Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 71 to 105 of 267
Thread: Air management picture thread
  1. Member Plain's Avatar
    Jun 14th, 2004
    Near the Ohio ground.
    65' T-1 | 10' TDI JSW
    03-04-2008 09:19 AM #71
    Man's mind, once stretched by a new idea, never regains it's original dimensions. -OWHjr
    instagram.com/plainpaul
  2. Banned autobahmer's Avatar
    Jul 23rd, 2006
    03-08-2008 06:54 PM #72
    Quote, originally posted by sirswank »
    it's only a schematic, but for a simple up/down system, would this work?
    may i add that no one should do this set-up EVER. pay the extra few bucks and do it somewhat right. you need 8 valves, so each line has it's own pressure and it's adjustable. if you don't believe me, i hope you don't get sea-sick. ever been in a boat? that's what this set up entails and it's DANGEROUS.
    you can also get away with 4 check valves if you want to run 6 valves.
    Modified by rustslanga at 4:03 PM 3-8-2008
  3. Member basti-FSI's Avatar
    May 26th, 2006
    Germersheim, Germany
    03-10-2008 08:55 AM #73
    just found an old pic of my trunk
  4. 03-10-2008 11:41 AM #74
    great thread, I really LOVE those copper lines from the valves to the tank, they look absolutley amazing....
    I gotta think about that for my next setup in the audi for sure
  5. Member Santi's Avatar
    Mar 26th, 2004
    Dallas, TX
    '05 Bagged GLI
    03-13-2008 10:57 PM #75
    no it wont, unless the bag as 2 lines going to it one in and one out which would be stupid.
    do mroe research before you try to go a 'simple' set-up...
    you definitely should do an 8 valve set-up. Idk if your drawing is just lacking details and thats what you plan on doing, but thats definitely not gonna work.
    Here is mine: I used the suicide doors set-up and added my extra parts.
    Air by Santi | 561-723-9020 | AirbySanti@Yahoo.com | "It's an up & down kind of business"
    Airlift | AccuAir | Viair | HornBlaster | AirRideTech | Universal Air | SMC | Slam Specialties | ASCO | and many others...
    www.facebook.com/AirBySanti | www.Flickr.com/VWSanti
  6. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    '11 Raptor '12 Tiguan
    03-15-2008 03:06 AM #76
    did a little more work to it
  7. Member candela's Avatar
    Oct 19th, 2002
    miami, FL
    mk3 diesel box, porsche 911 SC, porsche 912E
    03-15-2008 10:52 AM #77
    Quote, originally posted by joezeeuw »
    what kind/size is that compressor? looks bad ass
  8. Member Retromini's Avatar
    Nov 7th, 2004
    Southern California
    2009 MINI, 1970 BMW 2002
    03-16-2008 10:13 AM #78
    MKV
  9. Member joezeeuw's Avatar
    Feb 23rd, 2003
    Grand Rapids, MI
    03-16-2008 11:50 AM #79
    Quote, originally posted by candela »
    El cheapo Airbagit. I clocked it so it would lay flat.
  10. Member Kevin@AAC's Avatar
    Jan 26th, 2006
    Toronto
    1952 Ford
    03-17-2008 02:54 PM #80
    Here is one I forgot about. Did this 3 years ago I think.
    *******www.airassisted.com*******
    Your #1 source for Air Suspension products, Open Saturdays 9-3pm EST
    Follow me on Twitter - Lots of Industry News! http://twitter.com/alteredaltitude
    Its AirRide, it isnt perfect!
  11. Member Kevin@AAC's Avatar
    Jan 26th, 2006
    Toronto
    1952 Ford
    03-17-2008 03:24 PM #81
  12. 03-17-2008 03:31 PM #82
    What's that plumbed into the compressor on the left on eithor side?
  13. Member Kevin@AAC's Avatar
    Jan 26th, 2006
    Toronto
    1952 Ford
    03-17-2008 03:34 PM #83
    Thats Robs hydraulic set up. On the left pump are accumulators for ride quality.
  14. 03-17-2008 03:37 PM #84
    Ok, those have to be the smallest accumulators I've ever seen. I've only seen ones that are a 2 or 3 gallon long tanks. I like that much bette. You custom make those or is there a supplier?
  15. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    01 Golf GLS 1.8T, 02 Jetta WGN 2.0, 11 JSW 2.5SE (Wifes)
    07-04-2008 01:43 PM #85
    The Setup
    Front
    Koni Coilovers (soon to be replaced by my rebuild FK highsports)
    UVAIR Aero Sport Front Bags
    Rear
    Firestone bags with the bolt in kit
    Management
    2 400 Viars
    5 gallon 9 port tank (I could have done a 5 port)
    Autopilot Digital Controller
    Chamber: My Wheels Rub on the Inside|Forgeline Wheels|WRDusa.com|
    FlickR
  16. Member PAULITO's Avatar
    Oct 23rd, 2004
    NY
    07 STI
    07-04-2008 02:09 PM #86
    Quote, originally posted by jason@bda-felgen »
    cleaned is the name of the game
    clean
    WET.
    PVW 7/08
  17. Banned Fat Jon's Avatar
    Feb 26th, 2007
    07-04-2008 09:16 PM #87
    Quote, originally posted by Shurls »
    It doesn't look like it would be that hard to make, just some 120 Aluminium Tube, cap the ends using a tig, and then drill and tap for fittings. Probably took about 2hrs to make.
    much better to use a solid block of billet, drill through all the way, drill in the 4 ports and thread all the holes... what size holes would you guys want.. and what kind of spacing between the holes... i could make these fairly easily.
