Page 1 of 2 1 2 LastLast
Results 1 to 35 of 59
Thread: Replace 24V VR6 Serpentine Belt
  1. 12-19-2007 04:56 PM #1
    If you need to replace your serpentine belt and don't want to pay the $300 stealership fee to replace it, then do it yourself. I have never touched a serpentine belt before and I decided to take this task into my own hands and after about 45 minutes I discovered it was very simple.
    Do this procedure at your own risk. I am not responsible for any mistakes that you make, any parts you break, or any other thing you try to pend on me.
    Tools Needed:
    --Socket wrench--
    --6mm hex socket bit OR 6mm allen wrench--
    --socket to hold the 6mm allen bit above
    --T20 bit--
    --bit screw driver (fits the t20)--
    --M8 1.25 pitch screw about 2 inches long (you can get this at home depot or ace hardware for 50 cents--
    --and of course a new serpentine belt (part # 066 145 933J)--
    To start off you may want to print this diagram, it displays the 24valve belt pattern.
    1) If your old belt is still in there pull it out.
    2) Start off by taking the front passenger wheel off and jacking the front passenger side of the car up.
    3) Remove the t20 screws in the passenger fender liner (you don’t have to do this but it just makes life easier) just to give you an idea
    4) Remove tensioner pulley by removing the 3 blue-green 6mm hex bolts in the picture below. I used a 6mm hex bit and a socket and ratchet to do this. This makes it easy to loop the new belt in, since the gap between the actual pulley and engine is tiny and makes it hard to get the belt into position.
    Installing New Belt
    5) Start off my looping the belt around the crank as shown below (if you don't know what all your pulleys are, refer to the first image as this displays them all for you).
    6) Next loop it under the power steering pulley and up and around the A/C pulley as shown below:
    7) Next loop it around the Alternator pulley as shown below:
    8) Now were going to move back down to the crank, and from the top loop the belt under the coolant pump (water pump) shown in picture above ^^^
    9) Now that you have done this thread the M8 1.25 2" Bolt you bought into the threaded hole in the tensioner pulley, shown below:
    10) Thread this all the way until it looks like this (there is a stopper that will prevent you from going too far):
    11) Now go back to your belt and pull it tight, loop the tensioner pulley in now (refer back to diagram to see how the belt is supposed to be) kinda tight area but tried to get the best pik as possible for you.
    12: Once that is in line the tensioner pulley arm back up with the holes in the engine to bolt the 3 screws back in. Tighten them back on. (I don't know exact torque, I just did then tight with a quarter turn)
    13: BEFORE YOU PROCEED
    Check you belt make sure it is lined up around each pulley and not hanging off the edge of a pulley. If it is then proceed to step 14, if not line it up so its on track.
    14) Back out the M8 screw you put in the tensioner (my bolt had a 16mm head yours may be different) Our cars have automatic tensioners and it will automatically tighten the belt to where it needs to be.
    Here is what my whole system looked like after:
    Bottom:
    Top:
    Tensioner: (notice the gap under the threaded screw hole--it should look like this...just incase your worried
    Modified by eurostiehl at 5:19 PM 12-19-2007
    Modified by eurostiehl at 5:48 PM 12-19-2007
  2. 12-19-2007 05:18 PM #2
    Very Nice!
    I have two questions.
    What's the part# for the belt?
    What was the condition of the Tensioner Pulley?
  3. 12-19-2007 05:21 PM #3
    i will get you the belt part number later i dont have it on hand. i got my from vw but ecstuning.com has them at half the price. as for my pulley it coulda been replaced..it has a little chatter to it, but i figured it would hold up for the time being. If you are planning on getting a new pulley i you can get that at the dealership or i think ECStuning.com as well
    Modified by eurostiehl at 5:26 PM 12-19-2007
  4. Member koko5869's Avatar
    Feb 15th, 2006
    Lehigh Valley, PA 18042
    04 BDF O2M / C5 A6 3.0Q
    12-19-2007 05:44 PM #4
    i actually have a belt sitting here in my room.
    066 145 933J sound right?
    its in the "compilation of technical info" thread on the top
  5. 12-19-2007 05:48 PM #5
    yep that sounds like it thanks ill add it to the top
    another funny thing is I got an OEM VW belt from the dealer ship, it even has a VW symbol printed on it, yet it also has this printed
    Modified by eurostiehl at 5:50 PM 12-19-2007
  6. 12-19-2007 05:54 PM #6
    Just because its a VW part doesnt mean it was made in Germany.... most of these cars are made in brazil, why woudl the parts be any different? Nice writeup!
