Page 8 of 10 FirstFirst ... 4 5 6 7 8 9 10 LastLast
Results 246 to 280 of 333
Thread: 3.6L FSI 6 speed Corrado build 366C project
  1. Member HWY_GRZ's Avatar
    Apr 13th, 2004
    92 gti 20v bt in the works... 98 gti vr6... 96 carbio..2001 a6 2.7T
    03-23-2010 01:50 AM #246
    saw the car today this exhaust is a work of art
    must say this car is going to be amazing when its on the road
  2. 03-23-2010 04:36 AM #247
    What will you do with all those 02 sensors?? You used to have three on each side, one before cat, one between cats, and one after cats, is that true??
    Now you only have one cat, and you go into one pipe much sooner...
  3. Member DWI_gti's Avatar
    Jan 11th, 2004
    NJ
    03-23-2010 10:41 AM #248
    Green coolant is a big no no, I would change that if i was you. but on a positive note really interesed in hearing the reamus muffler with the 3.6L post vids once its running
  4. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    92 jetta 93 corrado 89 cabriolet 96 passat and more !
    03-23-2010 11:30 AM #249
    Quote, originally posted by Szandman »
    Well we have elimated the other four. The primary o2 sensors are the important ones.They control adjustments and fueling. The other four check to see the emmissions wernt tamperd with (ex punching the cats) so they will throw up the engine light when the cat is not working. I will program them out of the ecu. If it cant be done ill put them in the exaust behind the cat.
    3.6L project http://forums.vwvortex.com/showthrea...d-366C-project
    Burnouts are for losers in high school. Front wheel drive burnouts are gayer than aids. Whoever started the "burnout meet" should go deepthroat a cactus
  5. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    03-23-2010 11:32 AM #250
    Quote, originally posted by DWI_gti »
    ammm....... sure ...you are not me and im not changing it. The green in this car is better than the g12....ive done my research.
  6. Member JustTheTip's Avatar
    Jan 22nd, 2008
    West Chester,PA
    2010 GTi,1998 GTi (stock),1998 GTi(aba/16vT),1998 A4,1997 A6,1995 A6..etc..
    03-23-2010 03:48 PM #251
    The green coolant is only an issue if you have G12 in the system, G12 when mixed with any other coolant blend actually turns into an acidic mixture and corrodes anything aluminum or alloy....By itself the Green coolant is fine...
    I like cars.
  7. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    03-23-2010 04:00 PM #252
    Quote, originally posted by JustTheTip »
    well said and very true
  8. Member got_vdub's Avatar
    Jul 3rd, 2003
    ORT
    09 JSW 97 Golf 2.0
    03-24-2010 11:03 AM #253
    WATCHED
    SteveO@OpenRoadTuning.com
    OPENROADTUNING | BagYard AirRide | CANIBEAT | Nothing Leaves Stock | FIFTEEN52 | Homegrown Motorsports | Adaptec Speedware
  9. Member Malkierie504's Avatar
    Oct 6th, 2007
    New Orleans, Louisiana
    '60 Cadillac ambulance/hearse combo, '88 nissan pulsar nx xe, '01 MK4 GTI GLX
    03-25-2010 12:57 AM #254
    i bow down in amazement @ this build!
  10. Member jetta3dub's Avatar
    Sep 10th, 2006
    Aspers,PA
    1994 2.0 Jetta, 2001 1.8t A4, 1990 corrado RIP,
    03-30-2010 10:03 AM #255
    agreed. my mind has been blown
  11. Member SLC VRse6y's Avatar
    Dec 27th, 2004
    Freehold NJ
    04-01-2010 12:24 AM #256
    this car is fkn sickkkk
  12. Member andyztoy's Avatar
    Jan 21st, 2006
    oshawa - dirty south end with the crack heads
    92 jetta td - 2004 636 ninja
    04-01-2010 12:54 AM #257
    exhaust looks amazing
    however, i am still feeling a bit under the weather from you hot boxing your basement with gas fumes cleaning the heat shields
  13. Member URTurboFreak's Avatar
    Oct 21st, 2005
    Vancouver, Wa
    1993 Audi S4
    04-05-2010 12:45 AM #258
    MMMM 3.6L VR Corrado...AAAAAAUUUGGGGG (**DROOLING**)
  14. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    04-09-2010 06:16 PM #259
    update .. made a bracket for the fuel pressure regulator hooked up the fuel lines and started the car up. IT STARTS but shuts down b/c of the immoblizer. Now its time to send the cpu out for programing
  15. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    05-06-2010 12:26 AM #260
    work is getting done slowly........
