#246
Team Foreign Objects
TAI-VW & Audi REVO 3 K04
Premiere Auto Service and Performance Rotiform TMB's-AccuAir eLevel w/Bagyard Bombers
podi-Single Gauge Pod w/Stepper Motor Boost Gauge Amber Club
#247
#248
Finishing it up this weekend, more to come. Everything will be hidden.
#249
Does anyone have any unique eXo mount setups to share?
- Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
#253
Just one more top cover to add over the electrical
#254
I used the frame from sean's ^^ last setup. Just finished installing E-level tonight and building a new floor. The pressure sensor is attached with a hardline the goes into the input on the other side of the vu-4 and wraps around the frame.
#256
My trunk setup:
I made a compressor anti-vibration rack, cuz i found the drone is too much in the cabin...
It is dead silence now! Especcialy with the isolation! also mounted a fan that comes on when the compressor kicks in.
The build is not ready yet, my goal is to isolate every panel that you can see.
And this is the place of my V2 controller:
Stealth:
#257
#258
#259
I got the most basic setup. No bling, just business. Stereo still to follow..
#261
Complete air ride installs,frame notching,welding, in north jersey.
http://www.flickr.com/photos/rat4life/
roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
follow me on instagram RAT4LIFE
#262
I was part of the Illeststance gangbang |IBaumgartner Brand Schiltach|My Mk2 GTI VR6 Build
#263
Question for those that know the answer.
1. When you air out the tank to drain water, do the bags air out too? Does the ECU prevent air leaving the bags?
2. Let say your ECU decides to roll over and play dead. Your car is all the way down and you need to leave. Is there something that you can do to take the ECU out, allowing air going into the bags and continue your day?
If your answer is YES for 1: Can you put a shutoff valve between the tank and ECU to prevent air going out?
If your answer is yes for 2: What kind of safe guards can you do to help this process.
Thanks
#264
with accuair manifold when draining tank you car will go down, with airlift dual manifolds car will stay up even if your tank is empty.
i have installed smc check valve before accuair manifold and it holds the pressure even if the tank is empty.
client was driving for a week without tank while the tank was getting powdercoated.
as long as you dont have any leaks in the system and dont air out,cause there is no air reserve tank.
also if your ecu is dead and car aired out, you are able to trow direct power onto the valves and activate them for a little to let some air in the bags.
one of my friends had to do that with his e-level when ecu just suddenly died and aired out whole car while he was driving on the highway. ( that was a scary moment)
#265
Keep it simple![]()
// DROP // DRAG // DESTROY // beer
// Open Road Tuning
Instagram: @bryangb
bags and wheels = build thread
#266
Adding a one-way check valve is some good info! thanks! That is the main thing that had my a little iffy on getting bags. The "what if" I have some pretty ****ty luck. So my next question, having a SMC check valve save your ass if the AccuAir ECU decides to die? Or does it just allow the air to stay in the tank if the ecu goes? I want the AccuAir set-up, just trying to put in safe guards to prevent themoments.
#267
