Page 2 of 2 FirstFirst 1 2
Results 36 to 60 of 60
Thread: Has anyone seen this?
  1. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    2008 Jetta 2.5, 1996 Rustbucket
    03-28-2008 11:12 PM #36
    everything arrived today, hooked it up, and it works! but... only when the lights are actually on, with only drls, it still flickers so i guess next step is to cut drls off..
    at least it looks good at night tho lol
    it costs me 92 dollars for vw to take it in and cut them off, i got 50 bucks for anyone in Northern VA with a VAG-COM and knows how to cut them off. if anyone wants to let me know. id really appreciate it
    They're going to their house over there.
    You're not utilizing your education properly.
  2. Member need_4spd's Avatar
    Jan 11th, 2006
    Springfield,MO
    04 Dodge Ram 4x4, 05 Jetta GLI
    03-30-2008 03:03 PM #37
    we need pics!!!
    and if you can show pics of the cut off too
  3. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    04-07-2008 05:56 PM #38
    I QUIT!
    they were working great! i finally decided to just go to vw and get the DRLs cut off, came back home and hooked every up nice and secure, double checked everything, and they turned right on. i started the car, stayed on! drove around for about 15 minutes and they were beautiful lol. so i came back home, went inside for about an hour and when i went to go to leave again i started the car, turned the lights on and halfway down the street they started flickering..... i pulled over, double checked everything again and found nothing. they havent worked since.
    i tried swapping fuses and relays, nothing. until someone finds out how to get them working i quit. i already blew enough money on this project...
  4. 04-12-2008 02:18 PM #39
    maybe you just bought a bad kit? im going to be attempting this...i got my HID kit and im waiting for the adapters from kbcars. so i guess ill be the next one frustrated? iduno well see.
  5. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    04-19-2008 04:21 PM #40
    haha hopefully you wont be, let us know how it goes
  6. Member built2prfctn's Avatar
    Jul 9th, 2005
    Woodbridge. NJ
    2011 CC R-Line
    04-21-2008 10:33 PM #41
    I also just bought my kit and adapter.. Keep me updated guys and good luck
  7. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    04-22-2008 03:53 AM #42
    damn i hope someone gets these right!!
    if ANYONE does, PLEASE let me know what you did. i really dont want to sell my kit, id rather have them working
  8. Member built2prfctn's Avatar
    Jul 9th, 2005
    Woodbridge. NJ
    2011 CC R-Line
    04-26-2008 07:12 AM #43
    Ok guys. I got my HID kit and kb adapter in today.. IT WORKS GREAT!! Besides a couple problems maybe u guys can help me with.
    With that said install took me about 3 hours with my friend.kb thing is a piece of **** after market part, the bulb doesnt sit in there to good but after gorilla glueing the prongs on so they dont slide in and out and glueing the base of the bulb in there is alright.
    Also i wanna let u guys know that I already had my DRL shut off with a friends vag.
    Ok probelm number one.
    Relay kinda makes a clicking noise when the car is turned on and lights are on. Doesnt make the noise when the car is off and lights are on no idea but it doesnt sound healthy.
    Problem two.
    Dash lights are on for the bulb and the air bag i dont know why the airbag one is on.
    Problem three. Is the left beam is way to high how do i adjust the beam? Do i just tilt the bulb down???
  9. Member built2prfctn's Avatar
    Jul 9th, 2005
    Woodbridge. NJ
    2011 CC R-Line
    04-26-2008 07:13 AM #44
    Also I have no problems at all with flickering.
  10. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    04-27-2008 09:03 PM #45
    well relays click, but only when being started and should stop after a second or two (or so ive been told)
    i also had the airbag sensor come on, dunno whats up with that
    i had no problem just reaching in and grabbing the reflector and clicking it down a couple notches... i used a car parked in front of me and clicked it down until it wasnt hitting theyr back windshield any more
    and it clicks right back up if you ever take the HIDs out
    BUT MINE STILL F***ING FLICKERS!!!!!!!!!!!!!!!!!!!
  11. Member built2prfctn's Avatar
    Jul 9th, 2005
    Woodbridge. NJ
    2011 CC R-Line
    04-27-2008 09:53 PM #46
    Weird mine dont at all. Except when i try putting my high beams on
  12. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    04-28-2008 03:48 PM #47
    what brand ballasts did you get i have a feeling my ballasts are the problem
  13. Member built2prfctn's Avatar
    Jul 9th, 2005
    Woodbridge. NJ
    2011 CC R-Line
    05-02-2008 10:57 PM #48
    http://www.gothids.net/hidconversionkits.aspx
    I need to figure out how to get rid of the air bag light? is there something wrong with the airbag? i hope not
  14. Member built2prfctn's Avatar
    Jul 9th, 2005
    Woodbridge. NJ
    2011 CC R-Line
    05-05-2008 02:47 PM #49
    bump
  15. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    05-06-2008 11:32 PM #50
    well... i finally have my HIDs working!