  16. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    05-10-2010 02:00 AM #261
    update
    I cut out the rebar for the foglights. Then sand blasted and powdercoated the rebar. I installed all the lights and front end. My euro lip came from EPP it was folded in 2 places when they shipped it. Fail ! I ended getting one from the stealership FTW. Now its starting to look like a car. Im waiting on the ecu. Next ill make a intake pipe and box.
    heres some pics.
  17. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    06-10-2010 11:43 AM #262
    This car should be done for end of June just waiting for some key parts and ill update this thred
  18. Member engai69's Avatar
    Sep 9th, 2005
    Right outside of D.C.
    1989 Jetta Coupe
    06-14-2010 12:50 PM #263
    Quote Originally Posted by ERD View Post
    Quote, originally posted by engai69 »
    ok...unsubcribe. I don't believe you have the motor or any motor except for the one that came out of that thing. We usually see the motor after a certain time. Is this a wish list? Did you really mean 1.6L 4-speed Corrado build? Just asking. There is a guy who is actually doing it and showing what he is doing for the people who are thinking about doing this. I am switching channels. Thank you and good night. boooooooo
    well i do have a life outside the vortex ......thanks for comming out
    Thanks ERD for making me eat crow. That thing is looking good and coming along excellent. I was thinking back to your comment above and the same happened to me..."life outside the vortex". So accept my humble apologies for being the typical vortex ass. I am back to normal now. lol SUBSCRIBED!!!
    I might hit you with some questions (a lot of questions) because I might change up from 2.8 to a 3.6 (or 3.4) if I can find one. Great build.
    Facebook NGai's Jetta
    Coupe Nation FB - MK2 Jetta Coupe
  19. Member g60vw's Avatar
    Oct 3rd, 2002
    Anchorage, AK
    83/4 Rabbit w/ 2067cc 16v, 75 4dr ST, 85 4kQ for DD'n, F-350 haulrig, and Richard Pryor
    06-15-2010 04:22 AM #264
    In.
    An amazing build and an amazing ability to not get pulled into the Vortex squabbling.
    Talk softy and swap a big VR!
  20. Member xcrashx's Avatar
    Mar 19th, 2009
    Maine
    BH Outback
    06-28-2010 02:22 PM #265
    anything new?
  21. 06-28-2010 04:38 PM #266
    ay erd, why are u use an adjustable fpr? just curious.
  22. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    06-28-2010 09:09 PM #267
    yes their are new things with the car. Ill update you after the long weekend. As for the fpr i eliminated the single line computer controlled fuel pump (returnless system). Im using the stock corrado fuel pump and return line.
  23. Member mushroom_curry's Avatar
    Apr 20th, 2004
    Sunnyside
    07-13-2010 12:07 AM #268
    Been watching this for a while. Anxious for the end result!
    dasjettakartell - transcend trend - connoisseurism before consumerism
    vr6coilbracket.com
    Wroth European AutomotiveSterling Tire Services
  24. Member Mk2-Dub-GLI's Avatar
    May 25th, 2006
    Brampton
    '91 GTI '12 Focus Titanium
    07-13-2010 01:22 AM #269
    Mind Blasting
    -Dave
    Life Is Short So Grip It And Rip It.
    Quote Originally Posted by D_B_Jetta View Post
    Oops, sorry, The 15% off Promo Code: CANIHAVE15%OFFCUZIDRIVEAVWANDIMHELLABROKE
  25. 07-15-2010 07:56 PM #270
    wow this looks increadible!!
    Do you think maybe she'll be ready for VAGKraft at the end of Aug?
  26. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    07-16-2010 03:18 PM #271
    yes hoping to be done by vagcraft
  27. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    07-26-2010 01:37 AM #272
    Update....
    I was just about to ship my ecu out, and this guy(from unitronic) that was doing a 2.0t swap in a corrado said he has done the immo defeat before on the med 9.1. I wanted proof. None was provided. He begged me to do the immo defeat and said he can do it. Ok i gave him a chance. I shipped my ecu to Unitronic on april 15. They said they can do immo defeat should take about a week. 6 weeks go by and i have not herd from them. I inquire wat was going on and they said they are still working on it. I then asked why its taking so long. Then he said they had trouble doing the immo defeat. Give more time. Im now thinking this guy was lying, but i gave 2 more weeks. I inquire again he said we cant do it..........ship back my ecu. UNITRONIC CANT DO IMMO DEFEAT ON MED 9.1.. next i contact revo. They said they never did that one before and dont want to do it. I then contact the shop overseas they will do it, but then i got a call from one of the software enginers here and they have a guy that can do it. I meet the guy we chatted he told me he has not done this before but he can do it. I gave in my ecu. One week later i had my ecu back he said 95% that the immo was defeated. I go home to try it.