  7. 12-19-2007 06:02 PM #7
    not sayign that all parts need to be made in germany...but i figured the last place would be japan and china...
  8. Member orange1218's Avatar
    Mar 22nd, 2007
    Lombard, IL
    06 BMP GTI, 03 24v VR6 (sold), 06 Passat
    12-19-2007 10:07 PM #8
    How did you know I was looking for this? Nice write up. How do we add this to the DIY?!?
    Modified by orange1218 at 9:09 PM 12-19-2007
  9. Member koko5869's Avatar
    Feb 15th, 2006
    12-19-2007 10:13 PM #9
    Quote, originally posted by orange1218 »
    hah, good luck.
    the real question is how can we get a 24v guru as a mod?
  10. Member orange1218's Avatar
    Mar 22nd, 2007
    Lombard, IL
    12-19-2007 10:29 PM #10
    Quote »
    This pic makes me think it might be a good time to put on some new pulleys. Anybody know anything about under drive pulleys for our engine? Read something about damaging the harmonics?
  11. Member
    Sep 21st, 2000
    Lancaster PA
    12-20-2007 06:25 AM #11
    I got the tensioner assembly from MJM for like $89? Complete part, everyone else wanted like $180 for the part. Gruvenparts is working on a tensioner pulley for us. They have my old one as a prototype. They also wanted a crank pulley, but, I do not have a spare to send them. If anyone has a spare, send it to them, they will make you one and then we will have another part for us.
  12. Member supavr6lover's Avatar
    May 7th, 2004
    St Paul, MN
    2013 Jetta 2.5 SE
    12-20-2007 09:20 AM #12
    OMG THANK YOU
    Why didn't I just buy a GLI?
  13. 12-20-2007 09:39 AM #13
    dont replace the crank pulley. it also acts as a harmonic damper and getting rid of it is bad.
  14. 12-20-2007 11:11 AM #14
    [QUOTE=orange1218]How did you know I was looking for this? Nice write up. How do we add this to the DIY?!?
    its already added to the DIY lol
    see the 24v diy forum below
    http://forums.vwvortex.com/zerothread?id=804369
  15. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    12-20-2007 05:20 PM #15
    Quote, originally posted by NOVAdub »
    yeah but replacing other pulleys shouldn't too much of an issue, especially not on an NA engine...the harmonic balancer is a bad idea on any engine really...it keeps vibration away, and it also keeps the crank in balance...its a calibrated piece
  16. 01-22-2008 12:35 PM #16
    Does anyone know what the dimensions are on the belt. Does 15/16' x 54-7/8' OR 24mm x 1394mm look right? The only reason I'm asking is because I bought my part from NAPA and I can't check it with the part number.
  17. Member apstguy's Avatar
    Apr 3rd, 2006
    Chico, CA
    2008 VW R32
    01-22-2008 03:21 PM #17
    I'm not sure about the dimensions, they are usually right with the VW belts as they only came in one length in the US (with power steering and A/C), however, they always gave me the wrong width (7 ribs instead of 6). Most 24V VR6s are 6 ribs, but some are the 7 rib(like the 12V) so count to make sure!!!
    2008 VW R32 #587
    Gone: 2002.5 VW GTI 24v VR6 - 180k+ miles
    *My other car is a 1985 Chevy C10* 305 Bowtie Overdrives 700r4 3.08 - Ssslllooowww but sexy!
  18. 01-23-2008 02:08 AM #18
  19. Member Kevin0323's Avatar
    May 3rd, 2006
    Puyallup
    2002 Jetta GLS
    02-25-2008 12:44 PM #19
    On a 2.0 serpentine belt tensioner there isn't a bolt, more like a female star shaped screw hole. However I need to know if this is also reverse thread since I believe the pulley spins the other way. The 2.0 belt tensioner sits on top of the belt instead of the belt going over the top.
  20. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    2003 Silverstone Grey 2.9L 24v twin turbo VR6, 2002 S6 Avant
    02-25-2008 12:46 PM #20
    Quote, originally posted by Kevin0323 »
    Try checking in the 2.0L engine forum?
    Driversport|| Valley Dubs PM me for all your Fragola Fittings and Billy Boat Exhaust Needs!!!