    anyone who cant get rid of that annoying flickering issue could do what i did.
    i used a switch, you can buy one for like 6 bucks at any auto parts place, and get some wire (i used 16 gauge).
    run wires from the positive and negative wires on the ballasts, connect the positives from each ballast into one wire and run it to the switch.
    connect the negatives from each ballast into one wire and run it to the negative terminal on the battery
    run one wire from the positive terminal to the switch (also add a fuse to the positive wire).
    ground the switch and you're good to go. you have that extra step of having to hit the switch everytime you want headlights, and the lightbulb out sensor will always be on, but to me it was worth it since i had no other way to get them working
    just thought id put this out there for people who ran out of options like i did.
    Modified by MKVJET08 at 8:34 PM 5-6-2008
  16. Member frankachela's Avatar
    Jan 29th, 2007
    Weiden, Bavaria, Germany
    2007 VW Golf 5 (Rabbit)
    05-11-2008 09:06 PM #51
    Quote, originally posted by built2prfctn »
    Problem two.
    u need a vag com
    (2) The airbag problem is just the safety trigger for the airbags... (YOU DISCONNECT UR BATTERY?) nothing its wrong wit ur airbags just need smbdy wit a vag to erase the fault codes and it will go away
    on the headlight housing when you open your hood look at it from the top and you will see a white hole it looks like u will need a allen wrench just put it in there ant twist just watch it cuz u cold strip that thing and will have to buy a hole new headlight housing
    hope this helps
    and get prjector god dammit
    quit blinding people stingy ****er
  17. 06-04-2008 08:32 PM #52
    to intall an HID kit into our cars will it EVER be necessary to take the whole headlight assembly out?
    Modified by Geeb at 6:01 PM 6/4/2008
  18. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    06-08-2008 11:44 PM #53
    nope
  19. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    2008 Passat 4Mo 3.6L Wagon, 98 VRt, 2010 Routan/Caravan :)
    06-10-2008 08:18 AM #54
    Skimming through this thread so this may have been stated already but...
    Why would you need more light when regular 35W HID is already dangerous as a retrofit into halogen housings?
  20. Member Naokuphilip's Avatar
    Apr 18th, 2008
    Tokyo, Japan
    2008 vw Rabbit
    11-20-2008 06:36 AM #55
    ummm I still cannot figure out how to do the trick.. hhe with oem bulb without wires and hid kit bulb with wires.. how do you do that part on the oem headlight housing? Pics will be appreciated!!
  21. 09-03-2010 12:36 PM #56
    On that little plastic hid adapter how do you know which side is positive and ground
  22. Member wetheitalians's Avatar
    May 3rd, 2008
    NJ
    06 Jetta 2.5L ( VE )
    04-13-2012 08:37 PM #57
    hey idk if anyone else reads or has read this thread in a a while but, i put a xentec (ebay brand) HID kit in my friends 07 jetta...
    step 1: buy an HID kit with the dash light cancelers, and 35w-55w converters built into it already....SPEND THE EXTRA $...
    step 2: buy these
    http://www.ebay.com/itm/H7-HID-XENON...ht_5582wt_1163
    or these
    http://www.ebay.com/itm/H7-HID-XENON...ht_5666wt_1163
    step 3: adjust your light housings so u dont blind or kill people.
    step 4: enjoy
  23. Member 20jetta98's Avatar
    Feb 8th, 2012
    CT
    1998 Jetta 2.0
    04-15-2012 06:22 PM #58
    ive delt with retro solutions myself since he works in my state... hes a great person to deal with and help u anyway he can possibly...
  24. 04-26-2012 11:47 PM #59
    Hey,
    I just installed my h7 hid kit.. Though I was running into an intermittent working right bulb. So i pulled the kit out completely. I was interested in running a relay, which I heard solves this problem. The only thing I dont understand is where I do I connect the relay in the headlight housing?
    Since the factory bulb carrier is a screw in type there is no way I can use it while also having a mounted hid bulb. I was thinking of getting a universal kit and changing the clips to a female and plugging it in directly to the hid bulb adapter.
    Does anyone else have any ideas?
  25. 05-04-2013 04:49 AM #60
    Old posting I know sorry about bumping it, however I was curious has anyone seen any issues with theiy HID bulbs causing to much heat and damaging the housing of the lights themselves? I was thinking on doing this to my mk5 Jetta, as I have 2 35w ballasts left over from my fog lights that I upgraded the ballasts to 55w. I bought the extra wires, adapters and anti flicker kit off eBay, just waiting for it all to show from the motherland haha, just was curious if anyone has seen any side effects from this mod? Also how did you guys run the wire thru the caps? I seen one posting where someone drilled a 2" hole into the cap and fed the wires that way, I'd do that if I had backup caps to revert back to. However i dont have that option currently
    Thanks!
