Results 1 to 23 of 23
Thread: The baby 2.0T FAQ/DIY. Contributions welcome!
  1. Global Moderator iThread's Avatar
    Sep 27th, 2005
    12-30-2007 02:40 PM #1
    This is going to be a long work in progress but, it's about time it happened. PM me with topics you think should be added.
    FAQ:
    Chip FAQ - D.Passat00
    Some stock MAF readings. - GT17B
    MKV GTI Wiki - Various
    List of similarities and differences between the S3 and 200HP engines. - D.Passat00
    Forge DV installed - includes my impressions as well as pics and vag-com boost logs - D.Passat00
    Why is there a milky substance on my oil cap? - Spax MC
    Don't run 100 octane or higher in cold climates. - Kid Hobo
    A word on the oil debate and VW 502 certification - raceware
    The VW/Audi 502 and 505 approved oil list - GT17V
    Why do I have fault codes after a chip flash? - Theresias
    DIY:
    Chipped 2.0T preventative maintenance. - (mkV)Jetta2.0t
    Common issues and remedies. - D.Passat00
    How to reset "Service Now" indicator - cerny420
    Plugs & Coils Replacement - oooo-a3
    Forge Direct Replacement DV - oooo-a3
    Dogbone Mount Insert - oooo-a3
    Forge Short-Shift Kit - oooo-a3
    How to remove the engine cover / stock airbox. - oooo-a3
    Forge "Twincooler" FMIC revisted - D.Passat00
    DIY: Vag-com Logging and Graphing. - D.Passat00
    How to change the air filter on 2.0T engines. - Chuibacca
    Downpipe install. - Dean F
    DIY DSG Fill Tool - VAS 6262 - ZWStewart
    Noise Pipe Delete. - Twelvizm
    How to change your cam follower. - jc@douglas
    Intake cover retention. - 0000-A3
    PCV installation and Eurojet PCV valve installation. - 0000-A3
    Hot to check which revision cam you have. - NoRegrets78
    How to properly find a boost leak. - syntrix
    Modified by iThread at 9:13 AM 5-9-2008
  2. Global Moderator iThread's Avatar
    Sep 27th, 2005
    12-31-2007 09:07 PM #2
    Ok folks, here's how I'd like to handle submissions.
    Reply to this topic with links you feel should be included in the FAQ/DIY. I'll review the links and then add them or reject them and let you know why.
    After I make a decision I'll delete your post so I know I reviewed it.
  3. Member iluvtomesswithu's Avatar
    Jun 26th, 2006
    mtown nj
    07 gti
    05-31-2008 09:46 PM #3
    you should include a boost gauge install diy
    Made me think, best warthog combination.
    Driver = Master Chief
    Gunner= Mr T
    Passenger =Chuck Norris
    Random Thought
  4. Member Josein06GLI's Avatar
    Jun 28th, 2008
    San Diego, Ca
    2012 Audi A4, 2006 VW Jetta GLI, 1989 MK2 GTI 16v
    07-15-2008 07:53 PM #4
    ditto on that. would be very helpful to begginers or for some that end up doing this trying to firgure it out lol
    2006 BMP VW JETTA GLI DSG some coils, some bolt ons and some wheels.
    1989 VW GTI 2.0 16v some coils, some bolt ons, and some wheels.
    2012 Audi all stock, its hers. she dont want me messing with it...yet.
  5. Member JEttaVR66Spd's Avatar
    Jun 9th, 2005
    Indiana, US
    1987 Jetta VR6, 2009 Eos 2.0TSI
    07-20-2008 07:18 PM #5
    I have a picture tutorial, with captions, of how to inspect/install a cam follower on a Longitudinal Audi A4 2.0T. It includes a lot of extra pictures of the process and the tools needed for the job.
    http://forums.vwvortex.com/zerothread?id=3940922
    Might be redundant since you have one for the GTI/GLI/A3, but thought I would offer anyway.
  6. Member emo_dubber's Avatar
    May 11th, 2007
    Hamburg, NJ
    2007 GTI 2.0T
    10-07-2008 04:46 PM #6
    awesome feed!