  18. 07-06-2008 02:11 PM #88
    Quote, originally posted by Kevin@AAC »
    Of course, the caddy CTS.
    Kevin this is how I want my R32 done up...I can't wait.
    Truth is the light / Never give up the fight. -Bob Marley
  19. 07-06-2008 02:22 PM #89
    here's mine
    "Jacques Cousteau could never get this low."
    PVW - 05/09
  20. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    2010 VW JSW, 2001 Porsche 996, and 2004 Audi A8L
    07-26-2008 10:39 AM #90
    Incase you aren't quite sure what you're looking at.
    2008 Cadillac SRX with the tank and compressor mounted underneath the car. It's in a void above the spare tire. The spare tire mounts right back in it's stock location hiding what you see now. Valves are mounted inside the vehicle.
    This is exactly what I want to do with my tank and compressor on my Eurovan! Any problems with grime messing up the compressor? How about vibrations on the body when the compressor kicks in?
    SoWo Partners
    www.sowopartners.com
    Check out our webpage for SoWo, Kleen Freaks, and Liqui Moly Product Deals!
  21. Member Kevin@AAC's Avatar
    Jan 26th, 2006
    Toronto
    1952 Ford
    07-26-2008 01:22 PM #91
    Yes, when you mount the compressor under, it tends to resinate through the whole car. But it is a sealed pump so it can be done with no problems.
  22. Member MBounds@SOWO's Avatar
    Oct 24th, 2002
    Huntsville, AL
    07-26-2008 01:50 PM #92
    Noobie question: What pumps are sealed....Viair?
    SoWo Partners
  23. Member baggedbox707's Avatar
    Sep 1st, 2008
    Bay Area
    '10 VW Golf TDI
    09-12-2008 02:47 AM #93
    Yea, my setup is loud as hell cuz everything is installed underneath, but in all reality, is it any quiter in the cabin for all you wagons/hatchbacks?
  24. Member Santi's Avatar
    Mar 26th, 2004
    Dallas, TX
    '05 Bagged GLI
    09-12-2008 11:10 AM #94
    Quote, originally posted by SMOOTH »
    as far as i know only the big series, 450s, 480s.
    Quote, originally posted by baggedbox707 »
    what compressor do u have?? its easier to make it quiet on the inside of the car than the outside cause u fan put foam, or padding or dynamat to contain the vibrations and noise inside, outside the car the compressors have to be very secure otherwise they are gonna make bumper, and w/e else its close to them vibrate and make it even louder.
  25. Member rafiki2's Avatar
    Oct 9th, 2005
    Abu Dhabi, UAE
    2012 Audi A3 TDI
    09-12-2008 11:52 AM #95
    this is my favorite
  26. Member baggedbox707's Avatar
    Sep 1st, 2008
    Bay Area
    '10 VW Golf TDI
    11-06-2008 04:39 AM #96
    Quote, originally posted by Santi »
    The compressor is mounted securely to the exterior, but let's just say it's a suttle difference between the manufacturing of my toyota body and your vw body So everything outside the car is loud. I'm prolly going to move my compressor inside and dynamat around it with a vent line under the chassis. Compressor is a P.O.S. right now, but I have $300 to decide what my next compressor will be...
  27. 11-06-2008 05:02 PM #97
    Dang...
    Anyone got any photos of the exterior of this car?
    Thanks,
    Matt
  28. 11-06-2008 07:12 PM #98
    dakota digital mgmt
    Joosey - DubAudi - Banchwerks - ForceFed Engineering
    PVW 9/11
    Quote Originally Posted by uzi did it View Post
    you can compare me to kobe bryant of the vw world. i'm just that good.
  29. Member 2.0fsiwagon's Avatar
    Nov 26th, 2007
    Minneapolis. MN
    2007 VW Passat Variant
    12-12-2008 04:15 PM #99
    is that the Dakota Digital MGMT that Masontech sells on their site?
  30. Member f_399's Avatar
    May 8th, 2006
    Dallas-Fort Worth
    2007 VW GTI(SOLD), 2010 Passat Wagon, 2012 Jetta GLI
    12-12-2008 07:25 PM #100
    Simple to install
    Trunk space with access to full spare tire
    AJ
    Instagram: aj_p
  31. Member 2.0fsiwagon's Avatar
    Nov 26th, 2007
    Minneapolis. MN
    12-12-2008 07:50 PM #101
    Thats pretty badass...
    looks very clean
  32. Member absoluturq's Avatar
    Feb 28th, 2006
    1992 Honda Civic with spinner rims
    12-16-2008 11:42 PM #102
    arent the airpods $$$$$$$$$$
    instagram @sarpeezy
  33. Member f_399's Avatar
    May 8th, 2006
    Dallas-Fort Worth
    12-17-2008 09:16 AM #103
    it is a bit pricey
    AJ
    Instagram: aj_p
  34. Member Kevin@AAC's Avatar
    Jan 26th, 2006
    Toronto
    1952 Ford
    01-08-2009 05:17 PM #104
    TTT
  35. Member rollininstyle2004's Avatar
    Jun 8th, 2005
    ATL, NYC
    2001.5 VW Passat (RIP), 2002 Audi allroad 2.7T
    01-08-2009 06:43 PM #105
    2 2.5 Gallon Tanks
    2 400c compressors
    Easy Street Auto Pilot manifolds and management
    Everything else is in the back of the spare tire well (both compressors, manifolds, ecu, etc.)
    Current:
    2006 Audi A6 4.2 S-Line
    Past:
    2001.5 VW Passat 1.8T Rest.In.Pieces
    2002 Audi allroad 2.7T Sold
