VWVortex.com - Oil pan torque specs.
    Results 1 to 8 of 8
    Thread: Oil pan torque specs.
    1. 12-10-2007 07:50 PM #1
      I cracked my oil pan this weekend and my insurance is saying it falls under collision and not comp ($400 deductible vs $100.)
      1st VW parts has a R32 oil pan online for sale for $161.93.
      I guess I'll be replacing the oil pan myself.
      What are the torque specs for the bolts on the oil pan?
      How about the three that hold the oil pan into the transmission?
      Any other advice?
    2. Member Spoolin1X's Avatar
      Feb 25th, 2005
      NYC
      HPA FT465 R32 RIP, 1964 Impala, RS5
      12-10-2007 09:55 PM #2
      actually the pan that is $161.93 from 1stvwparts.com is not the correct one.
      make sure you look up this part #
      021103601L
      it is listed at $196.05
      i had the same issue and they shipped me the A3/S3 3.2L oil pan, slightly different that our oilpan.........
      Hitting switches in NYC.
    3. 12-10-2007 10:13 PM #3
      Quote, originally posted by Spoolin1X »
      Thanks for the heads up.
      They called me and let me know of this and then corrected the order..
      What torque specs did you use? Good and tight?
    4. Member graeme86's Avatar
      Jun 27th, 2003
      Brisbane Qld
      2004 DBP R32; 1971 Superbug
      12-10-2007 10:29 PM #4
      You need the special sealant for the sump as well -
      D 176 501 A1 (the tube actually says "Loctite 5970 - 50ml")
      The 5mm allen head sump bolts are only 12 Nm
      The large gearbox bolts are 45 Nm
      PM if you are looking for: Euro Headlight switches; RHD folding Stubbies.
      OEM+ freaks click here: Graeme's Webspace - Latest Updates: TPMS; More cluster programming goodies; Fuel & Brake Line Protection; Audi Rear Wiper; Passenger Footlight Mounting Bracket.
    5. Member graeme86's Avatar
      Jun 27th, 2003
      Brisbane Qld
      12-10-2007 10:31 PM #5
      ...they shipped me the A3/S3 3.2L oil pan, slightly different that our oilpan.........
      Could you see what the difference was - was it just that the Audi one has the oil sensor hole in the bottom?
    6. Member Mike Solo's Avatar
      Jan 25th, 2005
      2011 135i, 2007 Mini Cooper
      12-10-2007 11:38 PM #6
      Quote, originally posted by graeme86 »
      It's not just the level sensor, it seems like it's not as deep as our oil pan.
    7. Member Spoolin1X's Avatar
      Feb 25th, 2005
      NYC
      12-11-2007 12:44 AM #7
      Quote, originally posted by Mike Solo »
      correct, it had "more" baffles incorporated into it. and the height of the pan was shorter.
      if one were inclined to try to use it the oil pick up would need replacing as well.
      like i said in a previous thread, i was gonna end up using it but because of $$$$ issues i don't have the time to mess around with it...
      ~Kris
    8. 12-11-2007 02:22 AM #8
      Thanks for the info..
      I have a tube of
      " 12346141 - GM Gray Assembly Adhesive Silicone Sealant"
      so I'm good to go.