  7. Member OOOO-A3's Avatar
    Jul 19th, 2004
    KILG
    2011 Subaru Legacy
    10-12-2008 11:24 PM #7
    Fumoto oil drain valve installationFumoto oil drain valve installation & part numbers
  8. Member idoke1's Avatar
    Feb 22nd, 2009
    Sacramento,CA
    SOLD! 2006 VW GLI, APR stage 1 VID: http://www.youtube.com/watch?v=5FMdDKpRW-0
    02-27-2009 09:17 PM #8
    That's some good stuff to know and DO! Wooohooo!
  9. Member Slickvic's Avatar
    Apr 24th, 2006
    WI
    2010 Mustang GT, 2005 Legacy GT
    06-20-2009 07:26 AM #9
    Alternate DSG fill tool:
    http://forums.vwvortex.com/zerothread?id=4387117
    Thanx.
    That other non-douche Mustang owner.
  10. Member spoolin2o's Avatar
    Sep 21st, 2004
    West burbs of Chicago
    2003 GLi Jetta
    08-12-2009 12:11 AM #11
    is there any awe vent gauge pod install diy or boost gauge install diy?
  11. 08-12-2009 02:13 AM #12
    Quote, originally posted by spoolin2o »
    Right on AWE's website
    http://awe-tuning.com/media/pd...e.pdf
  12. Member spoolin2o's Avatar
    Sep 21st, 2004
    2003 GLi Jetta
    08-29-2009 10:04 PM #13
    Does anyone know why there are some jetta 2.0t with a redline of 5850 instead of the 6500 like all the other 2.0t's? please PM me if you have an answer.
  13. Member 2pt0tee's Avatar
    Apr 28th, 2008
    somewhere in the trees
    JATO powered gokart
    02-16-2010 11:31 AM #15
  14. Member 2pt0tee's Avatar
    Apr 28th, 2008
    JATO powered gokart
    02-26-2010 11:16 AM #16
  15. Banned KIDVersion1's Avatar
    May 10th, 2009
    Hellertown, Pa
    Veyron Super Sport
    05-28-2010 12:10 AM #17
    Here is a DIY for replacing the engine cooling fan I first put in the MkV forums but is now also in the 2.0T FSI forums.
    DIY: Cooling Fan Replacement
  16. Moderator silverspeedbuggy's Avatar
    Aug 8th, 2001
    Cleveland Heights OH
    2006 GLI and 1987 Scirocco 16V
    06-17-2010 04:32 PM #18
    It doesn't seem like any of the links to Vortex threads are working anymore.
    Probably due to the switch to vBulletin.
  17. n00b
    Nov 23rd, 2010
    Simpsonville, SC
    2006 VW Jetta GLI
    11-26-2010 09:21 AM #19
    I am thinking of swapping out my 2.0T (bottom end is no good).
    1) Is a full swap the easiest route to take considering that this is my daily driver and I need the motor running on this car stat?
    2) Or would it be just as easy to swap the bottom end and keep the costs down?
    3) Is there a DIY instruction for the engine/bottom end removal?
  18. Member rydaddyry's Avatar
    May 22nd, 2007
    Long Island, NY
    2012 Jetta 2.5L SE, 2009 VW Passat 2.0T(SOLD) 2001 VW Jetta 2. slow
    03-04-2011 09:04 AM #20
    any luck with that boost gauge install ??
  19. 10-01-2011 05:17 PM #21
    Was looking at oooo-A3's blog, and the latest submission is "its gone" and a whole speal about bad memories that the car brings up, is he talking about the car, or some bitch that cheated on him? Just curious
  20. Member cvincent78's Avatar
    May 8th, 2005
    Cincinnati, OH
    91 MK2 VR6 GOLF 97 VOLVO 850 Wagon
    10-11-2012 04:35 PM #22
    DIY: 2.0t Timingbelt / Waterpump (w/ Non-divided cover) and Thermostat
    The timing belt part of the DIY is finished. There is enough info for you to replace your thermostat, just not a step by step posted yet. I will be posting that later on this week! Good luck to anyone that is going to perform this procedure on their own! Anyone can PM me with questions any time!
    cvincent78
  21. 01-30-2013 12:55 AM #23
    RiDE SO SiCK iT MAKE YOU WANT TO KiLL YOUR SELF LML[a4][headbang] CHECK OUT MY PAGE http://www.youtube.com/user/RICHKID3003?feature=mhee OR GOOGLE ME @ RiCH A4 B6/B7
    MY LAST AUDi RED B6
    [hail][hail][hail][hail][hail][hail]