    On this day henceforth July 25 2010 18:03 hrs the MIGHTY CORRADO roared to life. The immo defeat was a success. WE have technology , there are great tuners here in Canada that do the impossible. Next stage is tuning and ill post pics and vids of REAL PROOF unlike other SHlT talkers, this swap is possible WITH FSI and stock ecu.
  28. 07-26-2010 08:25 AM #273
    congrats
    for some reason the unitronic bench flashed immob defeats dont take, only my personal experience.
  29. Member pdcm's Avatar
    Mar 29th, 2000
    DC Area
    81 Pickup, 93 Corrado, 05 Golf
    07-26-2010 08:38 AM #274
    Woohoo! Congrats ... I would have thought that Revo could have worked that ECU.. or did I read that wrong and it was one of the Revo people you ended up working with? Unless you're waiting to see how well everything works, this seems like a great bit of advertising for whoever did the immo defeat...
  30. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    07-26-2010 09:36 AM #275
    Quote Originally Posted by pdcm View Post
    thank you , but revo DID NOT have anything to do with this @ all. It was a small private company here Toronto that took the time and did the work. None and i stress NONE of the big companies had anything to do with my ecu.
  31. 07-26-2010 01:47 PM #276
    First off this is a sick project. But I have to disagree with your experience with Unitronic. I spoke to them at waterfest last year a week later I sent Mike S. my 2.0T FSI Ecu, engine code BPY, and he had it back to me in 5 business days with a stage 3 tune, immo defeat, vss and 02 exceptions written in and no ABS controller interface. it worked perfect right out of the box and the Unitronic guys were easy to deal with through the whole process.
  32. Member 1broknrado's Avatar
    Jul 6th, 2005
    Wilmington NC/Stratford CT
    24v Corrado
    07-26-2010 03:23 PM #277
    so someone had told me there was a r36 in a corrado already but i still want to do it however without FSI. what standalone do i havet o run in order to have the motor running and i know i need to convert to a cable throttle like older vr6s and have a custom short runner made.
  33. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    07-26-2010 05:19 PM #278
    Quote Originally Posted by kevinmacd View Post
    Well I have my emails backing my story. That was my experience with them.... it is what it is. but thanks , you also have a very nice clean jetta that i saw @ this years waterfest.
  34. Member ERD's Avatar
    Jul 19th, 2004
    Toronto Canada
    07-26-2010 05:24 PM #279
    Quote Originally Posted by 1broknrado View Post
    i used the stock fsi so i dono what you really need. I didnt do research that way.
  35. Member Mk2-Dub-GLI's Avatar
    May 25th, 2006
    Brampton
    07-26-2010 09:45 PM #280
    Quote Originally Posted by erd View Post
    update....
    I was just about to ship my ecu out, and this guy(from unitronic) that was doing a 2.0t swap in a corrado said he has done the immo defeat before on the med 9.1. I wanted proof. None was provided. He begged me to do the immo defeat and said he can do it. Ok i gave him a chance. I shipped my ecu to unitronic on april 15. They said they can do immo defeat should take about a week. 6 weeks go by and i have not herd from them. I inquire wat was going on and they said they are still working on it. I then asked why its taking so long. Then he said they had trouble doing the immo defeat. Give more time. Im now thinking this guy was lying, but i gave 2 more weeks. I inquire again he said we cant do it..........ship back my ecu. Unitronic cant do immo defeat on med 9.1.. Next i contact revo. They said they never did that one before and dont want to do it. I then contact the shop overseas they will do it, but then i got a call from one of the software enginers here and they have a guy that can do it. I meet the guy we chatted he told me he has not done this before but he can do it. I gave in my ecu. One week later i had my ecu back he said 95% that the immo was defeated. I go home to try it.
    On this day henceforth july 25 2010 18:03 hrs the mighty corrado roared to life. The immo defeat was a success. We have technology , there are great tuners here in canada that do the impossible. Next stage is tuning and ill post pics and vids of real proof unlike other shlt talkers, this swap is possible with fsi and stock ecu.
    awesome!!!!!!!! :d
    -Dave