    The Elite 24v VR6 Club: Member #4
    My Build Thread
  21. Member Kevin0323's Avatar
    May 3rd, 2006
    Puyallup
    2002 Jetta GLS
    02-25-2008 12:51 PM #21
    of course.
  22. Member coatofarms's Avatar
    Dec 27th, 2006
    Valdosta, Ga
    1990 G60, 2007 GTI Cone Killer, 1989 E30 2dr
    02-27-2008 08:47 PM #22
    awsome write up! I know it's for mostly the pulley....but when I replaced my water pump, I repacked my bearings (barely any grease left at 60k) and it totally cleaned up all noises...besides my intake manifold.
    \\\DateNavis///
    DIY: O2M OEM+ Short Throw http://forums.vwvortex.com/showthrea...6#post79056376
  23. 03-19-2008 07:47 PM #23
    Can you re-pack the bearings on the tensioner pulley for the 24v VR6?
    Great write up!!!!
  24. 04-25-2008 03:18 PM #24
    I doubt it. Much better to just replace the bearing.
    The tensioner itself is fine. It's the bearing and pulley that fail.
    Now if someone would just sell that part we would be golden
    My belt snapped last night, same issues with 7 and 6 ribbed belts.
    Found the correct one at a local indi store. Conti 6 ribs.
    I love the routing diagram you have, it took me 30 mins to find it on my dvd Bently.
    Should have checked here first
    I left the tensioner pulley in place, yes tight and fiddly but doable.
  25. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    04-25-2008 03:30 PM #25
    http://www.gruvenparts.com sells tensioner pulleys made from aluminum.
    My Build Thread
  26. 04-29-2008 12:26 PM #26
    NIce, I think i will swap mine out for one of those.
  27. Member Ld7w_VR's Avatar
    Apr 21st, 2006
    Alexandria, VA
    2003 Gti, 2001 Wolfsburg
    05-19-2008 10:38 AM #27
    Nice DIY. And wow those pullies really are big and ugly. hahah
    The Elite 24v VR6 Club: Member #268 "Like 6 cylinder of 15 degree sex"
    (_fishbowl society_)
  28. 05-22-2008 03:39 PM #28
    if anyone has any troubles or questions let me know, feel free to pm me. as for repacking the bearings..i would advise against that as well. and for the 2.0 tensioner pulley im not sure if it is reverse thread...stick a bolt in it and see...thats much easier than researching it
  29. Member
    Jun 16th, 2006
    Portland, OR
    2004 VW GTI 24v VR6
    05-22-2008 07:23 PM #29
    Some one told me that you will cause severe engine damage immediately if you use lighweight underdrive pulleys, as well as a lightweight fly wheel. Is this misinformation or truth?
  30. 05-22-2008 08:44 PM #30
    That's a huge topic that's been debated extensively - let's not get onto that topic in this thread. Do a search, read up on it, and decide who's opinions you believe
  31. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    05-22-2008 10:17 PM #31
    Quote, originally posted by Veedub_junky »
    Exactly.
    My Build Thread
  32. Member ruetzal's Avatar
    Dec 17th, 2007
    Wisco
    '13 WRX, 2009 A3 sold, '03 GTI sold
    06-14-2008 12:57 AM #32
    save
  33. 11-10-2008 12:25 PM #33
    I repacked my tensionsr pulley bearing this time last year. I had the entire thing disassembled and I had all the balls out and everything. I repacked it with some really good high temp grease and it worked out great... And now it's starting to squeak again lol. So I'll just get the gruvenparts one if I don't supercharge the motor wihin the year. I recommend just getting a new pulley if you're contemplating fixing a squeaky tensioner pulley.
  34. 11-10-2008 08:06 PM #34
    FYI - if your pulley starts to chatter, squeal, etc..., change it immediately! Here's what happened when I couldn't get to my wife's fast enough on her 12v:
    BTW, that was less than 1 week after it started making noise... The pulley exploded/shredded - I think this is about all that was left of the pulley:
    Moral of the story - don't screw around, get the Gruven pulley before this happens to you
    Per Paul, his bearing is rated at 20k rpms - the OEM bearing isn't even rated to redline
  35. Member Zuber Speed's Avatar
    Oct 7th, 2001
    Ontario
    24v
    11-12-2008 08:49 AM #35
    I just changed my serp belt and tensioner because of the squeel. after like 100km, its making a slight squeel again, ideas?
