forums.vwvortex.com/zer...99174
    6. 12-01-2007 06:43 PM #6
      Quote, originally posted by Deaner »
      x2
    7. Member supavr6lover's Avatar
      May 7th, 2004
      St Paul, MN
      2015 GTI
      12-01-2007 07:03 PM #7
      eh the arm came loose.. how am i post to stick it back on? it's not a bolt and it doesnt seem to screw on to anything, it's SQUARE!.. i loooked around and found nothing that fits it.. argAH i cant even get the square bolt thingy to go through the arm..argh
      Hi Signature
    8. Senior Member ratdub's Avatar
      Jan 16th, 2005
      hamilton township, nj
      stock TSI & stage 2 FSI
      12-01-2007 08:44 PM #8
      square? didn't know round blocks fit square holes
      odds are it isn't a vw wiper...but deff. make sure the splines arn't stripped...
    9. Member supavr6lover's Avatar
      May 7th, 2004
      St Paul, MN
      2015 GTI
      12-02-2007 01:20 PM #9
      using this as my winter beater really is sucking with this one busted wiper ..lol.. ill take photos later..
      Hi Signature
    10. Member supavr6lover's Avatar
      May 7th, 2004
      St Paul, MN
      2015 GTI
      12-07-2007 01:28 AM #10
      well i couldnt find a freakin camera nor the time to take a picture .. so i took someone elses and pointed out what fell off..
      the red outlined piece came off and can move freely down, the black outlined piece can be pulled up and down without unscrewing anything.. is my windshield wiper done for? how do i fix? ill try better pics later
      Hi Signature
    11. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      Barbie Jeep Power Wheel
      12-07-2007 01:29 AM #11
      You probably stripped the arm where it attaches to the shaft. Clean it and probably you'll have to replace the arm. Sometimes a washer and tightening it a little more works.
    12. Member supavr6lover's Avatar
      May 7th, 2004
      St Paul, MN
      2015 GTI
      12-07-2007 03:11 PM #12
      Quote, originally posted by The_Hamster »
      thanks, ill give that a try..ill clean it good.. im gonna try to work on it all day tonight ..because driving my mk2 for winter with no windshield wiper sucks...
      Hi Signature
    13. 03-28-2008 10:10 AM #13
      Hi i've just had my MOT wiper's worked fine, on the way home started to rain went to put my wipers on and nothing. front wipers don't work, rear wipers don't work and water jets don't work. Any suggestions, i've tried and tested the fuse.
    14. Member
      Nov 19th, 2004
      Vancouver BC, Canada
      1992 Jetta
      03-28-2008 07:43 PM #14
      you might want to start your own thread on the topic instead of hijacking someone elses. you will probably get more responses that way.
      I'd suggest how you might fix your wipers but I honestly dont know.
      Gumby
