Quote, originally posted by Capt. Obvious » Wish you were local!
We are only a flatbed, car hauler, and/or vehicle transport away lol. Although Washington State is kinda far......
Modified by Kevin@AAC at 3:08 AM 1-13-2008
#36
Thanks man. I will post some more later. We have done 100's of installs. And we have some nice new ones coming up.![]()
*******www.airassisted.com*******
Your #1 source for Air Suspension products, Open Saturdays 9-3pm EST
Follow me on Twitter - Lots of Industry News! http://twitter.com/alteredaltitude
Its AirRide, it isnt perfect!
#37
#38
Its done check the video!
#40
Quote, originally posted by Florida Flow » i need to get a pic of my set up on here Yea you do Ive been looking for some pics of a MKV setup???
#41
any pic of a MK2 install?? and what is the different between a single or double compressor in the system? and some used a 2/2 line and other a 5/2 or something like that.. what is easier or better??
#42
My all time favorite, and soon to be inspiration.
I hide behind .:Rudeboy
koolhaus - First Lady| Low.Life.Society | AAC | Unitronic | TMTuned
Fame is a vapor, popularity an accident and riches take wings. Only one thing endures, and that is character.
#43
Here's my work in progressValves, compressor and all other goodies are under the sub-floor in the spare tire well
#46
^^^ That's a badass looking setup!![]()
Who makes that valve block, I'm diggin' it!
#47
Quote, originally posted by Capt. Obvious » ^^^ That's a badass looking setup! ![]()
Thanks
Not sure who made the valves, I bought them used on ebay. They are actually two blocks. I made the distribution manifold thing out of a chunk of alluminum.
#48
I think your water separator is upside down by the way.Edit: Just realized the whole setup is turned upside down in that pic.
Modified by Capt. Obvious at 11:23 AM 2-11-2008
#50
Quote, originally posted by joezeeuw » yeah it mounts under the car Draggin tank....now that's ballsy
lol
#51
Quote, originally posted by joezeeuw » My low buck, used parts, ebay special. that is bad ass i must say...hmmm
#52
Those are Chassistech Valves. They work really good. I had the same deal but red (1/2" in's and out's)
#53
Quote, originally posted by joezeeuw » Thanks
That "air rail" is tight as foook. I want something like that myself.
too bad nobody makes it.![]()
#54
Quote, originally posted by Mr Schmidt » That "air rail" is tight as foook. I want something like that myself.
too bad nobody makes it.It doesn't look like it would be that hard to make, just some 120 Aluminium Tube, cap the ends using a tig, and then drill and tap for fittings. Probably took about 2hrs to make.
#55
Quote, originally posted by Shurls » It doesn't look like it would be that hard to make, just some 120 Aluminium Tube, cap the ends using a tig, and then drill and tap for fittings. Probably took about 2hrs to make.
You could do it that way. I just rifled a solid bar and drilled and tapped. just need a big bit and a pipe tap.
#56
Hmmm, that's even easier. It would eliminate the "Chamber" created with using tube. Not that a chamber would affect anything adversely though. That's not a cheap bit though, thats for sure.
#57
OR, you can do what I did and buy an anodized billet manifold already tapped and drilled for her pleasureit has a square profile, but tidys up the install and is tucked away.
#58
Quote, originally posted by jason@bda-felgen » OR, you can do what I did and buy an anodized billet manifold already tapped and drilled for her pleasure
Pics?![]()
#59
you'll see it when i redo some things in the upcoming months. i'll check to see if i took some uninstalled pics.
#60
my gauge in the ashtray (MK5)
#61
Quote, originally posted by basti-FSI » my gauge in the ashtray (MK5)
looks nice, how does the car i assume it is mk5 handles with just front/ back setup?
Modified by Rat4Life at 11:51 PM 2-28-2008
Complete air ride installs,frame notching,welding, in north jersey.
http://www.flickr.com/photos/rat4life/
roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
follow me on instagram RAT4LIFE
#62
yes, only front and back. side to side is illegal in germany![]()
#63
is there a reason for that??![]()
#64
no like it´s common in germany.![]()
#65
Mine is also in that area.![]()
Man's mind, once stretched by a new idea, never regains it's original dimensions. -OWHjr
instagram.com/plainpaul
#66
nice paul!? is this gauge from dakota like the grey tt from brittain has it?
#67
Yep. Its Dakota Digital, it's part of their Odyssey line. It's pretty good. I am having problems with my tank pressure sending unit.
#68
could you send me the name of a store selling it? i just read about that in the magazine performance vw with the grey audi TT...
#70
Quote, originally posted by passat_98 » what I have so far
looking really nice![]()
