VWVortex.com - S4 Headliner.
    Results 1 to 18 of 18
    Thread: S4 Headliner.
    1. Member Gti.1love.1life's Avatar
      Jan 2nd, 2006
      Jersey
      12-29-2007 05:39 PM #1
      Just some pics of the swap that are long overdue.
      S4 Sunroof Control is on the way.
      Empty.
    2. Member skiba's Avatar
      Jul 27th, 2004
      Long Island
      98 A4 2.8QM Avant - 91 miata
      12-29-2007 05:47 PM #2
      Nice dude, superfresh! [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 12-29-2007 07:48 PM #3
      very nice [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 12-29-2007 09:13 PM #4
      i like the white buttons its diff
    5. 12-29-2007 10:51 PM #5
      dope.
    6. 12-29-2007 11:23 PM #6
      looks really nice. I'd get the sunroof cover before the buttons though
    7. Member Gti.1love.1life's Avatar
      Jan 2nd, 2006
      Jersey
      12-29-2007 11:56 PM #7
      Quote, originally posted by kenncmiller »
      Honeslty, I don't feel like dropping the whole sunroof to just change the cover. I'm too lazy for that.
      Empty.
    8. Member .Mad Hatter.'s Avatar
      Oct 18th, 2007
      Toronto
      B5 A4, MK6 Jetta
      12-30-2007 12:15 AM #8
      That is ****ing money...is this a facelift car, run into any troubles?
      Quote Originally Posted by futur View Post
      who is fastest? if you guys didn't find out, what were you doing instead? patching floors? #mk3 #lulz # POR15 #umadbro #supercharger #thatsalottospendforjust8psi #justthetip #justkidding #noimnot
      podi.ca
      Scraped.Crusaders. l the.final.offset l flickr
    9. Senior Member MFZERO's Avatar
      Mar 13th, 2002
      Haverhill, Ma.
      2011 Kink Gap Xl, 2000 Haro Blammo,'08 Gti
      12-30-2007 12:29 AM #9
      looks good.
      I left the sunroof panel in my 90 the original color when I re-did my headliner as well.
      Modified by MFZERO at 12:36 AM 12-30-2007
    10. Member Gti.1love.1life's Avatar
      Jan 2nd, 2006
      Jersey
      12-30-2007 12:32 AM #10
      Thanks for the comments guys.
      Quote, originally posted by kollisioncourse »
      Thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG] , Yes this is a facelift['01], And no troubles, perfect fit.
      Empty.
    11. Member VReihenmotor6's Avatar
      Dec 12th, 2001
      Mass
      12-30-2007 01:04 AM #11
      how hard was it getting the headliner down?
      how does the B pillar trim come off?
      I've got to clean my sunroof drains bady and I think I'll pull the headliner down to do it
    12. Member Gti.1love.1life's Avatar
      Jan 2nd, 2006
      Jersey
      12-30-2007 09:00 AM #12
      Quote, originally posted by VReihenmotor6 »
      Not to bad, after you take off the handles,visors,visor clips,front and rear dome lights, There are a few clips around the sunroof that hold the headliner up.
      The hardest part is getting the headliner in and out of the car.
      Just pops off like the other pillar covers, It just does not have any bolts holding it in like the A&C pillars. Its attached with two clips at the top of the cover.
      Empty.
    13. 12-30-2007 01:38 PM #13
      VReihenmotor6
      "how hard was it getting the headliner down?
      how does the B pillar trim come off?"
      The B-Pillar trim pulls straight out at the top and slides up to release from the lower cover. Remove the kick panel in the front, and the whole lower door trim. Release the lower B-pillar panel clips behind the lower door trim and pull up.
      Don't do what I did the mine and try to pull it around the retainers on the lower B-pillar cover. Stuff breaks and you look like a fool. I work on Japanese imports, they're a bit different that's for sure.
      I haven't looked as to where the Sunroof drains are in B5's but there should be a drain at each corner of the sunroof assembly. If you don't go balls out, some compressed air will clean them out quick, but you can also blow off the tubes and make a huge mess if you're not gentle.
    14. Member kish0000's Avatar
      Sep 25th, 2006
      Shavertown, PA
      '01.5 b5 a4; '09 outback sport
      12-30-2007 05:11 PM #14
      looks real awesome, i hope i can do this soon [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. Member VReihenmotor6's Avatar
      Dec 12th, 2001
      Mass
      12-30-2007 07:03 PM #15
      Quote, originally posted by djwimbo »
      I assume they are the same as my old mk3 VW I'll simply disconnect the drains and blow a ton of compressed air thru them to clean ou the tubes
    16. Member SlimQuattro's Avatar
      May 15th, 2008
      Morgantown WV
      78 rabbit, 83 rabbit pickup
      02-24-2012 10:27 AM #16
      Anyone have any tips on cleaning a s4 headliner? I just picked one up an I want to clean it up before I install it. It also has a small impression or two if anyone knows how to get them out.
    17. Member
      May 29th, 2009
      845 ny
      96 A4 2.8
      02-24-2012 12:16 PM #17
      im going to assume this will direct swap for pre facelift too....
      F.T.W.L.T.B.D.W.I.C.T.W
      instragram: gallhue
    18. Member
      Feb 3rd, 2011
      Lombard, IL
      99.5 A4 1.8TQM 98 Passat Wagon
      02-24-2012 02:18 PM #18
      Quote Originally Posted by gallhue View Post
      No. You need to swap in a facelift sunroof also.
      Alex
      Strictly Pleasure
