VWVortex.com - 2000 Jetta VR6 won't start
    Results 1 to 24 of 24
    Thread: 2000 Jetta VR6 won't start
    1. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-30-2007 02:59 PM #1
      I have a 2000 Jetta VR6. I just had a new tranny and clutch put in just over a week ago due to the differential blowing a hole through the tranny. Well I didn't even have my car back for a week when I went to go start my car... and it wouldn't start. Everything comes on (electronics, fuel pump, etc) just no action to attempt to start it. No starter noise, no nothing. Just full dash lights, electronics, and the usual fuel pump and the usual click I hear from around the throttle body.
      Any ideas what could be causing this? I was reading up on the ignition switch, but I understand that it usually effects electronics too. Maybe a bad connection on the starter? Maybe the clutch switch? Any ideas?
      Thanks in advance!
    2. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-30-2007 03:00 PM #2
      Battery has been tested and is fine. It is def not a bad battery.
    3. 12-30-2007 03:05 PM #3
      had the same thing and it was a shot alternator, but i guess it could be a different problem.
    4. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-30-2007 03:07 PM #4
      Yeah that would make for a dead battery
    5. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-30-2007 05:07 PM #5
      Anyone?
    6. Member Futura-Matt's Avatar
      Oct 1st, 2006
      Scranton pa
      06 T-reg
      12-30-2007 05:09 PM #6
      Check your grounds, i know that there is one on the Trans it could be your problem.
    7. Member Jasmeleg's Avatar
      Nov 29th, 2007
      Canton, OH
      12-30-2007 05:12 PM #7
      Check the power cable to the starter. Maybe when the starter was being put back in someone forgot to tighten the nut all the way and it vibrated loose from the week of driving.
    8. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-30-2007 06:20 PM #8
      I know the starter is like under the battery. What is the easiest way to get to it?
    9. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-31-2007 12:46 PM #9
      Bump...
    10. Banned
      Nov 24th, 2001
      12-31-2007 12:49 PM #10
      like what was said above....verify that the battery and all the associated cables are in good shape.....if those all check out, then the issue is the starter, or the ingition switch....rule out the easiest 1st.
      also, LOAD test the battery, do not trust a simple voltage check. [IMG]http://**********************/smile/emthup.gif[/IMG]
    11. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-31-2007 04:38 PM #11
      I just checked all the cables running to the starter and they all look fine. If it was a bad ignition switch, wouldn't electronics act funny?
    12. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      12-31-2007 09:26 PM #12
      I replaced the ignition switch... not the problem.
      Should I go ahead and try to replace the starter? Is there anyway it can be tested while it is still in the car?
    13. Banned
      Apr 15th, 2007
      12-31-2007 10:11 PM #13
      Try push start? (manny tranny only)
    14. 12-31-2007 11:40 PM #14
      Quote, originally posted by cannondalemtb »
      to test the starter just remove it and hold it out in the open while someone tries to start the car...you should see the solenoid and starter pinion pop out whilst it rotates. If it's doing that then you might check to make sure all the other connections are hooked up like the reverse indicator on the back of the tranny and simple ish like that. Who did the maintenance before? yourself?
      I had something similar a while ago thinking my engine wasn't turning over and the car wouldn't start but turns out I got the fuel lines on the rail backwards A loud explosion, fuel in my eyes and 20 minutes later I had it right
      My Black Box | Kenwood X792 | Soundstream STL1.600D & 2.560 | CDT CL61a | RE SRX15 | Streetwires | TechFlex | PowerWerx
    15. 12-31-2007 11:59 PM #15
      Make sure the starter lead isnt grounding out, it happened to me once when I wasnt paying attention, during a bendex grease up
    16. Junior Member
      Oct 18th, 2007
      N. Attleboro, Ma
      '09 CC vr6 4motion
      01-01-2008 12:04 AM #16
      Pop start works, but that is no solution.
      The work was done by a local shop and friend. How hard is the starter to get out?
    17. Banned
      Nov 24th, 2001
      01-01-2008 12:12 AM #17
      please go back and state what you have done so far....
    18. 01-01-2008 12:18 AM #18
      ^^^Larr-bear's posting in here?! Miss ya big guy!
      I've got the last time we met rasterized on a wall in my office j/p
      drive up on some ramps or jack it up, two bolts, pull...might have to remove the clamps holding the power steering fluid line but you won't have to disconnect it, just push it out of the way if you want to drop it down all the way.
      climb under the car and look at it and you'll understand how it works. The upper bolt is probably easier to remove without the battery in the way. I had mine in the trunk so I never had that problem.
      Modified by WAGN LOL at 11:20 PM 12-31-2007
    19. 01-01-2008 12:22 AM #19
      here's a pic of under your car (my old VRT but same damn thing), you can see the starter to the left and the line I was talking about:
    20. 01-01-2008 12:24 AM #20
      and a look at where all the bolts are without the starter in there
      hope these are helping.
    21. 01-01-2008 02:19 AM #21
      I would say just replace the starter and try it, I'd bet thats the fix.
    22. 01-01-2008 03:01 AM #22
      Quote, originally posted by Jason LaRue »
      he can figure out if it's bad just by pulling it and cranking the engine...it'd be a waste of money to replace it and not do the simple check first.
    23. 01-01-2008 08:33 AM #23
      Why not take a meter or test light and just check to see if you're getting power to the starter/solenoid? Cheaper to diagnose the problem than just replacing random parts.
    24. Member GoodOlArtie's Avatar
      Mar 17th, 2005
      PNW
      2007 Audi A4 Avant 2.0t
      01-01-2008 01:27 PM #24
      you can also jump start the starter to see if it is working. it worked for me once.
